Question about Dell E193FP 19" LCD Monitor
Won't Power On
My monitor is about 5 years old and won't power on. At first it was intermitent, now it's dead. I suspect a loose connection.
    Scholar:
  • 113 Answers
Check to see if the Power cord is connected on both ends.
If this doesn't work, then try a different power cable. Use one that you know works.
If that fails, i suggest you upgrade to a new monitor.
Posted on Sep 29, 2009
Testimonial: "That's what I figured. Thanks for confirming"
Won t start just clicks
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Harley Davidson Sportster error codes and how to access them
Jan 08, 2014 | Harley Davidson XL 1200 C Sportster Custom...
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
Blueparrrot B250 is 1 year old & it went dead so I
how do you know it is fully charged? i think it may be dead battery
Nov 06, 2012 | Computers & Internet
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
Won;t power up at all. New batteries but I did not replace back up battery. should I? Tried the contrast fix. Son said he dropped it and it got kicked down hall at school. One year old. Any hope?
If new batteries did not solve the problem, the next thing to check would be the battery terminal.
If the battery terminal is rusty, the battery power won't contact and the calculator won't turn on. So, use a flat small screw drive to scratch the battery terminal so that there would be contact.
If the above is not the problem, the next to check would be the wire connecting the battery terminal to the the calculator's main board. There is a wire between the battery terminal and the calculator board. When the battery is inserted, the power from the battery goes from the terminal to the board through this wire. There is a possibility that this wire is cut in-between or is loosing contact. In this case, you need to get a small screw driver and carefully disassemble the calculator in order to check the wire.
If the wire is intact, use a light brush to brush the calculator board as there might be dust on the board.
If non of the above helps, then it means the calculator is dead and needs a replacement.
Regards.
Sep 13, 2011 | Texas Instruments TI-84 Plus Calculator
My jazzy was sitting for a year, without battery charge. now, the batteries won't charge. what shoul i do?
I strongly suspect your batteries are dead. The unfortunate part is that the gel batteries used in power chairs will not usually take a charge after they are completely depleted. The only solution is to load test the batteries and replace BOTH of them even if only one tests bad. ( I think you'll find that both batteries are dead)
Sep 05, 2011 | Pride Mobility Products Jazzy Select
I have a1984 vf1100s v65 sabre i was riding along and lost power the bike continued to run on like half power then died completely. the following morning it did restart. i put a house hold electrical...
Hi, Mrklave and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, needs to be 12.5 volts or better and be able to pass a "LOAD" test, your battery may show 12.5 volts but has little or zero amps and must be replaced.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or CDI or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Magna 1984 V65 with no spark in all four spark plugs
Testing Honda Coils and CDI boxes
Honda VF1000F 1985 Shop Manual Page 2
http://www.partsfish.com/page/oem-parts-for-honda
http://www.cantonmg.com/stewsplace/ShopManualVF1100C.html
http://mybikemanuals.com/honda/honda-vf-owners-manuals
Apr 24, 2017 | 1984 Honda VF 1100 Sabre
I have a 5-year old Sony 19-LCD monitor that stopped working. The little power-on light does not come on, and their is no picture, but I do hear a faint buzzing from the back. Sounds like?
smyko, Sounds like a tired out old "switch-mode-power-supply"/ "inverter CCFL power-supply!!! May require unit to be REFURBISHED with upgraded power suppllies and if the LCD screen had been displaying an increasingly dimmer screen, it may also need new "cold cathode-fluorescent lamps" installed. A technician who knows all about LCD monitors and their backlight "ELECTRONIC BALLAST" circuits will need to evaluate it. Check with sony and find out if you can do a "cash+old unit swapout for a factory rebuilt (refurb) same model type. Before you do any of that have a look at youtube for longer video clips of "LCD monitor disassembly" and "LCD monitor repair" just FYI. You will then know and understand what is on the "OTHER SIDE" of what you been looking at for 5yrs!!! Yes, they are trying to experiment with WHITE led arrays that won"t fail for 10 years. Remember lcd Panels last 8 - 12 yrs. Hope this helps. Bye for now. 12fixlouie
Nov 17, 2009 | Sony SDM-HS93 19" LCD Monitor
Hd50lpw175x7
Ballast Verification Process
1. Short out door switch (SP001)
2. Apply AC power and wait till DM module boots
3. Press power switch and observe spark gap on ballast
4. If spark gap arcs, suspect Lamp. If color wheel starts but ballast won’t strike
lamp, go to next step.
5. Measure BP252 on AC IN CBA for +300Vdc. If missing check door switch, cable
from AC IN CBA to switch and AC IN PCB. If correct go to next step.
6. Monitor pin 2 of BT251 for Ballast ON command from Light Engine. If present
suspect Ballast. If missing suspect Light Engine. Pin 5 of BT251 starts at 3.3V
after power switch is pressed and drops to .18V when the Light Engine sends the
start command. No change on pin 5 indicates Light Engine is suspect, change
on pin 5 with no ballast start, ballast is suspect.
Note: Lamp may arc but not start. Pin 5 of BT251 is "LAMP LIT" and goes to 1.48V
when lamp is lit. If ballast strikes lamp but lamp won’t stay lit, suspect Lamp.
Jun 09, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Dell E193FP 19" LCD Monitor Logo
255 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
