Question about HP Pavilion N5415 Notebook
I re-imaged the unit & it says the network card is working properly in device mgr. But it wont go online when i connect a cable. It stays on "Network Cable Unplugged". The LED on the connection on the laptop does not go on.
    Problem Solver:
  • 8 Answers
1. Try different cable if possible.
2. Check the network port of the laptop. Make sure the pins are in tact and there is no dust/dirt or anything blocking the port.
3. Verify the other end as well. Check the hub/modem/switch or whatever you are plugging into. Make sure it's securely plugged in.
4. If plugging into a router, make sure you aren't plugged into the Uplink or Modem port. If it's a simple 4 port hub, avoid plugging into the uplink port as well.
5. If you have a cable modem that plugs into a router then into your computer, test by powering everything down. Plug the laptop directly into modem's ethernet port. Turn power on to modem. Turn power on to laptop. Check your network light and test internet. If it works there's something wrong with router. If it doesn't, look to the cable for issues.
6. Lastly, if none of those steps worked, remove the ethernet driver and reboot laptop. Let Windows detect the ethernet card, then re-install the driver choosing to overwrite the existing. Know that Windows will tell you you're device is ok just because a driver loaded successfully. It doesn't always know if the driver is the correct one.
Posted on Sep 29, 2009
I am not happy with the service that i am getting.
Wireless connection or hardwired ethernet ?
Which ISP are you contracted to give them a call let them know of your problems or go to another ISP and phone company
Wi-Fi Internet is a popular and convenient way of accessing web pages and other online applications. A wireless router broadcasts an Internet signal, which enables a computer with a wireless capability to access online applications and sites. Problems with wireless connections require a different approach to troubleshooting than traditional, wired Internet connections. If you find that the wireless connection on your laptop frequently drops out, take a few troubleshooting steps to narrow down the issue and restore your laptop's full functionality.
Reset your network by unplugging the power cords of your Internet modem and wireless router. Wait 30 seconds before replugging the power cords. Restarting your computer will allow the devices to run through their full boot cycle. Test your connectivity after rebooting to verify whether it remains more consistent after the reset. Test your wireless Internet consistency on another Wi-Fi connection that you're legally allowed to use, such as a free public Wi-Fi hotspot. If the connection stays consistent when you're away from home, the problem is likely localized to your home wireless network. If the connection drops no matter which wireless network you are connected to, the problem is more likely with your laptop's wireless card or internal wireless device. Connect the Ethernet cable directly from one of the numbered Ethernet ports on the wireless router to one of the Ethernet ports on your computer. This is a useful way of testing whether the Internet connection is dropping altogether or if your laptop is merely losing its wireless signal strength. If the connection stays more consistent this way, contact the manufacturer of the router or of your computer's wireless card to troubleshoot the device. Plug the Ethernet cable directly from your Internet modem to one of your computer's Ethernet ports. Bypassing the router is useful for further narrowing down the source of your issue. If the connection stays more consistent this way, your router is likely the source of the problem and you should contact the manufacturer of the router for assistance. If the connection continues to drop, contact your Internet service provider to address a possible issue with your modem. wireless network card Go to the Start menu and open the Control Panel. In the Control Panel, open the Device Manager. Locate Network Adapters in the Device Manager list. Click on the plus sign next to Network Adapters to expand a list of all networking devices on your computer. Your wireless card should be listed, and most likely a LAN adapter as well. Alternately, you can open the Network and Sharing Center in the Control Panel, and then click on "Manage Network Connections." Find your wireless connection in the list and right-click it, then select "Status." Under the Status menu, click "Details." This will produce a list of information about your Internet connection, including your wireless card.
Test a Wireless Network Card b> laptop or desktop computer that has no built-in wireless capability needs a wireless network card installed in order for the computer to detect and connect to wireless connections. Before you can establish wireless connection, however, you need to make sure that that your wireless network card is working properly.
