Question about Brother MFC-5860CN InkJet Printer
Init unable AF error; mfc-5860CN the scanner makes a sound and stops. All four light flashes
Mix-it-up
  • 832 Answers
SOURCE: Unable to Init AF - New printer!
sure (this advice costs you some greetings from me to the beloved bahamas ;-))
you have to open the scanner as you have done to connect the usb cable. When opened you can see a "z" like small cover going from panel to the right rear side.
Open this cover which hides the flat cable of the scanner. The cable needs reconnecting to the main board. Simply stick it carefully into the right positon.
(will post a picture later)
Posted on Apr 04, 2008
SOURCE: Error 46 Unable to Init.
No need for part necessarily
SkipperOz solution pasted below
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the Stop/Exit key to return to the initial stage of the maintenance mode.
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
Posted on Apr 10, 2008
SOURCE: [HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Posted on Oct 22, 2008
  • 159 Answers
SOURCE: Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Posted on Jun 11, 2009
pineworks
  • 4041 Answers
SOURCE: MFC-240C PRINTER DISPLAYS "INIT UNABLE 4F" WHEN TURN ON
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Unable to Init. AF in brother mfc 64900 cw printer
initial error AF, check the scanner flex cable or any cable, either they are not fix or not intalled properly..
Jan 28, 2014 | Brother MFC-5440CN All-In-One InkJet...
Mfc j691dw unable to init AF what does it mean
I cant get rid of 'unable to init.42' from my new mfc j6910dw. Anybody know what does it mean & how to remove the mssge?
Oct 14, 2012 | Brother Mfc-j6910dw Inkjet Multifunction...
Mfc 440cn touble msg: unable to init af on the screen,
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with thearrow down (round) key. You'll find an entry listed as purge count.If number is over 6000, enter 2 7 8 3.
This will reset thepurge count value. Then the printer will restart, hopefully withoutthe annoying cannot clean message.
Oct 21, 2009 | Office Equipment & Supplies
Scanner bar will not reset, error "unable to Init. AF"
the problem might be the connection from the mother board of the printer to the scanner maybe due to lost contact and the ribbon was broken you might just have to reconnect it or it might be broken and need replacement
May 10, 2009 | Office Equipment & Supplies
Apr 04, 2008 | Brother MFC-465CN InkJet Printer
Machine ERRO AF
Reconnect the scanner flat cable to printer mainboard by sticking it into position.
Mar 10, 2008 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-240C init. unable AF error message
Sure. No prob.
Open scanner cover as you would do to check for a paper jammed sheet.
Do open the plastic which runs from middle to the right side (looks like a "Z" turned clockwise). Use a small screw diver for that. beneath you will find th flat cable of the scanner. You have to reconnect the flat cable by simply sticking it into position onto the main circuit board. make sure flat cable is in good position and click the" Z  "onto the channel. Close cover then power up and do what ever you want to do with your mfc ;-)
Dec 12, 2007 | Brother MFC 240C All-In-One InkJet Printer
Init unable AF
AF means that the CIS scanner is (can) not (get)in right position. This could be because of a broken scanner flat cable, or a loose flatcable or a defective pcb. Check flatcable connection at the pcb (Open scanner like changing carts, open flatcable cover with a screwdriver. Does the flatcable stick in the pcb? (There is only the flatcable without a connector ;-)) Reconnect and power up mfc again. If it doesn't help please write again here.
Sep 13, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5860CN InkJet Printer Logo
70 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
