Question about Lexmark Optra S 1255 Laser Printer
922 service error message, what does this mean? Can I fix it myself?
  • 496 Answers
922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine.
Posted on Sep 29, 2009
Testimonial: "thanks! "
How do I fix my 922 print head error?
Hi Anonymous,
You may want to refer the below link and follow the steps posted by the Dell Rockstar Rick K which might help:
http://dell.to/1N5bzhZ
Note: Please refrain from posting a service tag in a public forum
Feb 28, 2015 | Dell Inspiron Computers & Internet
922 SERVICE FUSER ERROR
922 means the fuser did not reach operating tempture. most likely the bulb in the fuser has gone out. Depending on how old your printer is, the fuser could need either rebuilt or replaced.
Feb 23, 2012 | Lexmark T630 Laser Printer
922 service fuser error
  • 921 Fuser Error and 922 Fuser Error messages indicate that the fuser unit failed to reach the standby temperature.
    • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
    • If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
    • If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine.
    Nov 10, 2010 | Lexmark T522 Laser Printer
    I am getting a 922 service fuser error on my lexmark optra s 1855
    922 Fuser Error message indicates that the fuser unit failed to reach the standby temperature. This usually requires a service call but try to turn off the printer for 30 seconds before turning it back on to give the engine board a chance to reset. Make sure the printer is plugged in straight to the power outlet in the wall. Bypass any surge device or power strip as they can cause low amperage. If the problem continues or if the error appears every time the printer is powered on, you will probably need service on the machine.
    Aug 26, 2010 | Lexmark Optra S 1855 Laser Printer
    Error code 0502 hardware error on dell printer
    i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
    Feb 19, 2010 | Dell 922 All-In-One InkJet Printer
    I am getting a 922 Service Fuser Error what does that mean?
    a 922 error means that the ac circuit is open. this is the heat lamp circuit. a burned out bulb, blown thermal fuse, or pitted contacts will be the cause. replace the fuser and your back up and running
    Oct 06, 2009 | Lexmark Optra T610 Laser Printer
    Re: 4037 5e lexmark laser printer printer is showing 921 service what does this mean and how do i fix it
    Here's some info:
    Oct 16, 2008 | Lexmark Office Equipment & Supplies
    I have a Lexmark X422 It has a error message when I try to print anything. It says 922 service fuser error
    This means Fuser failed to reach
    The only answer is to replace the fuser, part number 56P0648 110 VOLTS, 56P0671 220 VOLTS.
    Please advise if you require instructions
    Aug 04, 2008 | Lexmark Office Equipment & Supplies
    Dell 922 All-in-one printer has message on printer saying head error
    can you provide the error message, depending on the error and if you want to attempt to repair it yourself? Printers are like computers these days you can almost replace it for the repair cost, but if you will provide a error code we can see what we can do.
    Dec 26, 2007 | Dell 922 All-In-One InkJet Printer
    Dell 922 "cover open" problem / error message
    I had that problem too.
    Unplug the printer.
    Hold the printer cover open while you plug in the printer.
    Then close the printer after it powers on.
    It worked for me.
    Dec 04, 2007 | Dell 922 All-In-One InkJet Printer
    Lexmark Optra S 1255 Laser Printer Logo
    402 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
