Question about GE Profile Performance 25.2 cu. ft. Side-by-Side Refrigerator with Dispenser TFX25PPBWW
Do you know the exact dimensions of a GE Profie Performance side-by-side refrigerator Model No. TFX25PP? Thank you
SolutionGuy
  • 331 Answers
SOURCE: GE SIDE BY SIDE REFRIGERATOR
Kay, these are known for having faulty evaporator fan motors (failed motor bearings). This is what has failed in your fridge. This is a tedious and time consuming repair, you may want to purchase the evap motor and hire someone to install it for you. Just one of the reasons I recommend this is that 50% of the time, the new motor's wiring harness will not match the harness on the fridge and so must be converted to adapt. The evaporator fan motor is the fan inside the freezer, behind the back panels. If you choose to repair it yourself, UNPLUG THE FRIDGE FIRST! Then remove all items from freezer. Remove all shelves and bins. Remove the ice bin. Remove the lower back panel. You should be able to see the motor now, but you can not access it yet. The motor is mounted in a plastic shell/housing, this entire housing must be removed (along with the related wire harness). Install the new motor and rebuild the unit. This doesn't sound like much, but since you've not done one before, figure 2 1/2 to 3 hour job time. (With practice, it still takes us ~50 minutes) Wiring is CRUCIAL! Take note of EVERYTHING and the way things are routed in there. Otherwise, you won't know if you did it right until you have it rebuilt and plugged back in, if something were mis-wired... you'll know it now. Then have to disassemble to locate the problem. The part number you'll need is #WR60X10185, and sells for ~$45.00 at your local appliance parts retailer. If you hire someone to perform the labor, they won't be able to "soak" you on the part price. The good news is that after the repair is complete, your fridge will cool better AND I've never had a callback on these! (Which means that the replacement motors are MUCH better than the original factory installed ones.)
Posted on Aug 11, 2007
  • 110 Answers
SOURCE: GE Model # GSS201EPJWW
bad main processing board
Posted on Jun 13, 2008
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
  • 3 Answers
SOURCE: GE model TFX24FA side by side
If solution #1 fixes the problem, but it happens again, then check to see if you have water leaking from the ice maker area. I had a similar problem with my same model, and found that the ice maker water fill tube was leaking where connects to the connector in the back wall of the freezer. Water was leaking onto the freezer coils, causing it to go into defrost for long periods and both the freezer and fridge would warm up.
Getting to the fill tube is not an easy job. If you just pull it out without disassembling the fan compartment, you will probably not be able to get it back in.
You will likely want to move your food, unplug the fridge and thaw it out. Disassembling the top compartment on the inside of the back wall of the freezer is a tedious and time consuming task. After that I was able to just pull the tube out and turn it around and push it back in for a snug fit. You might consider using a sealer.
Posted on Apr 03, 2009
SOURCE: Specific dimensions of a side by side model 532
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
Posted on May 02, 2009
The water is slow coming out of the dispenser but the ice maker works normally model TFX25PP
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 09, 2011 | GE Profile Performance 25.2 cu. ft....
What is the cubic feet measurement for a GE Model TBX18 refrigerator? Also, what is its width and height?
The capacity depends on the exact model number. The TBX18TABWW and similar models are 17.6 cu. ft. The refrigerator holds 13.6 cu. ft. and the freezer 4 cu. ft. This model is 64.25" tall, including the hinge, 28" wide, and 31.25" deep.
The GE S series, including
TBX18SIBRWW, are 18.2 cubic feet; the specs are 13.04 cu. ft. for the fridge and 5.13 for the freezer. Total height (including the hinge is) 64.75", 29.375" wide and 31.5" deep including the handle. (It takes up 58" with the door open.)
The J series has the same total capacity and dimensions as the S series.
Remember to leave 0.75" free on both sides and 1" at the back and top for air to circulate around the refrigerator.
You can find your exact models specs and manuals here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box and click submit. Dimensions are provided in the Quick Specs for most refrigerators. The model number will be on a plaque in any of the following spots:
1) On the ceiling of the freezer near the front
2) By the temperature control
3) On the inside wall of the refrigerator near the crisper drawer on either side
4) Behind the crisper drawer
5) On the bottom front of the refrigerator
I hope this helps.
Mar 18, 2011 | Refrigerators
My ge profie PSS26MGTD is not getting cool any more
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 07, 2010 | GE Profile PSS26MGS Side by Side...
Mar 24, 2009 | Sub-Zero 690 Side by Side Refrigerator
Feb 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
