Question about Tools & Hardware - Others
My Husky brand framing nail gun started leaking air out the exhaust port. After shootin a nail, it stops for a few seconds, then starts leaking again. This makes my air compressor work continuously. What is causing this and what do I do to repair it?
    President:
  • 583 Answers
Get it serviced you have o rings sticking and cracking
Posted on Sep 29, 2009
Why might my nail guns not work?
Have you lubricated either nail gun? If not, go to Home Depot and get a bottle of air tool oil. It's in tools by the compressors. Disconnect the air hose from the tool. Pour about a teaspoon of oil into the air inlet of the tool. Reconnect everything and try it 10-20 times with no nails in the tool. Then try it with nails. Good luck.
Sep 14, 2015 | Porter Cable Tools & Hardware - Others
Air comes out the nose of my dewalt framing nailer
Again sounds like blown O ring give it a squirt of 3in1 oil and fire it several times (if oil is compatible in your gun). Repair center if that doesn't work. Trash can also get in the air orifice and stop moving parts from moving.
Dec 07, 2013 | Dewalt Air Tools & Compressors
Dewalt D51844. Framing out a wall today and the gun worked fine on the first wall. I was starting the second wall and heard an air leak coming from the gun. Would not stop. Tried several things and...
Most all of my guns are senco and the head has the moving part for fire and reload,, controlling the driver piston. Multiple shots suggests a trigger problem. No water in system right.. Well Its all O rings little ones,, skinny ones,, fat ones etc. You can open it up and check, do the head first, I think.. Its fast a off and on
Jul 15, 2012 | Dewalt D51844 Framing Nailer
I have a N80SB stick nail gun that have been leaking air from the trigger valve but was still able to shoot nails. After 3 months of discontinued use, I plugged in the air hose and fire the first nail
A new trigger valve and o-ring kit will give you a like new gun. Just remember to replace all available o-rings in the kit, lightly grease all of them as you reassemble the gun and use pneumatic oil at the beginning of the day so you won't be doing it again in a couple months.
Feb 23, 2012 | Stanley Bostitch Stick Framing Nailer...
Hitachi 83a2 (s) framing nailer jamed, there are 2 nails in cylinder, not sure how to clear the chamber. .
1.Remove the air hose
2.Hold the nose down on a 2x4 on the ground. Make sure the safety guide is full depressed.
3.Squeeze the trigger.
(I realize that sounds redundant, but I have to insure your safety as much as possible. We at FixYa want you to be safe. A Framer Nailer can be dangerous if safety precautions aren't observed)
4.Pull the slide back, and grab around it with your hand, up against the back of the gun. (Magazine)
If you accidentally bump the latch lever, the slide won't spring forward, possibly causing you injury by using this method.
5.Remove any nails. Pull the plastic strip of nails out.
6.The method I use here is to rest the air chamber cover on a table. (Top of the gun) Nose AWAY from your face. I use a small flat tip screwdriver, and see if I can move the Driver back up into the gun. Then see if I can ease one nail out at a time, by moving the nail down out of the nose.
You have two nails trying to drive out at the same time. They need to be separated from each other, so that you can get one nail out at a time.
Most of the time this occurs because of lack of lube. The gun is supposed to have 4 to 5 drops of pneumatic oil, added to the air hose inlet before starting the day out.
(Gun is faced so that the air inlet connection is straight up, oil is added, while the trigger is being squeezed in at the same time)
I don't rely on oilers in the air line. I think they're a bunch of hooey. I've had very few problems, when I have added oil manually at the start of the day.
Sometimes using those 'bargain' nails will cause a problem also. If you find a brand of nails that are cheap, this is the usual result.
Sometimes we framers are too fast on the trigger, and do not have the safety guide fully depressed, before firing the next 'shot'.
If you have further questions please post them.
Oct 10, 2009 | Hitachi NR83A2S Framing Nailer, Full Head,...
Can I change the pressure on the nail gun?
Hi there .
First check if the nail gun have a adjustment screw . Depending on the brand could be in the front where the nails comes out or by the trigger. Second check the compressor by the air hose connection you should have a regulator valve with a gauge and see if you getting the right air pressure .
Hope this help
Aug 29, 2009 | Air Tools & Compressors
Will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Jun 11, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
Tools & Hardware - Others Logo
649 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
