Question about Lexmark X5070 InkJet Printer
Scan message scan requested, then scan failed, same problem
2003 saturn L300 p1780
DTC P1780 (3.0L (L81))
To improve shift feel, the transmission control module (TCM) may request that the engine control module (ECM) reduce engine torque during shift events. When such a request is received, the ECM responds by retarding the base ignition timing and notifying the TCM that the request has succeeded. If the ECM is unable to comply with the request, the ECM sends the TCM a message that the request has failed.
The torque reduction request is sent to the ECM through a communication network called the controller area network (CAN). Two circuits are used to communicate CAN data between the ECM and TCM. A fault in the CAN will not cause DTC P1780 to set by itself. If a CAN fault occurs, other DTCs will set before DTC P1780.
When the TCM receives a torque reduction failure message from the ECM, then DTC P1780 will set. DTC P1780 is a type C DTC. Take your pick of which you think this code is for , this or the TSB - technical service bulletin. What need to hook up scan tool an data PID'S - Do you know what PID'S are ? sensor data read on a scan tool .
Mar 04, 2016 | 2003 Saturn L-Series
"Connection with Computer Failed" When I Try to Scan
If the primitive (as you call it) Windows Scan program is working then there is no problem with the machine. It can connect to the computer.
I suspect that the other (non primitive) scanning software is not configured correctly. It may be using a wrong driver. You may have installed some other device that is able to scan (such as a program that capture screens from calculators) and it has been set as default driver. Check the configuration of your scanning software.
Jan 23, 2014 | Lexmark OfficeEdge Pro5500 4-in-1 Inkjet...
I can't scan with my printer
try to remove the driver software and after a restart re-install the driver on the pc and see what happens.
Dec 08, 2009 | Dell 926 All-In-One InkJet Printer
Getting a message about shadowing my session
The program you are using is telling the terminal to accept a VNC request, as it will send date on the port open for VNC. So the terminal is asking you to accept the prompt to allow a remote machine to control your session.
You can set the program to ignore the VNC ports, so it wont get prompted. Failing that you should be able to change the terminals behavior to the requests by editing the wnos.ini to not allow VNC connections. I think that can be done from there. Check on the config generator for wyse terminals on technicalhelp.de to find the correct syntax.
Jun 23, 2009 | WYSE S10 (90210501) Network Terminal
Dell photo 926 wont scan
Replace the USB Cable to a new one 3.0
Jun 10, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 printer scanning problems
Go to Control Panel, then Programs and Features. Uninstall the Dell printer software.
Then, go to Control Panel, then Device Manager. Locate the printer, right click on it, and select uninstall.
Disconnect the printer from your PC.
Go to the Support section of Dell's web site, download the latest driver for your printer.
Restart your PC.
Install the software. Connect your printer when instructed to, or after the software install has completed.
Let me know if you still have issues :)
Apr 28, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell Photo AIO Printer 926 scanner
I want to scan pictures onto my computer to post them and when I push the scan button it says Requesting scan~ and then Scan request failed... Any ideas?
Mar 31, 2009 | Dell 962 Photo All-In-One InkJet Printer
Hp deskjet F2100 series scan fail
Okay, the driver for the scanner (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32\
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the scanner application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the scanner driver, and the problem will be fixed!
Mar 13, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
SCANNING WITH LEZMARK X4450
I gave gotten it to retrieve the applications list by opening Lexmark Imaging Studio while it was searching, I AM however still unable to scan it connects to my comp I tell it to save as a file and it goes "Requesting Scan" then "Scan Request Failed"
Jul 13, 2008 | Lexmark X4550 InkJet Printer
Lexmark X5070 InkJet Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
