Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Lines in the middle of screen
Tv has lines in the middle of the screen from left to right the length of the tv.picture is good on the top and bottom but has lines in the middle
  • kentois Feb 05, 2008
    Yes, a series of horizontal lines across the middle of the screen.  LCD board fried?  No info in the internet as far as I can see.  Out of warranty of course.
Fixed.  The problem was the B board (digital signal processor). Bring lots of money.
Posted on Feb 15, 2008
I have a LG 32LH30 TV. When I power on the TV I get a picture in the top half of the screen and vertical lines in the bottom half. Also I get a thin white dashed line across the middle of the screen....
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Picture is a flat line in the middle of the screen
Hello. Is the line is from left to right or top to bottom
Mar 01, 2011 | Toshiba CF35F50 TV
When I turn on my Vizio P42hd I get lines of different colors down the left side of the unit from top to bottom. Is this something that can be fixed? My email is mdrye@holtville.k12.ca.us
This problems is not causes by a person or some objects by hitting ur LCD tv picture screen panel?If,yes,by a person or an objects by hitting the picture screen panel.This tv is not repairable only can be by replaced the whole entire LCD picture screen panel only,sorry than this tv is not worth repairing.Because by replacing the tv LCD picture screen panel itself,will cost the same as a new tv.If these colors strips show up by itself,yes,tv it is repairable.The board call the T-Con decoders board is dead.This board sit right at the bottom right in the middle of the LCD picture screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Nov 22, 2010 | Vizio P42HD Television
We have a widescreen plasma (Panasonic TY ST05-K). The picture all of the sudden shrunk to about 3/4 of the screen. Fortunately, the picture is not cut-off, so you can see the whole picture. The...
Hi there! If picture is smaller top to bottom with blank section on top and bottom then check your aspect ratio settings. If blank at the bottom only the Bottom Y-Drive board may be faulty. If blank at the top The Top Y-Drive may be faulty. If blank on the Left (TOP TO Bottom) then the Right X-Drive Board and on the Right, the Left X-Drive Board. May also be bad connections on the cables or flexible ribbon cables. Best Wishes and Good Luck, JUS004
Aug 23, 2009 | Televison & Video
Picture/image problem
Bad solder connection in the horizontal pincussion circuit.have someone resolder.God luck.4tune
Jan 09, 2008 | Televison & Video
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
My Hitachi 65SWX20B Model, made in 02, just developed Picture disturbance
Can you post a picture of the set. This might be a convergence problem. seeing the set will confirm this.
Thank you,
shuttle83
Oct 28, 2007 | Hitachi 65S500 65" HDTV-Ready Rear...
Line going thru the tv
Josh, When you say a line going through your TV is it a line from left to right or top to bottom? Is there a picture present and this is a line imposed on the picture or just a line by itself? Let me guess, you have no picture just a horizontal line (from left to right) across the middle of the screen. If so that is collapse of the vertical deflection and most likely caused by failure of the vertical IC and possibly linked to some bad caps in theat circuit as well. It's not an expensive repair, just find a good reputable shop. You might also mention, or if they ask, that your unit is a lighbox. Meaning that when they go to repair it the insides of the unit separate from the cabinet for easier access.. Good Luck Bill
Jun 12, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
336 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
