Question about Sta Rite Sta - Rite 1hp Dura - Glas Inground Pool Pump, P2ra5el
Sta-rite problem
Hello i have a sta-rite dura glas p2ra5e-181L that trips out everytime it's being used what could be the problem it is wired for 110v and after being used for half hour in trips
  • Anonymous Mar 30, 2014
    How do u prime a sta-rite model mse-7?
  • 3,600 Answers
Pump is heating up and kicking the breaker try cleaning the pump filter and let me know by posting to this solution.
Posted on Sep 29, 2009
How to wire motor sta rite p2ra5e 181L
The green wire is the ground and bolts onto the motor frame on the top part,(should see a green screw). the other two wires go to the two posts with screws to clamp down on the wires. It does not matter which way these two are hooked up, one on each post.
Most motors are pre-wired for 220v from the factory. If you have 220v you're good to go. If you happen to have a 115v setup the motor will run at half speed. The motor can be converted to 115v by moving a brown wire and a white wire in the motor. The diagram is on the motor label.Best to verify your voltage first.
Mar 21, 2013 | Sta Rite Sta - Rite 1hp Dura - Glas...
How to replace motor
if you have the motor I recommend you have a pro do it. search your area for you're local pool pump motor repair service. cost should be around $20.00 this way its done right and protects the motor from getting damaged. ask them how to take better care of your pump and motor, that's the best pump you can get. sta rite dura glas
Prime the pump after any repair
Jay the pool pump reapair guy in longwood Florida 32750
Mar 12, 2012 | Sta Rite Sta - Rite 1hp Dura - Glas...
I need the wiring diagram for the point contacts on the back of a dura-glas 1 1/2 hp pool pump. thanks
7_26_2011_8_21_59_pm.jpg2 YELLOW GO ON 1 POST ON CAPACITOR , THE ONE RED GOES TO THE ONE SIDE OF THE POINTS THE RED/WHIT GOES TO THE POINTS AND TO THE OPEN LUG ON THE CAPACITOR .. SORRY ABOUT THE PICTURE , THE OTHER ONE WOULD NOT LOAD .. JAY THE POOL PUMP MOTOR REPAIR GUY LONGWOOD FLORIDA .
Jul 25, 2011 | Sta Rite Sta - Rite 1hp Dura - Glas...
Sta-Rite 1HP inground pool pump Every time the pump turns on it trips the breaker, after taking the motor appart and lubing it up I could get it going but once off for a period of time on startup it will...
Any time an electrical appliance trips a breaker there is only several causes:
1 - appliance is pulling more amperage than the breaker was built for.
2 - breaker is faulty
3 - a "hot" wire is touching "ground"
4 - screws (where wire is attached) in the pump or breaker are loose
1 - If the appliance is pulling more amperage than the breaker (or wiring) will allow, then check the appliance to see what amperage it's rated at. If this is more than the breaker will allow, you'll have to plug the appliance into a circuit that will take that amperage. If the appliance rating is within the limits of the wiring & breaker, then check #2, #3 or #4 above. If everything is okay with the remaining possibilities, then you have problems within the pump. Do it yourself'ers usually have a bad time when they open an electric motor. I suggest you take the motor to a electric motor repair shop or seek help from the Sta-Rite pump Customer Service.
Jul 01, 2010 | Sta Rite STA-RITE 1 HP DURA-GLAS PUMP
I have a sta rite 1 hp 115/230 motor i cant find where the white wire goes do you have a diagram
I assume you mean the white wire under the rear motor cover? If so Sta-Rite puts a wiring diagram inside this back cover. Hopefully it is still intact for you. Depending on your model and if it is wired for 115vac or 220vac will make a difference. I would suggest you go to the link I attached and look up your manual. The manual will have the wiring diagram for you.
http://www.starite.com/
I hope this helps you out. Please rate my response. thanks
Jun 17, 2010 | Sta Rite Sta - Rite 1hp Dura - Glas...
Pump froz and dont start
Is it still frozen?? If so thaw it out first.
If defrosted, will need to strip motor to see if you can hand turn it / free it up.
Jan 13, 2010 | Sta Rite Sta - Rite 1hp Dura - Glas...
I have a sta rite dura glas 1HP pump and can't figure out how to get the impeller off. Can you tell me?
Lock the shaft at the end where you electrical connections are made (disconnected of course!) and spin it off counterclockwise.
Aug 11, 2009 | Sta Rite Dura Glas 3/4 Hp In Ground Pool...
I wired a new dura-glas pump as a 115, and it popped the breaker. I put the black wire on 1 and the white on 2. Should I have wired it as 230? Should I switch the black and white wires, even though the...
The wire placement does not matter assuming you have a 115 volt supply with a three wire cord/cable and they are comming in as blk=hot, white=neutral and copper=ground.
Tripping a breaker would be from a shorted hot wire so look for a place where it touches the white or ground wires or the metal of the motor. Another cause would be if you really have 230V across the black and white and you connect it to a motor set for 115V. Is the breaker that turns off the circuit in question a signle wide or a double wide breaker. A double wide would be 230V.
Jul 31, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Sta Rite Sta - Rite 1hp Dura - Glas Inground Pool Pump, P2ra5el Logo
528 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
