Question about Sony BRAVIA KLV-32U100M 32 in. LCD Television
The screeen has gone black. The TV is only 2
The screeen has gone black. The TV is only 2 years old.
    New Friend:
  • 35 Answers
Check the U24 (CPU reset IC) on the "A" board. It may be burned. If you have a DVM (voltmeter) check for 3.3V across SW1 connections near this device. If you don't have 3.3V, U24 is bad. This part is not available from Sony. The TV may work if you just remove U24 from the board. I posted this fix on Agoraquest also, you can read more there (I'm "Roundabout" on that forum). Hope that helps.
Posted on Jun 25, 2010
  • 229 Answers
Can someone put the link of service manual ?
Posted on Mar 11, 2010
  • 11,361 Answers
The backlight inverter board may ahve gone out, or the power supply is not suppliyng 24vdc for the inverter board.
Posted on Nov 01, 2009
TV was working fine and then the picture has totally gone, just a Black screen as though it is switched off, Audio on all channels are fine and turns over as normal. No Text no nothing on the screen...
solution
step 1 : at first test your fly back transformer
step 2 : A.C. transformer test
step 3: adjust TV yoke coil
Send report :babul_jpi90@yahoo.com
Jul 28, 2011 | LG 50PS60 50 in. Plasma HDTV
My LG 42Lc7D tv just made a pop noise and then went back. The tv didn't turn off, it is like a more lit black screen. I unplug it and plug it back in, it works again for a few seconds and then it all...
This means that the lamp for the tv has gone out. This is replaceable but it is in the $200-300 range plus labor. If it is under 2 years old it should still be covered under warranty for this problem.
Mar 08, 2011 | Televison & Video
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Samsung TX-R3080WH, tv is less than 2 years old and the picture is too dark to see it. some channels, you can "make out" a picture, but for the most part, channels are black. but you can still hear it.
not sure about this model but it sounds like the backlight has gone out. You can call samsung at 1-800-samsung and they may be able to help or give you the # of the nearest service center.
Dec 08, 2009 | Samsung TX-R3080WH 30" TV
Picture went black
The backlight inverter board may have gone out, or the power supply for the inverter may have gone out. If it is two years old, you should look at the power supply first for bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find. What is themodel number anyway?
Nov 12, 2009 | Televison & Video
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
Flm-3201
Sounds like the back light is out, and the unit needs servicing. You can check this by shining a flashlight close to the surface, and if some image is seen, the the back light is the cause. Else the LCD driver is gone.
Aug 03, 2008 | Polaroid FLM-3201 Television
Monitor is on but disply id black
Having a similar problem.  When I turn my monitor on, the picture tries to come on, but then goes black.  After several times, I may get lucky and the picture will hold.  Is my monitor about ready to give up the ghost?  Mine is a few years old as well.
Jun 22, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
Color is gone in a sony kv-c2963e trinitron tv
as you say that color came back for 15 minutes then went off. this is a clear indication that there is a loose contact or pcb crack somewhere in color section only. if that happens to be ok then check 1 antena or cable socket loose 2 loose connector in color section 3 print open or crack near chroma signal processor. 4 loose near color control. 5 chroma ic night be defective. if you are not tech person take the help of tech.person.
Oct 01, 2007 | Televison & Video
Black square in the middle of the picture
You have the set configured to display "text 1 or Text 2" in the closed captioning menu. You will need to turn closed captioning off to get rid of this box.
Jan 13, 2007 | Craig CTV-41904 19" TV
Sony BRAVIA KLV-32U100M 32 in. LCD Television Logo
227 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
