Question about Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range
I replaced the control unit and now the display shows LOCKED in the lower right corner. The door opens and the light comes on. The clock and timer work fine. I attempted to clear the locked condition as indicated in the manual, but I always get an F3 code and intermittant beeping. I replaced the new control unit with the old one (with a too dim temp display) and received the same LOCKED message.
  • 8 more comments
  • rboedecker Sep 29, 2009
    Ok, where is the oven temp sensor? Also, I did install a new control unit/clock.
    Where is the oven temp sensor?
    I have already replaced the control unit/clock.
    Ok, if the sensor checks out ok, and I need to check the wiring, can you refer me to the location of a wiring diagram for the RDSS30? If the wiring checks out ok as well, and I have installed a new control unit/clock, what's next? Thank you.
    Did you read the previous thread and the original issue report! The door is NOT locked. There are not dials on this oven. Please have someone respond to my last message who is paying attention.
  • rboedecker Sep 30, 2009
    Can you refer me to a location where I can get a wiring diagram for the oven?
    This is the same guidance that I received from the first posting several postings ago. Don't you guys read the whole thread. This is my last attempt to get the information that I need. Then I will request a refund.
    PLEASE TELL ME WHERE I CAN FIND THE WIRING DIAGRAM FOR THE OVEN.
    Our model is RDSS30. This diagram is impossible to read.
    Thank you for the efforts. Even in the larger view it is impossible to read the legend. According to the tab on the web site, the diagram is for an RDDS30 not RDSS30. Is the wiring the same? How can I get a diagram that I can read?
    Is it possible to get a copy of the manual?
    I have the impression that as my request was being passed from one person to another the thread was not being followed. This took much more back and forth than it should.
    President:
  • 1,462 Answers
F3 Open circuit detected; oven temperature sensor. C
Check sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F).
Check wires and connections between electronic range control (also called clock or ERC) and oven temperature sensor
Replace sensor if other components check normal. Replace electronic range control (also called clock or ERC) if fail code reoccurs
Please leave me comment, if yu need furthur assistance
RNJ VINODKUMAR
Posted on Sep 30, 2009
  • 11,896 Answers
OK........here's what you do. Find the main circuit breaker for your oven. Turn it off for fifteen minutes, then flip it back on. This should allow the door to open. Another thing sometimes, the dial for self clean will hang up, but the circuit breaker trick should fix it for you.
the temperature also needs to drop low enough to unlock (after cleaning cycle)
Posted on Sep 29, 2009
  • Nate Stansfield
    Nate Stansfield Sep 29, 2009
    There is a bad capacitor or resistor on your control board and it is not sending correct voltage currents and causing a system error. Otherwise you have a short or open circuit in your wiring to control board or door sensor.
  • 10,515 Answers
F3 code refers to - Open circuit detected; oven temperature sensor. Check sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check wires and connections between electronic range control (also called clock or ERC) and oven temperature sensor.
Solution - Replace sensor if other components check normal. Replace electronic range control (also called clock or ERC) if fail code reoccurs.
The above explanation is described as per Thermador!!
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Sep 29, 2009
    Thanks for your response!!
    Follow the below guide :-
    http://www.appliance411.com/links/jump.c...
    Hope i helped you.
How can I to set clock on Sanyo Microwave EM-C678
1. Open door
2. Press clock/Kitchen Timer button the display will show "0:00" with the hour"0" flashing.
3. Enter the correct hour by turning the potary dial. Enter 1-12
4. Press clock/Kitchen Timer button the display will show "0:00" with the minutes "00" flashing.
5. Enter the correct minutes by turning the potary dial. Enter 00-59
6. Press clock/Kitchen Timer. The colon will remain flashing.
7. Close the door.
Sep 03, 2014 | Microwave Ovens
Just bought my house and the porch light is controlled by Intermatic timer. Just noticed today that my porch is light is on constant. Replaced the battery in the timer. I was able to set the time and...
Don't forget to reset timer after replacing battery:
Copy following link to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If timer does not function after reset, then buy new timer
EJ500 is rated incandescent bulbs only
Gene
h
Oct 05, 2013 | Intermatic Inc. EJ500C Digital Wall Switch...
TRAX single channel hot water 7 day 14 settings programmer instructions missing
1) Thank you for description:
Copy following links to identify possible match for TRAX timer, and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TRAX
http://waterheatertimer.org/GE-timers-and-manuals.html#DIGI
2) Add comment March 2013 and say how closely this information matches your timer. Attach image.
Mar 10, 2013 | Hardware & Accessories
This range was set for self clean. When i returned home the digital display was not on, the oven was locked, I turned on the top burners to see if they were working, they are. I tried disconnecting power...
their is a thermal fuse between the power and the main clock/timer ......find the wiring diagram ...it will be located in a small brown enevelope ....either on back../or where the range drawer.is ..remove it to look ..under either on right or left...this diagram will tell you the wire color /location on the clock/timer control..let me know an good luck.../joe/
Aug 31, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Oven Door panel is showing LOC position but can be opened and closed so not locked. Unable to use oven for cooking
What is the exact make and model of your oven? Unplug the power cord for one hour to reset the display
Mar 18, 2010 | Kitchen Ranges
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
After a power failure I am getting the code e1 f1 flashing on my display board and it will not go away.
q.gif Why is the display showing E"#"-F"#," for example, E1-F2?
Answer Is "PF" displayed on the control?
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Is the display showing E0-F5?
The Self-Cleaning latch may be interfering with the oven door causing the Self-Cleaning cycle not to work. If the oven door is open and will not lock, press Stop/Clear to clear the display, press and hold the door switch plunger (located in the upper-right corner of the oven front), and the door latch will unlock. If the oven door is closed and locked, press Stop/Clear to clear the display; apply pressure to the upper-right corner of the oven door, and the door will unlock.
Is the display showing E"#"-F"#," for example, E1-F2?
You will need to schedule service.
please do not forget to rate and comment about your experience today. Thank you
Sep 03, 2008 | Whirlpool Kitchen Ranges
Display shows nothing, microwave cuts off
You need a couple of cheap microswithes that the door latches hit when you close the door and a new control for your display problem which sharp has had a problem with
Oct 30, 2007 | Sharp R-1405 / R-140 Microwave Oven
Open Questions:
See all Thermador RDDS30 Dual Fuel (Electric and Gas) Questions
Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range Logo
435 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
