Water pouring out from under my washer as it fills...
As my Daewoo DWC-ED1212 front loader washer fills with water I can hear it spilling outside the drum and the water is pouring out from under the washer...what is wrong? Just started happening today. Before working just fine.
    Sergeant:
    Champion:
  • 205 Answers
Hello mam please check the rubber sleeve of the drum if there is any crack it should be replaced and check the drum if there is any holes in it, so please call the engineer and make him to check these.
Posted on Sep 29, 2009
THE ERROR IS 63 THE WASHING MACHINE MODEL IS DWC-ED1212
Under the machine should be a bag with
the diagnostic manual & codes
Aug 17, 2014 | Washing Machines
Daewoo DWC-UD1212 Washing Machine
Washer machine when I select manual wash , LE letter show on program monitor , and washer machine is not work.
Aug 29, 2013 | Daewoo DWDWD3011WW Front Load Washer
My ge front loader wont start will just fill with water and do nothing
If you look inside the washer cabinet or outside
shell, there should be a service or diagnostic manual
inside a bag, taped under or inside there,tip it up to look
from the bottom,may be up high so you don't see it
Most likely the circuit board failed
Aug 28, 2013 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer fills with water when not being used and pours out on floor. I normally leave the door open on the washer so it can air, but sometimes it will just fill with water and pour out the...
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2010 | Whirlpool AWM8123 Front Load Washer
Samsung Front Loader wf306law took off back panel as we had lots of water under neath ran washer rinse/spin soon as the cold water came in there was water all over the inside any idea why? the washer is...
I found MayTag has a full report on this washer. https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8169153c018494398525729c0057a4d2/$FILE/Samsung_Frontier_Washer.pdf
The part number is DC97-10417A and can be ordered at samsungparts.com
http://www.samsungparts.com/Products/Parts_and_Accessories/PID-DC97-10417A.aspx
Jun 11, 2010 | Samsung WF337AA Front Load Washer
Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Nov 10, 2008 | Samsung WF337AA Front Load Washer
Cleaning a daewoo
You usually grab it by the front and pull, but there might some screws holding it in.
Jul 24, 2008 | Daewoo DWC-073C Air Conditioner
Kenmore front loader 44832
1)right wont be a water surge if the water is coming from underneath washer when it is switched of could be that you have a leak and what it is doing is water is collect around the bottom and then spilling over so tip washer back fill it up and see were its coming from, 2)your hot water valve could be sticking on which in that case needs replacing take your lid off and when washer is off try and listen for water flowing through pipe
Aug 13, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
182 people viewed this question
Top Washing Machines Experts
