Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
RETUNE DMR-EX77 HOW TO - Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
    President:
  • 1,653 Answers
Download and follow the instructions from the following link
http://tvretune.co.uk/uploads/pdfs/Panasonic_DMR-EZ25_retune.pdf
Posted on Oct 02, 2009
  • Karl Wright
    Karl Wright Oct 03, 2009
    You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
    http://www.freeview.co.uk/_retuneinfo/
    If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
    For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
    For specific model information visit
    http://tvretune.co.uk/productmanuals
I want to be able to record on my DMR EX77 from another DVD player. cant locate how to do this. Thanks
Hello, maybe you can try to copy your DVD and backup on your DMR EX77. And in this process you may need a DVD Copy. Hope this idea can help!
Leawo DVD Copy Software Clone Copy DVD movie to DVD RW disc or hard drive...
Aug 30, 2016 | Televison & Video
My panasonic dmr ex77 is not multi region. How can i make it so?
The procedure below is a hack , can interfere with the normal working of the DVD player
*** Please note *** You will need a laptop with an Infrared (IR) port to use this method.
Most modern laptops have now dispensed with IR ports in favour of WiFi and Bluetooth, so you may need to forage around and find an older laptop with IR.
1) Download both parts of Chachi's RAR file (both of these files can be easily found on this forum).
You will need both files, as the ISO image file has been split across two compressed files.
2) Using WinRAR or WinZip unpack the ISO image file to a folder on your hard disk (the desktop is a good place, so you can easily find it later).
To successfully unpack the ISO image file, both of Chachi's RAR files must reside in the same folder.
As you extract the ISO file from the first archive, WinRAR or WinZip will automatically move to the second file and continue the unpacking process.
After the unpacking process has completed you will be left with a single file with the extension ISO.
3) Using Nero (or similar), use the "Burn Image to Disk" feature to burn the ISO CD image onto a blank CD (just copying the ISO image file onto a CD will not work).
I used Nero to achieve this, but most CD burning software can do the same.
4) On the laptop, ensure that the IR port is set to COM2 in the BIOS (note the original settings, so you can put them back after you have reprogrammed DMR-EX77).
Try to select an older IR mode if available.
My old Toshiba Satellite 4030CDT only supported FAST IR modes and wouldn't work.
I then switched to an Acer Aspire 2000 and through trial and error found the "IrDA (HPSIR)" mode worked perfectly.
5) Boot the laptop from the CD
If your laptop does not give you the option to change the boot drive order at POST, you may need to temporarily change your boot drive order in the BIOS (note the original settings, so you can put them back after you have reprogrammed DMR-EX77).
6) When the laptop has sucessfully booted from the CD you will be presented with a menu.
Using the down cursor key, select option "4. Minimal Boot" and press return.
7) At the "A:\>" prompt type "cd winamp" and press return.
8) At the next prompt "A:\>WINAMP\" type "winsamp" and press return.
9) The Remote control test tool should now be loaded (blue screen with white text).
10) Press the "r" key to load in the REMOTE.TXT file (this file contains the IR signal information required to reprogram your DMR-EX77).
11) The captions "button 1" to "button 10" near the bottom of the screen will now have changed from white to pink.
These are the emulated buttons you will need to press in order to unlock you unit.
Ensure "button 1" is highlighted before proceeding to the next step.
12) Power on your DMR-EX77 and switch it to DVD mode.
You must ensure the disk tray is empty during this process.
I had my disk tray empty and ejected (sticking out) during the process just as a precaution.
13) Point the IR port on your laptop at the IR receiver on your DMR-EX77.
The IR port on the DMR-EX77 is located just above the DVD/CD Open/Close button on the right of the unit.
I found the optimum distance between the laptop and the infrared receiver on the DMR-EX77 was approximately 5~6 centimetres, any more and it may not work.
14) With the IR ports aligned and "button 1" highlighted in pink press the return key on the laptop, wait a moment, cursor right to "button 2" and press the return key, wait a moment, cursor right to "button 3" etc....
Keep repeating this procedure until you have entered all buttons highlighted in pink from 1 to 10 in order.
If your DMR-EX77 reacts as mine did during the process you may see the display on the DMR-EX77 change and also experience the TV channel changing.
Don't panic as this appears to be quite normal during the unlocking process.
15) If all has gone well the display on the DMR-EX77 should now read "HELLO" and you should hear the hard disk spin down for a second, then spin up again.
The DMR-EX77 has new reset itself and has successfully been reprogrammed.
Leave the unit alone for approximately 10~15 seconds before doing anything else, just to be on the safe side.
16) The buttons on the front of the DMR-EX77 unit will no longer function, so switch the DMR-EX77 off using the remote control.
If you left the tray poking out during the reprogramming process (as I did), just wait a few seconds and it will close automatically, you can then switch off the DMR-EX77 using the remote.
There is no need to disconnect the DMR-EX77 from the mains supply.
17) Switch the unit back on, pop in any region DVD you like, sit back and enjoy biggrin.gif
Switch off your DMR-EX77 using the power button and leave it off for a few seconds.
Switch back on your DMR-EX77 and when it's ready try the proceedure again.
I failed several times initially, but it didn't seem to do any harm and everything is fine.
You may also find that changing the IR mode setting in your laptops BIOS may help.
I had to try a few different modes until I found one that worked.
If you can't find the files you need, or require the procedure for using another type of device to region free your DMR-EX77, then visit:
http://www.dcevolution.net/panasonic...tpage&Itemid=1 user_offline.gif
Apr 22, 2008 | Televison & Video
Panasonic DVD recorder won't recognize any disk inserted in tray
I am just wondering if you found the solution to this problem as it has happened to ours.
Regards
Oct 11, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
WE HAVE LOST THE INSTRUCTIONS
You can get the full instructions here
http://tv.manualsonline.com/manuals/mfg/panasonic/dmrex77_dmrex87.html
That is the whole booklet. Please let me know if you have any problems
Jan 10, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I have a Panasonic DMR EX77 PVR. Two days ago the Electronic Programme Guide stopped working and was replaced by the message "No Data". Is this a unit failure or just a temporary problem with the...
It must be no coincidence that our Panasonic DMR EX768 has done exactly the same exactly 2 years later i.e. on the weekend the clocks go back. We intend to reset the time & see if that solves the probelm
Oct 30, 2008 | Panasonic Televison & Video
Making my Panasonic DMR EX77 multi zone
i have the same player and wont play burned dvds
Sep 05, 2008 | Televison & Video
Panasonic DVD recorder DMR-EX77 - suddenly unable to play DIVX
It's actually a fault on the device that needs to be repaired.
Jul 15, 2008 | Televison & Video
Multi region code for DVD
You need to hack the dvd reinstalled firmware, I can see if I find hacked firmware for your dvd
May 01, 2008 | Onkyo DV-CP704 DVD Player
How do I flash the firmware for a Panasonic DMR-EZ47V?
According to the Engineering channel schudle there is a new firmware (v.1.13)for the following panasonic models
DMR-EZ27, DMR-EZ47, DMR-EX77, DMR-EX87
This is scheduled to be broadcast on 6-2-08.
http://www.dtg.org.uk/retailer/download_schedule.pl user_offline.gif
Jan 31, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
676 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
