When scanning get error message scan requested, then scan failed
  • 3,741 Answers
If the printer/copier is new under warranty.get it replace from the company.but if its out of warranty.means one year old.then check out the above.this problem occurs in two cases.and many users face this problem. 1)if you have installed the driver of your copier in your pc/laptop/mac etc etc and from that when you give a command to scan and you get such error message on the the screen.that means the driver which you have installed is got corrupted in the pc.so it will support some functions and not support some.in this case just unplug the copier from power out let.remove the usb wire from the back of the copier.wait for two minutes and then reinstall the copier driver again .you delete the old driver which are already installed.copier driver cd comes with the copier when you buy a new copier/it will be mentioned on that cd .if you don't have that cd then you can just search on internet for the driver of the copier by mentioning the model number.you will get it in seconds .its free. ----------------- and now the second option ------- 2) if you reinstall the driver and still have the same exact problem,then its not the drivers problem.its the problem of scanner board in the copier.many times getting the printer/copier serviced by a local copier repair center solves the problem but if that does not helps then inner board of the scanner is faulty/so when you give a scan command it says requested but because the scanner board is faulty so it says scan failed. -------------- mostly the cost of this board are near to $45.you can get it easily from local printer repair shops/.they also replace it for you if you buy it from them. ---------------- this will help.thanks.please do rate the solution.thank you for using fixya .keep updated.
Posted on Sep 29, 2009
"Connection with Computer Failed" When I Try to Scan
If the primitive (as you call it) Windows Scan program is working then there is no problem with the machine. It can connect to the computer.
I suspect that the other (non primitive) scanning software is not configured correctly. It may be using a wrong driver. You may have installed some other device that is able to scan (such as a program that capture screens from calculators) and it has been set as default driver. Check the configuration of your scanning software.
Jan 23, 2014 | Lexmark OfficeEdge Pro5500 4-in-1 Inkjet...
Why sfc scan performs only 77%?
when you start sfc scan because operating system having problem and its try to fix but some how its not able to fix using this command so do one thing please repair os
May 10, 2010 | Microsoft Windows Vista Home Basic Edition
I just installed a (new out of the box) HP LaserJet 3380 All-In-One printer/fax/scanner. I have NOT set up the fax function (no telephone line available). The unit is connected to my computer with a USB...
WHen you open the scan application and get to the point just before you scan... open at the top menu "File" and request to "Save As" and give it the "Name.BMP" see if that helps..
You named the folder but you did not mention naming the file you want to save????
Aug 04, 2009 | Office Equipment & Supplies
Dell photo 926 wont scan
Replace the USB Cable to a new one 3.0
Jun 10, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 printer scanning problems
Go to Control Panel, then Programs and Features. Uninstall the Dell printer software.
Then, go to Control Panel, then Device Manager. Locate the printer, right click on it, and select uninstall.
Disconnect the printer from your PC.
Go to the Support section of Dell's web site, download the latest driver for your printer.
Restart your PC.
Install the software. Connect your printer when instructed to, or after the software install has completed.
Let me know if you still have issues :)
Apr 28, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell Photo AIO Printer 926 scanner
I want to scan pictures onto my computer to post them and when I push the scan button it says Requesting scan~ and then Scan request failed... Any ideas?
Mar 31, 2009 | Dell 962 Photo All-In-One InkJet Printer
Hp deskjet F2100 series scan fail
Okay, the driver for the scanner (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32\
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the scanner application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the scanner driver, and the problem will be fixed!
Mar 13, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Go to control panel, scaners and cameras and use that to start the scan
Oct 30, 2008 | Dell 962 Photo All-In-One InkJet Printer
Emachines 3240 - cannot recover
Download a Linux distro to a flash drive or DVD and see how well it runs off that. There's HDD utilities like SuperGrubDisk that can diagnose things.
Apr 04, 2017 | E-Machines Computers & Internet
16 people viewed this question
k24674
