No black ink on colour prints very light on paper FADED? trid allsystems? would like to be talked thourgh fault not good at following trouble shooting? CLEAND ALL MLOORE THAN ONCE AND CHANGED BLACK INKS
  • 165 Answers
It is because of your ribon complaint change your ribon.
it is better u to go to aithorised service centre
Posted on Sep 29, 2009
Testimonial: "I will take your advise and get back to you thanks"
Anything I print looks really faded.
Did you clean the print heads and/or re-calibrate the printer after installling the new ink. It is possible, however, to have gotten a faulty cartridge.
Hope this helps
Randy
Aug 31, 2012 | Canon PIXMA MP160 All-In-One InkJet...
Print is very faded and more brown than black. Cartrige seems ok and indicator does not light for low ink.
i think it means for black print it use colour cartridge
first check ur black one
another if in printer properties there is check on high quality print then it also use colour cartridge for that
Aug 05, 2011 | Office Equipment & Supplies
HP2600n - red prints faded and very faded on the left hand side. All other colours are OK
make sure the all colour are one brand. if yes, change the rad one,
to be more confident you change with the cartridge,
but I m sure that is not solid ink liquid with "paper" and other ink,
sometime the kind of paper can be influential,
May 11, 2011 | HP Color LaserJet 2600n Printer
Please help with my problem. I recently printed a report and the paper got stuck. I managed to remove the paper jam but have since had problems with the pages coming out blank. I left it over the weekend...
A peace of paper is proberly still caught inside the machine.
proberly under the carriage unit that houses the cartridges.
Open the printer and see if you can find any peaces of paper that could
be causing the fault
Feb 14, 2011 | Office Equipment & Supplies
Black ink started to print blue/mauve
Many thanks for the suggestions received. Have been told by HP to
change the black printhead - which has solved the problem!
Dec 22, 2009 | HP Designjet 110plus nr InkJet Printer
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Black ink printing
black developer rollers need replacing.common fault.
Aug 06, 2009 | Samsung CLX 3160fn All-In-One Printer
Black colour ?
Thats because it's using the other colours to mix what it thinks to be shades of grey. Due to the black ink being pigment based and the colours inks dye base, when printing onto glossy paper the machine will use the colour dye based inks to make up black.
If you were to print on plain paper, set to greyscale, then the machine will just use the black as the pigment ink sits onto of the plain paper and will not run should the paper get wet.  With glossy paper the ink has to be absorbed into the paper ad the Black pigment ink will not do this so the machine will use the coloured inks.
Sucks but true.
Aug 06, 2008 | Lexmark X3480 All-In-One Printer
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Colour faded
Hi Desperate for help I had a similar trouble with my printer it turned out that when I bought a replacement ink tank they gave me a photo quality cartridge and you can't mix them you need all photo quality or all plain cartridges check for that hope this helps
Jan 12, 2007 | Canon PIXMA MP760 All-In-One InkJet...
102 people viewed this question
k24674
