I have a 5 month old zanussi essential 1200 washing machine. It has power to it but it does not draw in the water. I have checked the fault finder element of the manual and it still does not draw the water. I have lost the receipt so cannot prove its age, therefore they will not honor the guarantee. Can you help.
    Sergeant:
    Champion:
  • 205 Answers
Hello mam
please check the filter at the water line filter will be fixed outside the washer where the water hose pipe is connected and check the solenoid valve which controls the water flow this will be fixed at the upper part of the washer you can see this when you open the top cover of the washer and at the water line.
Posted on Sep 29, 2009
The conditioner isn't going through my machine
Clean conditioner compartment as you can see on bottom picture.
Be sure to read the instructions of the manufacturer of conditioner. Some manufacturers supply concentrated softener which should be diluted with water (is too dense and can clog small drain tube in softener compartment). Also make sure you do not fill up over sign MAX., otherwise softener may leak in drum before starting the washing machine.
Dado
Oct 10, 2014 | Zanussi Washing Machines
Zanussi 1200 essential washing machine, cleaned out filter now will not fill with water
Go back into the machine and check for a disconnected wire cause by cleaning out the filter. Oh and did you remember to turn the water faucet back to the on position? It helps to plug the machine in to the A/C outlet, too. Keep an eye attuned to a safety switch on the access panel as well. It may have an alignment or broken plastic fastening/ mounting design.
Feb 08, 2014 | Zanussi F1045W Front Load Washer
Zanussi 1200 6kg, not spinning or taking in water ?
Try unplugging the unit for 30 mins. then run it again.
Nov 21, 2012 | Washing Machines
We have a Zanussi Essential 1400 6kg washing machine which is about two years old. It is not working , not turning. We live near Bridgend in South Wales, can you recommend a repairer for us in our vicinity...
Ideally if you are able to give us some input of the fault we can advice you other wise it is best to identify the nearest Zanussi service support close to your place.
Please check this out with a basic idea to identify the fault .If the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Sep 02, 2011 | Zanussi Washing Machines
I have a zanussi 1200 essential washing machine, and the conditioner is not emptying?
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Sep 02, 2011 | Zanussi ZWF12070 Front Load Washer
I use zanussi essential. For the last few months the fabric softner did not completely go away and I was left with water in the compartment. No the fabric softner does not go through the wash at all. ...
Zanussi
Jul 30, 2010 | Zanussi Washing Machines
Missing user manual for Zanussi Essential 1200
I have downloaded a manual for the item
May 17, 2009 | Washing Machines
Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Jul 28, 2008 | Zanussi FC1200W Front Load Washer
Washing Machines Logo
211 people viewed this question
Top Washing Machines Experts
