Question about Kenmore Refrigerators
My refrigerator has a water dispenser on the outside, and the icemaker on the inside. IT makes the ice but I can't get the water dispenser to work, I thought that maybe i somehow locked it, and can't figure out how to unlock it.
    Problem Solver:
  • 18 Answers
The water dispenser solenoid may have gone south on you. Do you use it quite a bit? Hopefully it is only a bad door panel switch though.
Posted on Sep 29, 2009
Why water to icemaker , none to water dispenser , replaced water inlet valve fghs2655pf1 or 4a32520097
Refrigerator Not Making Ice? Water Inlet Valve Test - Fridge ...
? 2:47
https://www.youtube.com/watch?v=aXIX73EI1Z4
May 15, 2012 - Uploaded by RepairClinic.com
This video demonstrates how to test a water inlet valve on a refrigerator. ... Ice maker or water dispenser not ...
Refrigerator Ice And Water Dispenser Not Working - Repair ...
www.repairclinic.com/...---/Refrigerator-ice-and-water-dispenser-not-wo...
How It Works: Refrigerators · How It Works: Refrigerator Icemakers · How It Works: ... Most Frequent Causes for Refrigerator ice and water dispenser not working.
Nov 18, 2015 | Refrigerators
Icemaker will not make, cold water works fine, have changed inside filter nd outside filter I added before I knew there was one inside
Refrigerators with both ice and water dispensers have a dual port electric water inlet valve. This inlet valve is the plastic part usually on the back of the refrigerator where the house water supply connects to. This dual valve has 2 electric coils that open to let water in depending on if you want water to a glass or if the icemaker needs to fill with water. Your problem seems to be the half that fills the icemaker may be bad. The valve comes as 1 complete part for both water and ice.
May 09, 2015 | Refrigerators
Where do I find the ice maker inlet water valve or solenoid? The valve on the back of my fridge has only one hose going to both the water dispenser and ice maker and the water dispenser works fine.
Since there is water that flows to the water dispenser, the water valve is working. Now, there's a spout that water flows from to the icemaker tray. Look for it. It's located on the back wall inside the freezer and maybe behind the icemaker tray. Check and see if it's frozen. If so, defrost your freezer by turning the temperature gauge to off position. Wait a while until it's defrosted, then turn it back on.
Next, make sure that the metal wire is in down position.
If that doesn't work, your icemaker maybe defective and needs replacement.
Nov 01, 2014 | Maytag MFI2665XEM Stainless Steel
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
Icemaker stopped working
You will have to determine whether the problem is due to no water getting to the icemaker or a control problem in the icemaker unit.
There is a water valve near the bottom of the refrigerator where water from the outside source enters the refrigerator. This valve sends water to the icemaker (and probably the water dispenser) when the refrigerator controls call for water. These valves can malfunction, and the water lines can get blocked.
The other possibility is that something inside the icemaker controls has malfunctioned, and it is not calling for water.
Oct 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker doesn't work
chack water valve and make sure it is getting water if so and there is ice in ice maker then your heater is bad and not releaseing ice
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Icemaker not working,water pours from dispenser side
it could be water valve or ice maker that has gone bad.check all connectins to icemaker and tubing to icemaker and water valve.
Mar 20, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Ice Dispenser
hi there,
check to see if you have a leak either on the inside or the outside of the freezer door.
check your icemaker line and see if anything is freezing up.
from the sounds of it, something is stopping the water flow into the icemaker.
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
77 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
