Question about Safe International Aquascape - Black Fish Safe Silicone Sealant For Water Garden & Pond Use
Our aquarium had a leak...so we had to strip all of the old silicon out and replace it with new. However I was unaware that some silicone can be harmful to fish. the ingriedients that were the the silicon bottle we used are: Aromatic Hydrocarbon, Thermoplastic Rubber, Hydrocarbon Resins (Proprietary) & VOC content is less than 350 grams/liter. Are any of the above ingredients harmful to fish?
  • 855 Answers
The silicone most be 100% silicone appropriate for aquarium use. If the sealant tube did not say this on the tube it is not safe for use in aquariums. They sell this type at pet stores that sell fish. Also make sure you use acetone to clean surface before applying sealant.
Posted on Sep 29, 2009
Fluorescent tube want light up completely
this is a very common thing to happen with fluorescent aquarium lights , moisture causes corrosion of contact points , corrosion causes loss of voltage in tube contacts , light does not receive the power it needs so doesn't light correctly , id retrofit a L.E.D light bar assembly right inside of your old hood held in place with some food safe silicone there avail off amazon for not a lot of money and some even give u the choice of colors as well
Feb 05, 2013 | Aqueon All-glass Aquarium Strip Lights
My glass aquarium cracked. How can I fix it?
There are a few steps to take to fix a cracked tank:
  1. 1. b>Move the fish to a backup tank with cleanwater
  2. 2. Wipe the crack with white vinegarto clean the glass and let it dry completely. This will allow the silicone tostick.
  3. 3. Line the crack withaqua-marine safe silicone gel
  4. 4. Let the gel dry completely(usually overnight) before returning the fish to the water
May 13, 2012 | Fish
My Bunn Coffee maker is leaking water from the bottom.
I had the same problem. On mine (and probably yours) the problem was the seal between the (upper) plastic water reservoir and the lower (metal) heating reservoir. No replacement seal is available.
I fixed mine by coating both sides of the old seal with aquarium grade clear silicone sealer - available at pet supply stores. Just a light (1/16") coating is all that's required. Carefully re-assemble and allow the sealer to cure for 24 hours.
I did that over a year ago, and it hasn't leaked a drop ever since.
Sep 25, 2011 | Bunn GR10 Coffee Maker
Water seal between the cold water tray and the heater unit is bad, where can I get a new silicon water seal
The seal is not available. I fixed mine by coating each side of the old seal with aquarium grade clear silicone sealer - about 1/16" thick.
Re-assemble and allow it to cure for 24 hours.
Jun 30, 2011 | Bunn GR10 Coffee Maker
99 dodge caravan 3.3lt leaking transmission fluid out of a rusty side pan. How difficult to replace/fix
even if you bought a new trans pan gasket it will still leak this is a easy repair get a new gasket and silicone (gasket making silicone) use bothe gasket and silicone that the only way you will stop a leaking pan gasket and yes its simple
Jun 08, 2011 | 1999 Dodge Grand Caravan
The (plastic? rubber?) trim strip running along the roof and body of the car appears to be loosening. During an overnight heavy rain it must have leaked on the left side since the driver's seat was...
Actually, your idea is very close to what the car dealership would do, but not tell you that's what they did. Just make sure you wipe the area(s) clean with rubbing alcohol and do not use any type of conditioner to the pieces that will have silicone placed around\under them as, this will prevent the silicone from making a proper seal and you could lose your rubber pieces going down the road.
Once you have put your silicone in and have put your rubber pieces back into their grooves, give the silicone 24 hours to set. This way, the bond is tighter and this should also fix your leaking issue.
Hope this helps.
Jul 13, 2017 | Scion xA Cars & Trucks
Oil pan replacement
No! Find the pan and remove all bolts holding it on. clean off old seal and silicone. After this keep the rubber parts to gasket and replace old gasket with a strip of RTV high temp silicone. (RED) any Q's just write.
Apr 14, 2009 | Nissan Sentra Cars & Trucks
Replace new moen 1200 stem, still leaks due to scratches housing
The proper fix for this is to hone out the scratches
take steel wool and wrap it around a dowel or piece of wood or ust stuff it into the housing and turn back and forth to smoth out the scratch
if the scratch is real dep you wll have to go to harbor freight and get a honing tol that fits on the end of a drill
the stem should have some type of crown washer that you should be able to get an assortment from lowes , ace or hd
If you are asing for a recommendation for a good silicone I always use GE silicone it is the best
as a last resort (if nothing else works to stop leak
I would take cartridge wall and streatch teflon tape as tight and smooth as possible to block water coming up between housing and
cartrideg this is not recomended by mfg just a spa (my initials) certified suggestion
Good luck
Jan 07, 2009 | Moen & Replacement Cartridge
Water leaking from A/C
ok this unit should have a silicone seal around the pan so water does not collect under it if old silicone is worn away scrape old silicone away and redo new silicone around unit so it sits properly make sure all the water is gone before sealing because you run the risk of mold build up under it; let it dry or help it dry thats up to you
but would like little more info on what this is on
May 07, 2008 | Coleman Mach 15 Air Conditioner
Safe International Aquascape - Black Fish Safe Silicone Sealant  For Water Garden & Pond Use Logo
102 people viewed this question
Top Safe International Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Safe International Garden Expert? Answer questions, earn points and help others
