Question about Canon PIXMA MX310 All-In-One Printer
Question? Is the pre-loaded s/w
Question? Is the pre-loaded s/w "EASY PHOTO PRINT EX" capable of creating "CD LABELS"?
Epson Artisan 1430. How do I print photo labels onto CDs
You will need photo printing software. Should be available from the manufacturer:
www.epson.com
Mar 23, 2014 | Epson Artisan 1430 Wireless Wide-format...
Printing to adhesive CD labels
you need software like Nero to print on cds
Nov 05, 2013 | Epson Stylus Photo R220 InkJet Printer
Printing directly onto CDs
I'm afraid that is not possible with the printer. You an do cd/dvd labels but you can't print directly onto a cd.
You would need a CD/DVD burner with a Light Scribe capability. You also need special CD/DVD's to use Light Scribe.
Thanks for using Fixya.
PS. Just for additional info, here is a link to support for your printer:
iP4200 Support
Mar 19, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
Cannon Pixma ip5200 Wont print labels for DVDs
In order to print CD/DVD directly, you must use Canon Easy Phot Print & put your disc on the Disc Tray and then insert to the printer. Then enjoy with the amazing printing
May 30, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
How to print cd covers with HP Photosmart Essential 3 5 i have microsoft office 2010 beta and open office 3.1 installed and some avery standard #8931-face-cd labels nd can not figure out where the tools...
hi Justchuck69.
You can use the software that came with your HP Photosmart all-in-one printer to create CD covers and then print them on the discs. For this to work, the CD must be printable, and you shouldn't use CDs that have their manufacturer, size and speed already printed on them. You must use the latest HP software to create and print the covers. If you can't find the installation disc that came with your printer, download the latest version of the software from HP's Support website.
1 Launch the HP Solution Center that was installed on your computer when you installed the HPsoftware.
2 Click the "View Library" button to open the photo library and then select the folder that contains the images you want to use for your CD cover from the left pane. Click the "Add This Folder" to add the folder to the library. You can only use photos from the library to create the CD cover.
3 Click the "Back" arrow near the top of the window to return to the Welcome screen.
4 Click the "Create" button, choose "Disc Labels," and then click either "Standard CD" if you want to print on a standard CD or "Mini CD" if you want to print on a mini CD. Click "Choose This Format."
5 Choose a design from the list of designs, and then click the "Choose This Design" button.
6 Select the photo or photos you want to print on your CD, and then click the "Add These Photos" button.
7 Use the controls in the Edit Your Disc Label section to zoom, rotate and reposition the photo. Click the text boxes and type or paste some text, if you want to add text to the label. Click "Create" when you're satisfied with the result.
8 Select the HP Photosmart printer from the "Printer" drop-down box, and then ensure the "Standard Sizes" option is selected.
9 Click the "Print" button when you're ready to print the cover on the CD. The "Open CD/DVD Tray" message is displayed on the printer's LCD.
10 Pull the CD/DVD tab below the main tray to remove the CD holder, and then place the disc on the ring of the CD holder with its print-side up. Gently press on the CD until it snaps into place.
11 Lower the CD/DVD tray located just below the control panel, and then insert the CD holder into the tray. The printer starts printing as soon as the white lines on the tray and holder match up.
12 Wait until the printing process is complete, remove the CD holder from the tray, let the ink on the CD dry for a few minutes, and then remove the disc from the holder.
13 Close the CD/DVD tray, and then insert the CD holder back into the storage space.
Tips
  • checkPhoto Creations, the latest software from HP, does not support printing CD labels. HP Photosmart Essential is available for download from HP's FTP website (link in Resources).
  • checkThe back of the HP all-in-one printer must be at least three inches away from the wall or other objects.
  • checkIf you use a small CD, don't forget to flip the holder ring over the disc before you snap the CD holder into place.
  • checkYou can add additional folders to HP Photosmart Essential if you can't find the photos you want to print on the CD.
  • checkYou can bold or italicize the text when you type it, but you can't choose a different font or change the size of the text.
  • checkAlternatively, you can use a free third-party utility to create the CD cover and then print it on the disc.
Warnings
  • closeDon't turn off or unplug the printer from the computer while it prints the CD cover.
  • closeInformation in this article applies to HP Photosmart Essential 3.5. Procedures may vary slightly or significantly with other versions or products.
Ads
CD/DVD Label Software
Download free software to create CD and DVD labels on Windows or a Mac
NCH Software
Start Download
Microsoft™ 64/32 Bit Driver Download Driver Support™ Free Scan
Driver Support.
plus you could read up some more at this link if the above does not work for you.
How to print cd covers with HP Photosmart Essential 3 5 Google Search
Dec 15, 2017 | HP DeskJet F4280 All In One Printer InkJet
Can i print on printable dvds on this printer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Print CDs
1. Open HP Photosmart Essential 3.5 software.
2. Select Create option.
3. Select Disc Labels option.
4. Select Print directly on Disc option.
5. Choose the Mini CD.
6. Select Choose this format option.
7. Choose the appropriate Design and Photo you want.
8. Click on Create.
9. Under Settings option, select the appropriate printer and Media type.
10. Under Printable Area option, select Standard/Print to hub option from the drop down list under Standard Sizes.
11. Click on Print button.
Jan 25, 2009 | HP Photosmart C5180 All-In-One InkJet...
Page size for CD printing
I think that the CD/DVD printing ability depends on the software that epson bundles with the printer.
I had the EPSON R200 and i could only print CD's from the EPSON PrintCD software.
May 04, 2008 | Epson Stylus Photo R260 InkJet Printer
Dvd and cd printing
This is an easy fix by creating your own template....choose program "cd-labelprint" >> file >> select paper >> new >> (select a name to save as) (select diameter sizes etc) >> OK.
Dec 13, 2007 | Canon MP610 Photo All-In-One Printer
Anoterh Vertical Line Problem!
So many questions Vertical lines suggest [you do mean vertical do you - up/and down?] is new one to me try www.fixyourownprinter.com Printing CD's is not a 2200 thing, it is the province of the R series. Printing lables is easy purchase CD labels and suitable CD print software - A kit including labels software and label applicator is available at many computer stores Other labels- download the Avery-Dennison free lable software.
Aug 01, 2007 | Epson Stylus 2200 InkJet Photo Printer
Canon PIXMA MX310 All-In-One Printer Logo
old marine
old marine
