2001 Oldsmobile Alero Logo
Posted on Sep 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I take off a headrest, so I can put on seatcovers
Anonymous
Level 3:
  • Master 1,986 Answers
  • Posted on Sep 29, 2009
Anonymous
Master
Level 3:
Answers
1986
Questions
0
Helped
1298140
Points
14923
On your headrest, there will either be a push button that you can push to release the headrest, or on some models, there's actually a tiny hole that you will need to push something like a paperclip into to release the headrest
4 Related Answers
Anonymous
  • 716 Answers
  • Posted on Jan 05, 2009
SOURCE: cannot remove front seat headrest, 2001 Saab 9-3
There Is A Button At The Bottom Of One Of The Silver Posts Hold It The Whole Time You Are Lifting The Headrest Out. The Little Button Is Almost Always Grey Plastic.
Anonymous
  • 36 Answers
  • Posted on Jun 10, 2009
SOURCE: headrest removal
Usea small flat screwdriverand run down along side the inside of the headrest rod. You will unclip 1 side and the rod will release. Do the same on the other and the headrest will come off. When you want to put back on just install and push down. Follow same procedure when you want to remove again. It is a little touchy but as soom as you remove 1 you will become a expert. I have done hundreds of those in the past couple years.
Rich Florenzen
  • 333 Answers
  • Posted on May 08, 2010
SOURCE: How do I remove the headrest from the front seats
there should be a button you push in under the headrest on the top of the seat
Anonymous
  • 410 Answers
  • Posted on Dec 05, 2010
SOURCE: I want to install a
If there is no button on side or in back, you just have to pry it straight up with a padded strong flat tool.
IHow do I remove front headrest in my 2002 Mercury Mountaineer to install a seatcover
Most headrests have a spring clip as the safety latch. If there is no visible push button there will be a hidden release latch. Carefully examine both plastic caps the headrest posts sit in. Look for a pin hole. If there is no pin hole the caps are 'push on' covers. They should lever off and reveal either a push button or a pin hole.
With the pin hole, insert an unfolded paper clip to release the locking spring.
How do I remove the frontseat headrests?
There is a button location underneath the headrest. Lift headrest as high as possible, feel for the button, press and continue to lift up.
How do I remove the headrest on my 2002 silverado to install seatcover
Pull the head rest up and look at the bottom of both shafts for small holes. Put a paper clip or something a little stronger into the holes to depress the locking tabs while lifting up on the head rest at the same time.
I need to remove the headrests to install seatcovers on my 1998 Cutlass Supreme
Sorry I don't know this exact model, so if this does not help please post again.
Look at the base where the bars go into the seat, around the bases will be a button or what looks like a button on the base, you either push this in, now if it does not push in then it's usually a clip thet needs to come out.
Look at both bases, carefully for a spot where a small notch is, this is so the plastic clip can be pulled out so the headrest can be pulled out.
So try pushing in on the spot that looks like it has a seam around a button, or you pull it out.
1helpful
How to remove headrest on 2006 sebring
Just removed them on a 2005 Sebring sedan. Easier with two people but one can manage just fine. The trick is a tiny hole in the plastic "sleeves" that the metal posts on the headrest slide into. You'll need a small poking device-Allen wrench, drill bit, tiny screw driver, whatever. The hole is on the right side of the right side sleeve on each headrest (as you're sitting in the back seat facing forward) and is perpendicular to the direction the metal rods go into the sleeves. Insert your small poker and depress the plastic button on the other plastic sleeve simultaneously while your helper pulls up on the headrest.
I want to install a seatcover so I need to get the headrest off, how do I remove the headrest?
4helpful
2answers
How do I remove the headrest from the front seats so that I can put seatcovers?
Cannot remove front seat headrest, 2001 Saab 9-3
2helpful
2answers
Headrest removal
Look at the top of ur seat, between the two shafts of ur headrest. Beside one of the posts is a black plastic base on which one side has a button u push. That allows u to remove the headrest. U might have to jimmy side to side a bit as they are somewhat hard to remove at times, just do so with ur finger pushing the release mechanism.
4helpful
Headrest removal
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you an Oldsmobile Expert? Answer questions, earn points and help others
