Question about Samsung TX-T2793H TV
Samsung version st01 (the audio output don't work)
(the audio output don't work)in fact none of the RCA plug ins work
2 Suggested Answers
lovejoy91
  • 691 Answers
SOURCE: The video on samsung Pn50b650s1f plasma TV is out
First turn off game mode if on if not fixed afterward then look for upgrade on firmware.
Posted on Dec 28, 2010
Connect a CD player to LF320EM4A
Hi, plug red and white rca connectors from cd player to audio in - rear of tv.
Feb 02, 2015 | Emerson Televison & Video
Samsung LN-T4671F HDMI PC hookup and Audio Problems
Pls bear with me, have you tried not using the HDMI/DVI cable but simple straight connection PC > Standard 15 pin VGA cable and audio cable that has "stereo mini-plug" on both ends to the PC IN of the Samsung?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Samsung LN-T4671F 46 in. LCD Television
For audio from my samsung led tv to my samsung av receiver must i use an optical cable connection?
There should be setting menu on tv whereby you can select RCA or optical.samsung units have automatic selectivity when you use optical cables so they will gives instant output when switched on....make sure you pull off the plastic ends covers ,they only go in one way into the connection ports.if you only have RCA leads you may have to set up the output audio on tv menu.
Jan 19, 2015 | RCA Audio Players & Recorders
Dont have my manual. i can't get am reception and it was good before. am reception is fine. also have a new lg led tv and the only audio coming out of the tv is an optic one, my onkyo tx-8511 does not have...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-8511-Receivers-manual/id/365ci176/t/2/
As far as the TV audio goes... unless it is the primary source of the audio (tuned through its own antenna and available no where else) why don't you just run the actual primary source's (cable/sat, whatever) best digital audio straight to the Onkyo and skip the middleman that adds nothing to it but expensive unnecessary cable hops.
I'd also run each video sources absolute best video straight to the TV for the same reason.
Apr 15, 2011 | Onkyo TX-8511 Receiver
No analog comming out of receiver when optical input is used .
as a rule...in order to get analog audio out of a receiver, it must have an analog input. you could use a digital to analog converter between the tv and stereo or come out of both of your source devices (ps3, cable) with analog to the receiver. good luck
Feb 10, 2010 | Yamaha HTR-5740 Receiver
Cant get sound from speakers
That is because you didn't have the audio input connection right.
1. HDMI cable going from the Samsung tx72 output to Your Samsung TV HDMI input 2.
2. Non HD directv box Left and right audio output should be connected directly to the Samsung DVD receiver under Satellite input.Select"Satellite"for the sound from your Samsung tx72.You are good to go!
Joe
Feb 03, 2008 | Audio Players & Recorders
No audio
yeah sometimes we all get fustrated with stuff like that, the trick is not to hit the thing with a hammer,,
any way ensure that yougot the cables connected propperly in the L/R audio output from the dvd player (RED AND WHITE its alo labeled) and connect it to the in in the tv..
check your player settings (audio settings and and check your tv audio settings to ensure they match) some HDTV's only use 5.1 or higher
if your dvd remote got a volume controll on it ensure the u\volume is all the way up and that it isnt muted.
try your player on a next tv to ensure its working , if it is the problem is with your settings as stated above
Jan 05, 2008 | RCA RC5510P DVD Player
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Samsung TX-T2793H TV Logo
168 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
