Question about GCC Technologies Elite 12/600N Laser Printer
Change printer name on ethernet mac network
Change printer appletalk name on ethernet mac network
4 Suggested Answers
SOURCE: GCC 12/600 Not found under Leopard (on wireless network)
Same problem.
Plus I am trying to find a legitimate download for a 12/600 printer driver that will let me print from my new MacBook Pro running Jaguar.
Peter B.
Posted on Jan 08, 2008
  • 62 Answers
SOURCE: Xerox DCCS50 to DC12, change Cobra with X12 fiery
at the end of setting up network settings it should ask if you want to save settings, click yes then its enabled. i have never had a fiery that doesnt hold its settings so its probably something you arent pressing.
there is an issue with one of the mac OS's that it just doesnt like the old fiery rips and you will never be able to print, but i'm not that clued up on the mac side and cant remember, sorry.
from your add printer section it should automatically see the x12 and give you the options of a hold,print and direct queue. I f you havent got a pc then the only queues that is useful to you is direct. Print holds the job on the hard drive and will eventually fill the server
Posted on Jul 30, 2009
  • 32 Answers
SOURCE: GCC 12/1200 printer and SNOW Leopard (TCP/IP?)
A friend had this problem. She is using TCP/IP with no problem. AppleTalk should still work with older machines. I have no idea if you can leave both connected at the same time. You will have to try and see for yourself.
Posted on Dec 27, 2009
The machine was moved to another location. the message states "close lower side cover" the door is closed. there is a crack in the hinge of the door. i press on the door and nothing happens. ...
Turn the power switch off.
If the printer has an external Ethernet adapter (an additional device that connects the Ethernet cable to the printer -- often this adapter will be a small gray or black box attached to the back of the printer), unplug its AC adapter from the power source.
Save your work and shut down your computer.
Wait a few seconds, plug the Ethernet adapter back in first, and then turn the printer back on.
Turn the computer back on
If the printer remains unresponsive, check the print queue for the printer, there may be other users' print jobs blocking up the queue. To check the queue on a Windows computer, go to Start -> Settings -> Printers and double-click on the printer. On a Macintosh, double-click on the printer on the desktop. If there are numerous print jobs stuck in the queue, cancel any jobs you own. If there are jobs owned by other users, you can contact those users directly or call the Help Desk to request assistance unblocking the queue.
If the queue is empty, try creating a small text file and print to the printer. If this prints correctly, the problem is likely with the other document rather than with the printer.
If the text document does not print, have another user print a small text document from their computer. If this document goes through, the problem may be with your computer rather than the printer.
Windows users should remove the printer by deleting it from Start -> Settings -> Printers and re-add it from its NTPrintServer queue.
Macintosh users can throw the printer in the Trash and reinstall it from the Chooser. If the printer no longer appears in the appropriate AppleTalk Zone, it may have been taken off the network or its AppleTalk name or zone have changed.
AppleTalk printers can occasionally lose their configuration and "forget" their zone. If you no longer see the printer in the appropriate zone in the Chooser, check the Unconfigured zone. If the printer has never been given an informative AppleTalk name, for example if a default name like "HPLaserJet6M" was never changed, there may be more than one printer with that name in the Unconfigured zone. If there are multiple printers with the same name in a zone, they are automatically assigned a number (#1, #2, #3, etc). To figure out which is the correct one, turn off the printer and see which one disappears from the zone. When you turn the printer back on, you will be able to pick out the correct printer.
Jan 21, 2011 | Toshiba DP2570 Printer
IMac connection to lanier ld122
Does this printer have the PS option installed? If not you will be unable to print even if you clear up the network issue.
As far as network goes is it currently connected and working with other PCs?
Mac printing is easily setup by typing the IP address of equip in the queue box upon setup. I believe the default queue name is "print" all lower case. If IP in unable to work properly make sure lanier has appletalk turned on and setup printer using appletalk.
Again if the machine doesn't have Postscript option you won't be able to print anything.
Hope this helps,
TankMurdock
Apr 23, 2009 | Office Equipment & Supplies
Asant? Talk compatibility with Mac OS 10.5.5
This is for system 10.5.x:
1. Delete that printer from your list of printers in System Preferences.
2. Make sure your computer, printer, and Asante box are all hooked up together and turned on.
3. Click + under the list of printers in System Preferences.
4. Click AppleTalk icon in top row of dialogue box that appears.
5. After a moment, click Bluetooth icon instead.
6. After a moment, unplug the power cord from your Asante box (but not from the electrical outlet).
7. After a moment, re-plug the power cord into your Asante box and, as soon as possible after the "TX" light comes on, click the AppleTalk icon again.
