TV picture is unstable until the TV warms up. This is taking longer and longer. Picture gets large, small, large, small... Quality is also lacking until it is warmed up. This is a Phillips 60'' Is this something that should be repaired or is it just better to get new TV?
    Genius:
  • 1,112 Answers
What model and brand is your television?
Is it a CRT type or DLP?
If picture is getting smaller then larger, and its a crt rear projection television sound like you have bad connections around the Flyback transformer and or horizontal circuits. This usually happens when a connection is made on the circuit board and the picture returns to normal especially during a cold start, but as the television warms up the connections on the board start to seperate and the problem starts occuring or it could be in the reverse process. Unstable at first then when tv gets warm it make better connections. All in all have a technician check the HV section of your deflection board.
Posted on Sep 29, 2009
LCT TV picture blurry with black smudges until it warms up
No easy way short of monitoring with a scope and or voltmeter, based on age of set I would first "look" at all the filter caps in the main power supply--bad ones when they get hot can regain some function:
Dec 09, 2012 | Televison & Video
Screen is turning purple and green dose this cost lots to fix?
It sounds like your tube Shadow Mask may have got magnetised and need to be degaussed.
Turn off your TV at the mains and unplug it for at least two to three hours. Longer the better. After that time power up your TV it should degauss the tube at power up.
Worth a try before you give up on it. Or else get your picture tube replaced. It may be more economical than purchasing a new television. Also try to have the picture tube of an old color T.V as modern picture tubes lacks quality when compared to older ones. But check those tubes thoroughly before buying it.
Apr 07, 2010 | Hitachi 43FDX01B TV
Dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Feb 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
My pictures are too large to email, why
open up your camera like you are going to take a picture, and click your blackberry button. go to options, inside there you will find picture size and picture quality. change your picture size to medium and your quality to fine. if they pictures are still too big, then just play around with those settings until something works. Hope this helps.
Jul 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Toshiba rear projection has a very fragmented picture
By fragmented, do you mean pixelated?? If so, it may be worth trying different inputs to make sure that it`s the set and not the external equipment that is producing pixelated pictures, The primary fault that you may have could be due to the age of the set. Most CRT/TUBE TV sets start taking longer and longer to come on as they get older because the uPC (Computer) performs various checks on the set and one of these checks involves beam current. Basically, if one or all tubes were getting soft or poor due to age, the uPC would mute the video signal until such times that the tubes had warmed up sufficiently to provide a good picture. Basically, if this is the case, then it`s getting tired and if the delay gets to a point where it becomes unacceptable, then a replacement set is the only option. I hope this is helpful to you, Ian
Jul 24, 2009 | Toshiba 50HDX82 50" Rear Projection...
Rolling of picture
You camera is PAL and you are attaching with Ntsc TV or VCR. Both Pal and Ntsc are different systems and incompatible to each other.
If you want to see correct playback of your Camera, it requires Pal or Multi-System color TV.
Need further info, please let me know.
Oct 04, 2008 | Sony Handycam CCD-TRV68 Camcorder
Tv picture is shakey
Bad capacitors on Hyper module = no longer available, but
can be rebuilt by PTS Corp or a qualified tech...........T.
Feb 13, 2008 | Toshiba 42H81 42" Rear Projection...
Vertical hold problem
Maybe sync separator transistor is faulty
Dec 22, 2007 | Zenith C32A26 32" TV
Picture darker/less color/smaller until warm up
Hi there!
Have you checked for dust on the Tubes and mirror? This may cause a bad picture quality. Also power supply related problems like capacitors can cause a dark picture. Try replacing some of them in the power supply area and line stage.Also adjustments in the service mode,but for this you will need the service manual. Good Luck,JUS004
Oct 15, 2007 | Mitsubishi VS-55707 TV
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
Electro Med Services...