Ensure that the wireless network card is properly installed in the computer. A wireless network card can come as a PC/PCMCIA card that only needs to be inserted into a PC card slot in your computer, or it may be a wireless PCI card that needs to be installed inside the computer. Wireless PC/PCMCIA cards are usually used for laptops while wireless PCI cards are installed in desktop computers. Install the driver of the wireless network card. Note that if the driver is not installed, the wireless network card will not be able to communicate with the computer. Insert the installation CD into the optical drive, wait for the computer to recognize the installer and follow the on-screen instructions. Finish the installation procedure and then reboot the computer. If you do not have the installation CD, download the installer/driver from the manufacturer's website. Check if the computer can detect wireless networks and Internet connections. Access the "System Tray" at the bottom-right corner of your screen and double-click the "wireless icon." Browse through the list of available wireless networks and then connect to any one of them. If there is no "wireless icon" in your system tray, the wireless card may not be properly installed to the computer or the device may be malfunctioning. If you cannot connect to a wireless connection, ensure that you entered the correct network password (if connecting to a secured network).
Feb 25, 2013 | Computers & Internet
Dell Gx280 won't connect to internet - in Device Mgr in Other devices, all 4 are yellow ?; cable and signal are good, just no connection Can't download any drivers if can't connect!
try using another computer that can go online and download NETWORK DRIVER then save it to a flash drive and transfer it to your optiplex. type this in the search box, R132254.EXE this will help you connect to the internet..
Nov 10, 2010 | Dell OptiPlex GX280 PC Desktop
Internet connection work fine on WiFI, but connections from desktop, connecte with cable to router LAN port does not work
Either you are connected to a different wireless network or the connection from the modem to the router is incorrect.... Make sure that the other end of the cable from the modem is connected to the WAN/Internet port of the router. If you have this kind of connection already, try checking the TCP/IP properties of the computer connected to the LAN port, make sure that it is set to obtain an IP address automatically...
Mar 28, 2010 | Zyxel Prestige 660R Router (91004397002)
Westell 6100F: dsl lite on ,internet lite blinks/steady, data light out and stays out, no internet, no network device or dsl modem in device mgr, called verizon they said my network card is bad, took pc to...
Try a different ethernet cable. It could be that your cable is bad. I had that happen to me before. My was from the modem to the router. If it was working at the store and not at home, then it is cable. It is should bea cheap fix.
Oct 20, 2009 | Westell Wirespeed LiteLine 6100...
Can't connect to internet on desktop computer
Most likey the issue is with the network adapter. As it does not work even with the modem and router the card seems to be faulty.
Hope this helps.
Sep 05, 2009 | Computers & Internet
LAN problem
If your network card works properly( you can check it using device manager- Right click on my computer icon -> manage)
check its ip address settings(TCP/IP setings). Make sure there are proper settings for dns.
Otherwise you can do a system restore.
May be an OS setting have caused the problem.
Hope your machine is virus free.
If there is a problem when you check device manager what you have to do is use *********** board cd and update/re install(after removing) the drive.
If any of these are not working, you may have to check your network adapter.
Please rate the answer if it works for or helps you.
Thanks Good Luck :)
Jun 12, 2009 | Computers & Internet
Lan hookup works with laptop but not with desktop. desktop crashed a while back and I have reinstalled cds I received from Dell, but now the desktop does not recognize the lan hookup. I know it is not the...
if your talking about the RJ45 cable that goes from your cable modem
to PC, then you need to make sure that the Ethernet hardware
has its driver installed. Go to device MGR and check and see if it is listed, it should be listed under network adapters. If there is nothing there or there is no network adp even listed under devise mgr then
your driver is not installed,just go to dell online and look at the download section for your pc and find the Ethernet driver.
Apr 17, 2009 | Dell Dimension 1100 PC Desktop
Cannot connect to wireless network
may be your router needs a firmware upgrade.
check the router's website.
and make sure the router and the wireless card are both using the same 802.11 protocol
Feb 22, 2009 | Linksys WMP300N Pre-802.11n Wireless...
