Question about HP L1906 19" LCD Monitor
Monitor doesn't turn on - HP L1906 19" LCD Monitor
  • 31 Answers
Tere is problem in ur monitor go to near shop nd show ur monitor
Posted on Sep 29, 2009
Why does monitor not turn on with computer
I know this sounds stupid but make sure the monitor is plugged in and turned on. If it is then either your monitor is bad, or your graphics card is bad, if you have access to a different monitor hook it up, if it works you know it\'s not your graphics card, if it doesn\'t then it\'s probably the graphics card
Jul 21, 2014 | Dell OptiPlex Computers & Internet
Both leds are on
Have you checked the cable and reseated it, check for bent pins in the connectors. Perhaps the Graphics card/adapter is gone.
Mar 05, 2013 | HP Compaq d530 CMT PC Desktop
Acer P221W turns off without warning
tried with unplugged and re plugged doesn't resume in normal ?.ok check loose connection in the power adapter.if still doesn't resolved the problem, at this time you will need to check the power supply if it is working.you can use a digital tester or an analog to make a voltage checking.
Oct 07, 2012 | BenQ FP71G 17" LCD Monitor
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
No power at all
If your monitor doesn't turn on, and you are sure of the power supply (some plug directly into the wall and some use a power adapter), then you can assume that the monitor has failed.
You can fix it (replace the power supply in the monitor itself or possibly the on/off switch), have it fixed by someone who knows how to do this, or buy a new monitor.
First, of course, be sure the problem is your monitor and not the computer. If the monitor light turns green and then yellow, you can assume it's the computer. If the monitor light doesn't go on at all, it's the monitor.
Nov 18, 2011 | Computers & Internet
My computer's tower turns on but it doesn't display on the monitor, the monitor shows the normal Self test box so the monitor doesn't seem to be the problem. Also when I press the power off...
Make sure that the cable is connected from your computer to the monitor, and if it is wiggle it and push it in all the way. If it has screws, screw them in. If that does not work, check that your monitor is on the correct input (if it has multiple) then see if anything comes on the monitor. If nothing happens you should buy a new cable from the store. If all of those steps do not work your computer or your monitor might have a more serious problem.
Jul 29, 2011 | Computers & Internet
Monitor doesn´t work
1 MAKE SURE THE DATA CABLE IS CONNECTED TO THE CPU.
2 MAKE SURE TO TURN THE MONITOR ON.
Aug 05, 2009 | Samsung SYNCMASTER 943B 19" LCD Monitor
HP L1906 19" LCD Monitor Logo
292 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
