Question about Whirlpool LGR7646E Dryer
The timer seems to not work only on the auto sensing (left) side. It does not move forward. On the timed dry, its fine. I'm thinking a piece in the timer assy is bad. Is there anything else that can go bad?
  • Whirlpool Master
  • 3,361 Answers
The auto dry sensor in the dryer could be bad or the wire to the auto dry sensor may have come loose. If these parts are OK and you are getting heat in auto dry then yes,it would be the timer.
Posted on Sep 29, 2009
My roper dryer works fine, it heats and the timer advances, it just wont shut off at the the end of a timed dry or auto dry. What do you think?
A timed drying cycle uses the timer alone to stop the drying cycle. Once it times out like an egg timer a set of contacts open up shutting off the dryer. Or a set of contacts closes to activate a relay which in turn shuts off the power.
Auto dry usually uses a moisture sensor which would do the same thing as the timer. Once it doesnt sense moisture in the load for a predetermined time it in turn triggers a relay which shuts the power off. Some auto dry cycles just use the timer alone and guess-timate the drying time by the selection.
If yours does not use a moisture sensor then most likely it is your timer/cycle switch. There may or may not be a relay involved.
Most dryers have a basic wiring diagram on the inside somewhere on one of the panels which will help.
Since yours is acting up on both cycles Im guessing you have a bad relay or connection to that relay somewhere IF it uses a moisture sensor.
Dec 17, 2014 | Roper Dryers
Dryer will not stop when clothes are dry in auto-sense mode
Try "timed" cycles. If it shuts off on timed it's not the timer. It's more likely it's not cycling on the thermostat due to an airflow problem like the vent. To rule that out (or in) run ONE load through it with the vent disconnected. If it shuts off you'll know where to look
May 03, 2014 | Admiral AED4475TQ
Whirlpool gas dryer (WGD9450WR1) not drying on auto-cycles
try cleaning the 2 silver senser bars located inside the dryer drum on the door side with isopropyl alcohol and lint free wipes,these bars sense moisture and control timer speed,and when they get coated with the chemicals in dryer sheets they become coated and can no longer sense the damp clothes (these sensers use capacitance to sense moisture)
Feb 18, 2012 | Dryers
Amana lga30aw. dryer starts in auto mode, pilot on, gas on, goes off after awhile and never comes back on. timer does not move in auto but does move on the timed mode (still does not dry in the timed...
You may need to replace the timer, but watch the video below and it will walk you thru the troubleshooting process. The timer not moving in the "auto sense" mode maybe due to a bad thermostat. Here is a link to the timer in case you need it.
Jan 05, 2011 | Amana ALG331RAW Gas Dryer
I have a Whirlpool Estate dryer Model TGDS840PQ0. During auto sense, the timer will not move. But during a "time dry" session, the timer seemse to work just fine. Any ideas?
in auto the timer will not move if there is no heat,when the heat stops the timer moves,heat comes on timer doesn't move,when it's on auto make sure power is going down to the heating system,next time send model number and if it's gas or electric,good luck
Jan 27, 2010 | Kenmore 63942 Dryer
Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
Apr 10, 2009 | Roper REX4634KQ Electric Dryer
Need to reset Timer...need help
Hi Dawn,
I'll ask the obvious question, Does the engine start and run every Thursday at 2:30pm (more or less) or not?
What I see in the field is that people notice the TOD clock on the timer is incorrect due to DST changeover and make a boo-boo while trying to correct it. You seem to have the right idea above so it's better to observe and see if the thing operates like we want rather than fix what might not be broken :-)
Generally speaking...
Generators have 3 switch positions, Off, Auto, and Manual. I think that's the switch on the left side of the panel you mention.
Timers have a Program, Run, and sometimes Override mode of operation. This would be that switch on the right side of the panel above. When in the "Run" mode almost all timers display the current Time Of Day somewhere, many blink the colons in the display to indicate that something is happening.
Let me know if you need further help,
Carl
Mar 19, 2009 | Winco 200-Amp Automatic Transfer Switch -...
Gas Dryer runs non-stop.
Repairing a dryer that won't shut off many seem daunting, but fixing your own appliance is actually pretty easy. The toughest part is figuring out what dryer part is the problem. We've created a list of the most common parts that can cause a dryer to not shut off. Use this list to diagnose the problem you're having and then enter your model number into the search box to find the right part for you. You'll also be able to access even more detailed repair help and tips about your dryer.https://www.youtube.com/watch?v=rXs6cL_prAQ
Mar 16, 2017 | Whirlpool Dryers
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
301 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
