Question about Fire Magic FireMagic Grill
NEED THE INSTALLATION ROUGH FRAMING DIMENSIONS FOR THE FIREMAGIC, CHARCOAL, BUILT IN GRILL.
  • 3,600 Answers
Here is thier web page for the deminosns you need to frame in the grill.
http://www.bbqparts.com/FireMagic.htm If this does not help let me know.
Posted on Sep 29, 2009
Charmglow 810-6805-0 is the grill we have! It's a built in and we need to replace the entire grill? How do I find that grill so it fits the dimensions of what we have? Thanks
You won't find that grill anymore. Models come and go like waves in the ocean. You may find one with the same dimensions, but you won't find a new replacement for that exact model. This is the pitfall of "built-in" grills, as they have a tendency to need replacement within 5-7 years on average, due to wear and tear, and the elements. All a "built-in" grill is, for the most part, a typical grill that has not been mounted on the base unit and instead mounted into some kind of enclosure.
Sep 25, 2016 | Grilling
I'm trying to locate a replacement coal grate (perferably in stainless steel) . Can you supply one? Thanks tlynch@inficon.com
Sorry, we don't sell anything on FixYa. However, if you get the dimensions of the grate you needand search around on Google for some the Grill Parts & Accessories sites and you're more than likely to find what you need. I will caution you, Stainless Steel Grates are expensive. Plus, they do not do well with charcoal. The charcoal gets so hot against, that it will pop and pit. It's not like doing it on a gas grill, where the heat is moist and the stainless retains it's integrity. Unlike coal or charcoal, which is an extremely dry heat. You may be better off with Cast Iron. Once it's seasoned, it should do better than Stainless Steel.
Hope this helped you. Please let me know. Thanks/
Jun 21, 2011 | Patio Classic 2000 Series Grill
I need an installation guide. None was included. Please help
Here is a link to Landmann Grill's home page. To be able to download and print a copy of your Owners Manual, you must register your grill first. Then click on the Customer Service tab and a drop down menu for Owners Manuals will appear. Click on Charcoal Grills and find the Model Number of your grill. You will be asked to log in again, before you can download it.
If you don't want to go through all this convoluted process, try calling Customer Service direct 877-347-4557 and maybe they will be kind enough to send you one.
Mar 23, 2011 | Landmann Black Dog 590115 Charcoal Grill
Firemagic ECHELON E660i - flames shoot out around the orfice heat stressing the front panel, making controll knobs too hot to touch and allowing flames to shoot up onto the lid, grill is 20 months old. ...
Has this been happening since new or did it just start?
Either way, you need to check the burners for proper placement over the burner orifices. Are they fitted snugly? Are they running perfectly parallel to each other and resting properly on the back inner cabinet of the grill, in the burner holders.. Also, make sure that the orifices are screwed in tight and are not clogged. Check the burners for clogs and if found clean out the burners, by gently tapping them on a firm surface.After doing that, turn the up so the orfiice end is down and see what falls out of the burner(s). If the burners or orifices were clogged or the orifices not tight, it may be backfiring into the control panel. This can also indicate a gas pressure problem.
If you can remove the front control panel (remove the burner knobs, first) you can access the gas fittings to each burner's control knob and it's gas fittings. Without lighting the grill, turn each burner ON and check for leaks with soapy water at all the connections. Then turn it off and check for leaks again.
If you found any leaks, check each fitting to make sure it's not cross threaded and re-tighten.
If none of the above solves the problem, contact the Fire Magic Dealer you purchased it from or the R H Peterson Company (they make the Firemagic Grills), as it may be a manufacturer's defect. They have an excellent warranty program. For a warranty claim, you will need your Proof of Purchase.
Hope this helps to get you back grillng>
Feb 21, 2011 | Fire Magic FireMagic Grill
I am looking for the top and bottom grills for the patio classic 6000 grill . thanks for the help.
Check with Lowe's. They carry a large number of generic grates for gas and charcoal grills. However you must have the dimensions of the grates or take the old ones with you to the store to match them up.
Jan 27, 2011 | Patio Classic 2000 Series Grill
How to shield wood cabinet from heat
You should not have flammable materials near the grill to begin with, but if you do. You will have to have a metal insert made for the grill to sit in.
Jul 05, 2010 | Fire Magic FireMagic Grill
13 year old firemagic -- rusted burners and grid. can i get replacements?
yes you can look up Atlanta Grill Services on the internet call them they can get the parts for you.
Jul 14, 2009 | Fire Magic FireMagic (LP) 14-S000C-0 Grill
I need a charcoal filter
The GE spec sheets for what is the right charcoal filter are incorrect. You will never find the right one. I have this same microwave and had same problem. I called a local appliance company and they gave me Part No. WB06X10359 and when I googled this part it was not the right dimensions. I finally found the perfect solution. Go to www.rangehoodsfilter.com (Filter Factory-TTN Inc.) and they are customing making the filter for me. I spoke to Dave this morning from Filter Facotry and he's making me one with the following dimensions - 5 7/8" x 13 1/4" x 1/4". The cost is $16.95. If this fits I will order more. The more you order, the cost per unit goes down.
Jun 03, 2009 | GE Spacemaker JVM1540 Microwave Oven
Fire Magic FireMagic Grill Logo
42 people viewed this question
Top Fire Magic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
