Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Washer does not spin
My Cabrio top load HE washing machine just stopped spinning. It seems to try to run the cycles, but it just won't spin. I've emptied the clothes and drained the water. I've also lifted the tub and pushed it back into place. Nothing is happening. I've also tried adjusting the spin speeds. Everything seems to be working normally except for no spin. The washer is only 13 months old. It doesn't have the old fashion type agitator. It works on a spin plate. Any help would be appreciated.
  • 3 more comments
  • DaveW68 Dec 19, 2007
    I went through the diagnostic tests and the following error codes came up in this order: F50, F83, F51, F51. I then activated the Manual Diagnostic test mode and code 61 came up, which wasn't listed in the Service Tech manual provided by Eagle on this board. It figures that my 12 month warranty just ran out 1 month ago. Any ideas on which part is bad?
  • 1mikey Dec 26, 2007
    My Cabrio is 16 months old. Just got the F_ _ code. It wont spin. Seems to fill up and drain without problem. Im under warranty, thank goodness, but been on hold with service dept for nearly 30 mins now. I'm on hod as I write this. Maybe I'll get a reply before I get a service rep.
  • Sandi4 Jan 08, 2008
    My machine initially adds water and then gets to the "wash" cycle and won't spin or agitate. If I put it on "Drain and Dry" the tub spins so it's not the tub. I suspect it's the electronics. I can hear a humming noise so the machine is trying to do something but the tub doesn't spin or agitate.
    I am out of warranty and bought it in Sept. of 2006 so I'm beginning to wonder if it's a fault in the machinery since we are having similar problems with it around the same timeframe....hmmmm?
    Sears is charging $72 to just come out and look at the problem. I am going through the yellow pages searching for other repair prices.
    Sandi
  • kawimmer Jul 15, 2008
    Washer will not spin at all, agitates OK. Hear hum, so at least a relay is being picked, just no action. Countdown timer stays at 9 minutes forever.
  • Anonymous Mar 14, 2014
    i am trying to find how to dye clothes in cabrio top load washing machine
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Posted on Jan 09, 2008
My washer has been repaired. The control board was bad & the new one fixed the problem. They also replaced the sensor on the bottom of the washer while they had it apart since he had an extra one on his truck. Fortunately, even though the machine was 1 month out of warranty, Whirlpool agreed to cover the parts and labor.
Washer comes out of wash cycle stops code ol.run in rinse/ drain cycle,ol stops before comple cycle ,run in drain spin compels cycle
I hate to say it but everything on those machines is controlled by one board which can become faulty at any time. I would replace the control board
Sep 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the "OL" mean on the cabrio washer? it doesn't seem to be spinning out the water either
my cabrio is having problems too it won't go through a full wash cycle ,when it's time to drain it stop.I cleared the drains and even took the drum out and found some socks,then I started it today and it worked till the drain cycle .I also had it run a diagnostic and stopped on C8. I hate laundermatts
Aug 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer will not complete cycle and drain water
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
Feb 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Won't drain or spin
the timer may need to be replaced.. it might not be clicking on the spin cycle. try moving the dial manually to the spin mode.
Jul 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio agi stops after wash cycle
you may need a new timer. yes have it looked at.
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,202 people viewed this question
Dan Webster
Dan Webster
Sal De
