Question about Acer Veriton 7600G PC Desktop
I cannot boot my pc
My pc shows the intial starting procedure after that it restart and this process is repeating.
    Scholar:
  • 113 Answers
You first need to try and start it in safe mode. Usually you can get to it by pressing F8 Other computers may have a different button, so if F8 doesn't work then press the other F's
Also, does it give you the Blue Screen of Death?
Posted on Sep 29, 2009
My laptop(gateway nv53a) turns on but why does it only indicate "starting windows"?
Hi
The boot up files have become corrupt
you have to get the windows install disk
to match the windows installed on your
PC/laptop
Boot from disk and when its loaded it will give
you the choice to install or repair
chose repair and follow the promts
reinstall boot up files and then restart
if it still dosnt start
repeat process and this time
reinstall master boot record MBR
and restart
if that dosnt start you will have to
reinstall windows
25671898-m35oz4jvdfvvmght4a51n0jl-3-1.jpg or
or
cheers
Apr 29, 2015 | Computers & Internet
Wipro laptop PC not starting Only widows starting automatically option is repeating
go to boot menu and check your setting about firstboot devise.sure first boot devise is hdd than restart and show if problem not remove than return into boot menu and change first boot devise into dvd rom and reinstall your oprating system whith your oprating system cd..
Mar 02, 2014 | Computers & Internet
My Dell Dimension 8400 desktop computer using Windows Xp operating system. The monitor shows the Xp Logo at first. Then the screen goes blank about 30 seconds into the boot process. What can I do to g
If you hit <F12> key upon boot-up and the monitor displays a boot menu, then you probably have an issue with your XP software. Meaning that you may have to re-install XP (by the way, XP is no longer supported).
Jan 28, 2012 | Dell Dimension 8400 PC Desktop
Black screen on start up with blinking cursor
Chances are, the operating system is corrupt.
Solution 1
1. Restart the computer, before entering the windows, press F8 to open the Windows Advanced Options Menu.
2. To enter the windows, select Last Known Good Configuration - enter. If that fails, repeat the process, select the Directory services restore mode. If that fails, repeat the process, select the Debugging mode.
3. After successfully entering the windows, press START - All programs - Accessories - System Tools - System Restore. Restore to a date when the computer is in normal condition.
Solution 2 (if the above solution fails)
Repair windows operating system with a bootable CD
Windows XP
1. Insert the bootable operating system CD, and restart
2. Perform booting from the CD room - Enter
3. Press enter - F8 - press R to repair the operating system
4. Wait until the process is complete. Finish
Windows Vista or Seven
3. Select Repair your computer - System Restore. If that fails, repeat the process 1, 2
4. Select Repair your computer - CompletePC restore. Restore a computer from CompletePC Backup Image.
Solution 3 (only for Win XP)
When done repair the operating system, drive C is detected: unknown or not formatted, it means the C drive for bad sectors.
To fix hard disk bad sectors, use the software HDD Regenerator bootable CD.
Nov 23, 2011 | Toshiba Computers & Internet
My htc hero phone will not start up. it completely repeats the boot up process but not finishing the boot process. i have tried the procedure to force my spne into safe mode and it failed. is there a...
I have the same problem. There was an update and something went wrong. It installed, but the it just kept stannding on the startup-page. I pushed Back, Home and start, I then pressed menu, and now it's all black. I can't start it at all
Nov 06, 2010 | HTC Hero Smartphone
Laptop wont boot up after virus scan
I got this from Acer when that happened to mine. Good luck.
It sounds like it may be advisable to perform a system recovery on your machine to rule out that the problem is a software related one. In order to do so, you will need to launch the Disk2Disk recovery feature (which should be supported by your machine).
This can be initiated by typing Acer into the start search box and choosing Acer eRecovery Management from the menu. From here you’ll need to set up a password and then choose restore to factory defaults.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
If you are unable to complete the recovery process, please do not hesitate to contact us again, as there may be another problem with the machine.
Jan 13, 2010 | Aspire Acer 53152826 Notebook
I just purchased a display model notebook lg x110. i'd like to do a system restore and wip all the date off - can you help me?
If you reinstall windows, its probably best to format the harddisk. To get started, insert the window cd/dvd into your drive and restart the laptop. While it restarts, tap the "delete" button repeatedly in order to enter bios. there you can set the dvd-drive as the boot-device. Look for a menu called boot or boot-order. exit the bios and save the settings.
the laptop will then restart and boot from the windows cd. The insallation process will start and you will just have to follow the directions =)
hope this was what you were looking for.
Jan 30, 2009 | Computers & Internet
My computer Keeps restarting after the first 30 seconds...
before you get to the xp loading bar hit F8 a few times, youll get a menu up. boot in safe mode and try a system restore, make sure you pick a date to restore before the problem started. to find the option go to your start menu/programs/accessories/system tool/system restore
let me know how you get on
Jan 16, 2009 | E-Machines eMachines Desktop PC
Laptop ?
First try to boot in the safe mode, by repeatedly pressing the F8 key. If it boots into the safe mode, press the start button, shut down then select restart. If it will not boot normally then, repeat booting in the safe mode and once booted go to programs/accessorys/system tools/restore the select a restore point date that the computer was functioning correctly and restore for that date. If it will not boot the safe mode restart the computer with the system cd disk and restore from it. BPCS
Dec 05, 2007 | Dell Inspiron 6400 Notebook
Acer Veriton 7600G PC Desktop Logo
56 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