Cant get network to recognize the cable connection
XP doesnt install the right device drivers for the NIC card (LAN card) if you have the origianl Device utilities disk, you can insert it and find those drivers (they will be checked) if no disk, use another pc and go to support.dell.com and enter the tag# locate the networking device drivers and its going to be a Broadcom 47xx driver. if not that try others till it works.
Dec 24, 2008 | Dell Dimension 2400 PC Desktop
Internet connection problems using the BEFW11S4
If you are having problems connecting to the Internet, follow the following steps: 1. Internet service: Check with your Internet Service Provider to make sure that service is active. You usually can determine a good link to the service if you can bypass the BEFW11S4, plug directly into the ISP modem unit, and get a good connection. This will narrow the issue down to either the service, or the router. 2. Network cables: Verify that the network cables that connect the network together are plugged into the current ports as they should (modem into the WAN/Internet port, computers into 1, 2, 3, or 4). Also try to change some or all of the network cables that attach to devices coming from the BEFW11S4. You may have bad cables. 3. Router configuration: Your router may not be configured to use your Internet service properly. While plugged into your provider?s modem and able to get online, run the bundled Router Setup Wizard CD-ROM program that came with your router. This will configure the router automatically for you. Note: this program must be executed on the main computer when plugged directly into the providers modem unit and able to get on the Internet 4. Manual configuration: If the Setup Wizard CD-ROM from Step 2 fails to configure your router, you may need a manual configuration. While plugged into the provider modem unit and able to get online, visit http://kb.linksys.com, and search for the name of your Internet service provider for detailed instructions on manual configurations. 5. Router firmware: Upgrade your router to the latest firmware version. Please go to http://www.linksys.com/download to download the latest version of firmware for your product. After the upgrade, be sure to reset the router, by holding in the router?s reset button for 30 seconds and reconfiguring it for use with your service (Step 3 or Step 4). 6. Malfunctioning equipment: You may have a faulty network adapter, or a bad router. Please contact Linksys Technical Support for further assistance.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
Open Questions:
Toshiba Customer Care And Toll Free Number ' Dataalign 'Call +1888784-9316 Toshiba Corporation is a Japanese multinational company that is headquartered in Tokyo. It produces products and services like information technology, communications equipment and systems, electronic components and materials, power systems etc. Toshiba products are innovative and cost efficient which provides best solutions for home or business use. Toshiba has become the world's seventh largest IT Company which launched its first laptop in 1985. All Toshiba products have the best qualities like high efficiency in very affordable pricing, innovation at its best, ultra- portability with faster working laptops and desktops. As known by everyone, every Toshiba user require good Toshiba Customer Care and thus requires a good customer support. Likewise, Toshiba laptops also require a reliable support for the proper working of Toshiba laptops and desktops over a longer period of time. Dataalign provides best in class Toshiba Tech Support exclusively for the Toshiba customers. Dataalign tech support is provided by the highly knowledgeable and expert technicians who have years of working experience in this field and these tech support engineers have been particularly trained to be able to solve the issues related to Toshiba products. Toshiba Support of Dataalign has following features: 1. Slow speed issues are resolved. 2. Toshiba support technicians of Dataalign analyze the issue very carefully and follow proper trouble shooting steps to get to the real cause of issue for properly suitable resolution. 3. Blue screen of ***** and other errors are resolved. 4. Issues like virus, malware, spyware is resolved accurately. 5. Tech support experts providing Toshiba Support to the Dataalign customers have years of experience in the field of providing helpful assistance to customers with accuracy. 6. Dedicated staff with lots of knowledge makes the support team of Dataalign the best. 7. Customer satisfaction is taken care of every time. 8. Highest productivity is ensured after services to Toshiba laptops. 9. Resolution is provided over remote access so that Toshiba customers can witness the issue and the overall process of resolution applied. 10. Toshiba Customer of Dataalign works 24/7 and 365 days a year. For any kind of help in Toshiba products contact on the Toshiba Tech support number of Dataalign :- +1888784-9316
Jun 22, 2018 | Toshiba Computers & Internet
See all HP Pavilion N5415 Notebook Questions
HP Pavilion N5415 Notebook Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
