Question about Whirlpool AWM8000 Front Load Washer
AWM8000 AF flashing and machine cut out, very
AWM8000 AF flashing and machine cuts out, very little water enters washer, sounds as if it is pumping out, aquastop is also flashing
WHEN I PRESS START - HAS ALARM ON DISPLAY F AND H FLASHING AND TAP OPEN POSTER HAS THE FLASHING LED TOO. HO TO REPAIR IT.
MY NAME XUAN
Posted on Oct 04, 2009
LG Fuzzy logic 6.5kg WF-T7519PV washing machine.Sensor panel error PE where E is flashing indication with sound.
This PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch. If no water is going into the machine, check the water inlet valve operation.
Apr 24, 2017 | LG Washing Machines
Whirlpool awm8000 will not start
tengo una lavadora wirpool modelo AWM 8000 la pongo en funcionamiento y se enciende y apaga sola con lo cual el programa no camina
Nov 03, 2012 | Whirlpool AWM8000 Front Load Washer
The water won't cut off inside our whdse820 GE washer. I've stopped the cycle and cut off the water. Little help?
the water valve solenoid on the rear apron that opens the water valves electrically to fill the washer is bad and is not closing to shut water off
Oct 23, 2010 | GE WWSE5200B Top Load Washer
Stoping under process on every step from begning to ending
its very common for front load washers to have the water pump to freeze up.
ever washed something with sand or little rocks or rubber bands?
flip the washer to the side, then locate the water pump. take the filter and the hoses around the water pump. sometimes the water pump too, to make sure that the fins on the water pump are free and not stuck. put everything together and try the cycle. when the water pump is stuck it will cause the error and will not go into the spin cycle.
Aug 14, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
I am trying to take the drain pump off of my washer and it seems to be stuck. how do i get it off?
the motor shaft is rusted causing the plastic pump to be stuck. you might have to cut thru the center of the pump with a chisel or flat screwdriver. once you get the pump off then you will have to grind the motor shaft down a little before installing a new pump. if the new pump doesnt just slide on and off easily then dont force it.
  • cut the center of the water pump where you see the red circle. cut all the way to the motor shaft.
Aug 08, 2008 | Whirlpool Washing Machines
Program problems
please check you drain filter, situated @ bottm of appliance. if ok i think you may have a pcb fault and you need an engineer
Jul 14, 2007 | Indesit W 123 Front Load Washer
Whirlpool AWM8000 Front Load Washer Logo
416 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