8. Within a few moments, your printer's name should appear. Highlight its name, then make sure all the information about it that appears is correct, then click "Add."
9. Everything should communicate beautifully. I had no further problems.
Nov 13, 2008 | AsanteTalk - Ethernet to LocalTalk Adapter...
ANy solution to the lack of fuji drivers for new macs and OS?
4500N can't be recognize with an Intel Mac, because the Appletalk doesn't work. My solution to print: I've got a powerPC as an interface between Imac intel and fuji network adapter. The pictro driver is installed on both machines. On The Intel, The Appletalk is connected on Airport. On the PowerPc, The Appletalk is connected on Ethernet. Ethernet cable between powerPC and pictro network adapter. SCSI2 cable between PNA and the 4500. Of course, auto calibrating + eye-one color calibrating. WELL!! it works.
Nov 13, 2008 | Fuji Pictrography 4500 Thermal Printer
I need to install HP deskjet 6940 on my Powerbook G4. I am operating on MAX OSX 10.4.6
If your printer does not appear in the Printer pop-up menu, find and install the appropriate driver. Check any CD-ROM discs included with the printer, or the website of your printer's manufacturer. Only users with an administrator account can install software.
Tip: You can also open the Printer List window from Printer Center (Mac OS X 10.2.8 or earlier) or the Printer Setup Utility (Mac OS X 10.3 Panther, or later).
Check the Printer menu again after installing the software. If the printer does not appear, you may need to do this:
  1. Make sure the printer is connected to your computer, plugged in, and turned on.
  2. For Mac OS X 10.2.8 or earlier, from the Printer menu in the print dialog choose Edit Printer List. The Printer List window appears.
  3. For Mac OS X 10.3 or later, choose Show Printer List from the View menu. The Printer List window appears.
  4. Click the Add Printer button.
  5. Choose USB from the first pop-up menu.
  6. Select your printer from the list.
  7. Click Add.
  8. Close the Printer List window.
How to add a network printer (AppleTalk or LPR)
Adding an AppleTalk or LPR network printer is very similar to adding a USB printer. In Step 4 above, you would choose AppleTalk or "LPR Printers using IP" from the pop-up menu. From there, the setup differs slightly.
AppleTalk printer
  • AppleTalk must be enabled in Network preferences.
  • If your network uses AppleTalk zones, choose one from a second pop-up menu that appears.
  • Make sure to avoid potential issues with AppleTalk multi-homing.
LPR printer
  • You must enter the printer's IP address or DNS name.
  • If you're printing to a queue, deselect the checkbox for "Use Default Queue on Server", then type the queue's name. If not, leave the checkbox selected.
  • You can select your printer from the Printer Model menu or leave it at Generic. In essence, are selecting a PPD file.
Question mark appears, or trouble finding a printer?
If you can't find the printer you want to add in the list of connection methods, make sure you're choosing the right connection type for your printer. Some printers may use custom input-output modules, such as "Epson AppleTalk". You may need to select one of these custom options in order to add your printer. If there's a question mark on the printer's icon, or Print Center or Print Setup Utility lists it as unsupported, check for an updated software version at the manufacturer's website, or the Mac OS X downloads page.
Tip for software installation
Your printer may appear in the printer list before manufacturer-required software is installed. If you have such a printer, remove the printer from your printer list before installing the software. Add the printer back to the list after you've installed the software.
Printers whose drivers or PPDs are included with Mac OS X
Additional Information See these articles for lists of printer drivers and PPD files included with Mac OS X:
25587: Mac OS X 10.3: Included PPDs for PostScript Printers
25588: Mac OS X 10.3: Raster (Inkjet) Printer Drivers Included
107001: Mac OS X 10.2: Included Ink Jet Printer Drivers
107002: Mac OS X 10.2: Included PPDs and Use of PostScript Printers
106490: Mac OS X 10.1: Many Third-Party Ink Jet Printer Drivers Are Included
106516: Mac OS X 10.1: Includes PPDs for Many PostScript Printers
Jul 10, 2008 | HP Office Equipment & Supplies
Airport Express, Bonjour Printing Does Work With Leopard
In the setup of the Airport network settings, you have to make sure that AppleTalk is actually turned on (or the box is checked). When using Mac's with Leopard and you use both the ethernet port and airport off and on, the OS tends to deactivate AppleTalk. Its not a set thing, just random.
