Question about Epson Stylus Photo R200 InkJet Printer
Head is cloged for my epson r200, print comes out with lines, and when I do a head cleaning, it never comes out good.
    Problem Solver:
  • 8 Answers
Hi, When printing photos, my photos have horizontal light coloured lines across them. When I print the nozzle check pattern all colours match the guide with the exception of the light magenta....
Epsons are notorious for this sort of problem, especially in used infrequently as ink residue dries on the print head; try using a cleaning cartridge, or swab around relevant print head with cotton bud and ethanol/isopropyl alcohol. Here are examples of cleaning carts, there are others http://www.internet-ink.co.uk/epson-cleaning-cartridges/ http://www.icompinkcartridges.co.uk/epson-r200-r300-r220-r320-r340-cleaning-kit.html
Jan 03, 2011 | Epson Stylus Photo R200 InkJet Printer
My espson R200 won't print black even though it is full :s
> ESPSON
ESP-son? EPSN-Sports-Online?
Use the EPSON software to run a "print-head-cleaning" cycle to try to "unclog" the path that the ink takes from the ink-cartridge, through the "jets" onto the paper.
Nov 17, 2010 | Epson Stylus Photo R200 InkJet Printer
HEAD CLEANING DOES NOT FIX GAPS IN NOZZLE CHECK
Head cleaning is for fixing horizontal band. If some point of head cloged, print out will show horizoantal banding. For vertical banding, try using head alignment. Have yo tried printing without high speed (disable high speed option)
May 20, 2010 | Epson Stylus C84 InkJet Printer
I CANNOT PRINT BLACK ON MY EPSON STYLUS PHOTO R200. All other colors print. I have replaced all the cartridges. This is my forth attempt at trying to contact you people. CAN YOU HELP ME?
this issue may have several causes:
1. make sure that you've removed the yellow ribbon from the top of the cartridge before installing it. it is there to keep the ink fresh before it's installed and has to be removed to enable the ink to flow into the print head. (not all epson cartridges have this ribbon though)
2. check all the settings in the printer driver or simply remove the current driver completely and reinstall the latest driver you can find on the epson site.
3. the black print head may be clogged. in this case, performing cleanings will help, possibly several cleanings are necessary
4. there may be a faulty connection between the printer's mainboard and the print head.
5.there may be an electronical problem with either the print head or the mainboard.
in the last two options it's better to let a professional technician look at it.
Mar 08, 2010 | Epson Stylus Photo R200 InkJet Printer
Hi My Epson Stylus R200 print is nearly unreadable. The status monitor says status is OK and the nozzle check is fine
Ensure the nozzle check has 6 colours if it doesn't you will need to try head cleaning. you may also need to align the print head. All this can be found in the same place as the option for nozzle check.
If that is ok try a different paper type, ensure you are using relativly fresh ink.
Feb 02, 2010 | Epson Stylus Photo R200 InkJet Printer
Brown spots appear on the right of prints
I finally fixed it by printing in glossy mode on a thick and rough paper used for manual drawings. A bit of dust came off from under the print head and now it prints clean again.
Jan 16, 2010 | Epson Stylus Photo R200 InkJet Printer
Black wont print I've cleaned the print heads and there is ink it just keeps printing lines. It's like the print nozzle is cloged. I've cleaned the print heads so much that I've had to take the cartridges...
Hi and welcome to FixYa,
A possible workaround if it is an Epson brand is to use "Deep Cleaning" feature of a 3rd party utility program. Please check for model compatibility and if workable, download, install and run "SSC Service Utility". Additionally, there are special cleaning cartridges that contain cleaning solution rather than ink that maybe used in this process.
Good luck and thank you for asking FixYa.
Aug 08, 2009 | Epson Office Equipment & Supplies
Printing problem
Try jiggling the cables and making sure that the USB connection is solid. It worked for me. Good luck.
Sep 03, 2008 | Epson Stylus Photo R200 InkJet Printer
Lines in the printed page
go to printer properties , click the utility or maintainence tab, and click clean the ink jet cartriges option it will auto matically clean.then print nozzle check pattern,.compare the printout before and after.that.
Aug 16, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson photo r200 will not print
so after reseating all the cartridges and doing head cleaning from the computer / driver and still not getting any output on the paper :
if it´s not the printer - hopefully it´s the ink
have them replaced, contact the manufacturer
Dec 23, 2007 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
187 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
