Question about Fisher Paykel EcoSmart GWL15
Water pump i live in NY and can't find parts to fix mechine
    President:
  • Fisher Master
  • 2,651 Answers
Call fisherpaykel themselves or the dealer where you purchased, either of them will give you an authorized servicer
Posted on Feb 22, 2008
How to unblock pump
the pump is usely held in with 2 screws at bottom of mechine a circlip from the sump hose and one on outlet hose photograph the pump on its side and remove the 3 or 4 screws around the edge of pump or clean via the inlet and outlet holes.after removel ps has only 2 wires to it ie live and neutral.
Jun 28, 2014 | Tricity Bendix Washing Machines
No water flow through system, checked tip, water was on, nozzle on, checked filter. motor starts and runs fine.
The first thing you need to check is if you have the water supply hocked to the mechine with no pressure line connected just the water dose it spray out the pressure line connecter with out the engine running . If this dosen't happen the water pump is no good . You can never start any kind of mechine like this with out constant water flow . It sounds like something is broken between the engine shaft and the pump the pump is likely seized and this broke the connection between the engine and the pump. If this is the case the mechine is likely not worth the money you would have to put into it to save it
Sep 17, 2011 | Honda Garden
I just got a refurbished pressure washer and after a week of it working i went to use it today and it works there is just no pressure from the knozzle can u help ?
Im not sure you have replaced on the mechine and you say it worked for a weak so it sounds like a new problem . But i owen a few powerwashers and wash houses as part of my bussiness. The most likely things that will stop the pressure are eighter the valves in the water pump witch under the caps on the pump the cages are sometimes made out of plastic and peices of the cage can break of and stop the valve to not seal all it takes is one of them but if you remove the peice the mechine will work again . However it could be what is called the unloader valve . This is a valve located under the water pressure control knob it adjusts the pressure at the tip but also allows the water inside the water pump to recurilate in side the pump when the trigger is not pulled so the mechine won't over build inside the pump if its stuck in recuriculate you will have no pressure at the tip . Most of the unloader are not rebuildable but i fine if you remove them and turn the knob while spraying WD40 into them most of the time you can free them by turning the pressure control knob You have to play with it good luck
May 23, 2011 | Garden
2004 trailblazer leaking water pump, live in NY and its cold now isthis something i should fix right away or i can wait until spring
I speak from experience: changing the water pump on a Trailblazer yourself is very involved---much of the front fascia of the vehicle will have to be removed as there is almost no clearance. In cold climes, I would DEFINITELY have a leaking water pump repaired right away.
Feb 13, 2010 | 2004 Chevrolet TrailBlazer
Fisher Paykel EcoSmart GWL15 Logo
47 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