Jun 27, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
i just bought a used 4500N printer and can't get it to be recognized by my mac or pc...any ideas how I get an ip address for it?  Thanks
May 10, 2008 | Fuji Pictrography 4500 Thermal Printer
Cannot connect using Appletalk protocol
Given that this issue is three years old, and AppleTalk protocol is no longer even supported, it probably should be laid to rest.
Oct 17, 2007 | HP Business InkJet 2800 Printer
Macintoshes and Print Servers, the PS110 in Particular
Topic 1. What do I need to connect a Macintosh to the PS110 Print Server? A PostScript printer with a parallel interface, a Mac running MacOS 8.6, 9.x, or 10.x. (NETGEAR products are not supported for earlier versions.), and Ethernet cables to connect the Print Server to the printer, and the Print Server to your Macs, and to a router. NETGEAR's RP614 router is known to work connecting the PS110 to the Internet with Macs. Topic 2. How do I avoid losing my network configuration when restarting my Mac? When changing theMacOS configuration it is best to use Configurations (MacOS 8.x or 9.x) or Network Location (MacOS 10.x) settings instead of changing settings for each category (TCP/IP, AppleTalk, AirPort, etc.). That way you can be sure the changes will not be lost after rebooting. To Create a Configuration in MacOS 8.x or 9.x 1. Open AppleTalk (or TCP/IP) from the Apple Menu in the upper left-hand corner of the screen. 2. Select File > Configurations > New Configuration. 3 . Type a meaningful name for your new configuration (e.g., NETGEAR Wireless Router). 4 . Make your changes to the AppleTalk or TCP/IP settings. 5 . When closing AppleTalk or TCP/IP choose Save Changes. Whenever making Configuration changes for settings in MacOS 8.x or 9.x, open File > Configurations or press Command-K. Changes in Configurations are saved after rebooting. To Create a Network Location in MacOS 10.x 1. Open the Apple Menu by clicking the Apple icon in the upper left of the screen. 2. Select System Preferences. The System Preferences window displays. 3. Click Internet & Network > Network. The Network Settings window displays. 4. If the window is locked, click the Lock icon in the lower left to unlock the Network window. (You may be asked for a username and password.) 5. Click the pull down menu next to Location at the top of the Network window. 6. Select New Location. 7. Type a name for your new location and click OK. 8. Make your changes to the TCP/IP, AppleTalk, and AirPort settings. 9. Click the Lock icon in the lower left to prevent further changes. The Apply configuration changes window displays. 10. Click Apply to keep the configuration changes for the newly-created location. 11. Close the Network window. Topic 3. How do I connect a Mac to the PS110 Print Server? For MacOS 8.6 and 9.x 1. Follow the instructions in the NETGEAR PS110 Installation Guide coming with the Print Server. (The CD is not needed unless you need the Reference Guide.) 2. Connect the PS110 Print Server to the PostScript printer with a parallel interface. (You cannot use non-PostScript printers with Macs on the PS110 Print Server.) 3. Connect the Print Server to the Mac. 4. Install the Printer Driver for the printer to be used with the PS110 Print Server on your Mac. 5. Open Chooser from Apple Menu. 6. Select LaserWriter 8. 7. Select the PostScript Printer to use. (This is probably the description for the PS110 Print Server and may have a name like ?PSD90335?. This name may be different on your computer.) 8. Click Setup. 9. Click Select PPD. 10. Select your printer from the Printer Descriptions list. 11. Close the Chooser. 12. Click OK. A message displays: ?You have changed your Desktop Printer.? You can now connect to the RP614 Router Gateway, and to the Internet. For MacOS 10.x 1. Follow the instructions in the printed NETGEAR PS110 Installation Guide coming with the Print Server. (The CD is not needed unless you need the Reference Guide.) 2. Connect the PS110 Print Server to the PostScript printer with a parallel interface. (You cannot use non-Post Script printers with the Mac and the PS110.) 3. Connect the Print Server to the Mac. 4. Install the Printer Driver for the printer you will be using with the PS110 Print Server on your Mac. 5. Open Utilities > Print Center in the MacOS 10.2 Applications folder. The Printer List appears. 6. Click Add. The Printer Selection window appears. 7. From the top of the Printer Selection window, select AppleTalk from the first pull down menu. 8. Select Local AppleTalk Zone from the second pull down menu below. 9. Click the Print Server from the list in the window. PSD90335 ? PostScript Printer in the case of this test. 10. Click the pull down Printer Model, and select the model of printer connected to your Print Server. A list of printers displays. 11. From the scrolling list select the Model Name of the printer connected to your Print Server. 12. Click Add. 13. Printer List displays with the list of printers and print servers connected to your Mac. Select the name of the Print Server from the Printer List. 14. Click Make Default. 15. Close the Printer List. 16. Open a file and try printing it. You can now connect to the RP614 Router Gateway, and to the Internet.
Feb 19, 2006 | NetGear RP614 Router
Macintoshes and the RP614 Router Gateway
You need a Macintosh computer running MacOS 8.6, 9.x, or 10.x. (Netgear products are not supported for versions of MacOS before 8.6.) You can use the RP614 with an eMac, iBook, iMac, PowerBook, PowerMac, or PowerPC as long as they are running one of these versions of MacOS. You also need a few Ethernet cables to make the connections between the router to your modem for internet connection and from the router to your computers or peripherals. Topic 2. How do I prevent my Network configuration from being lost when I restart my computer? When making configuration changes for MacOS it is best to use Configurations (MacOS 8.x or 9. x) or Network Location (MacOS 10. x) settings instead of just changing settings for each category (TCP/IP, AppleTalk, AirPort, etc.). If you just make changes to your settings, they may be lost when you restart your computer unless you have saved them in a Configuration or Network Location. To create a Configuration in MacOS 8.x or 9.x: 1. Open AppleTalk (or TCP/IP) from the Apple Menu in the upper left-hand corner of the screen. 2. From the pull-down File menu select the Configurations option. 3. Choose New Configuration. 4. Type in a name for your new configuration (Netgear Router). 5. Make your changes to the AppleTalk (or TCP/IP) settings. 6. When you close AppleTalk (or TCP/IP) choose Save Changes. Whenever you make Configuration changes for settings in MacOS 8.x or 9.x, open Configurations from the File menu or by pressing Command-K. Saving your changes in Configurations means that they will not be lost when you reboot your computer. To create a Network Location in MacOS 10.x: 1. Open the Apple Menu by clicking on the Apple icon in the upper left-hand corner of the screen. 2. Select System Preferences. The System Preferences window displays. 3. From the System Preferences window click Network under Internet & Network. The Network settings window displays. 4. Click the Lock icon (if necessary) in the lower left-hand corner of the window to unlock the Network window so you can make changes. (You may be asked to type in your User Name and Password.) 5. Click the pull-down menu next to Location at the top of the Network window. 6. Select the New Location option. 7. Type in a name for your new Location and click OK. 8. Make your changes to the TCP/IP, AppleTalk, and AirPort settings. 9. Click the Lock icon in the lower left-hand corner to prevent further changes. The Apply configuration changes? Window displays. 10. Click Apply to apply the configuration changes for the newly-created Location. 11. Close the Network window. Topic 3. How do I connect a Macintosh to the RP614 Router Gateway? MacOS 8.6, 9.x, and 10.x 1. Set up your system for installation. 2. First make sure your ISP connection is working. Try testing your computer with the ISP directly to make sure you can successfully make a connection to the internet. 3. Connect your DSL or cable modem to the Netgear Router. 4. Log on as Administrator (if required for your system to make configuration changes). 5. Quit all other applications. It's best when configuring MacOS 8.6 and 9.x to use the Configurations settings for AppleTalk and TCP/IP because they should then retain their settings when you reboot. (Use Network Locations to save your settings changes in Mac OS 10.x.) If you just change the settings but don't use a Configuration or Network Location to save your settings changes, you may lose those changes when you restart your computer.
GCC Technologies Elite 12/600N Laser Printer Logo
117 people viewed this question
Top GCC Technologies Office Equipment & Supplies Experts
jasbo
jasbo
Are you a GCC Technologies Office Equipment and Supply Expert? Answer questions, earn points and help others
