Question about Parsons QuickVerse 2005 Expanded Edition (11149)
Quickverse 7.0 and vista
I need to get a driver so quickverse 7.0 will work with vista. any tips are appreciated. thanks
When attempting to install QuickVerse versionn 7 on my new Vista equipped computer, I receive the following message: Microsoft
DAO is in use. Programs using DAO must be exited before setup can continue. I have tried to follow the solutions posted, none of which works.
    Sergeant:
    Champion:
  • 298 Answers
Run msconfig and check if any Office programs
are running at startup uncheck them or delete the entry run from the registry ,and any Office programs that
are running during installation it exist
Posted on Dec 19, 2007
Can I install Quickverse 7.0 on Windows 7?
Locate the setup file for QuickVerse. Right click on the file and choose 'Properties'. On the 'Compatability' tab, click the check box next to 'Run this program in compatibility mode for:' and choose 'Windows XP Service Pack 3'.
After QuickVerse is installed, you may have to perform the above steps for the application file as well.
Jul 26, 2012 | Computers & Internet
I have a new computer with Windows Vista. I have
No it looks like they stopped the support at the old one, this means they did'nt make any drivers for the old one to function on vista.
Vista uses a very diferent driver model than xp does.
The drivers for xp won't work in any way on vista.
Sep 19, 2009 | IMSI QuickVerse 8 Deluxe (QUICKVERS8E) for...
I have used Quickverse VErsion 7 Deluxe for years on previous laptops using Windows 98 and Windows XP. However, I have installed it on my new laptop using Vista 32 bit and if I right click on the desk
From their website
Question 1:
Can QuickVerse 2007 run on Windows Vista?
Answer: Configure QuickVerse 2007 for Microsoft Vista Compatibility Mode
  1. Download and install the latest Maintenance Release
    Browse to the Program Files folder for QuickVerse 2007
  2. Configure Compatibility Mode for these 2 files:
    C:\Program Files\QuickVerse 2007\qv11.exe
    C:\Program Files\QuickVerse 2007\QVBookManager.exe
  3. Right-click each file listed above and select Properties on the Menu
  4. Click on the Compatibility tab and make the following selections for both files listed above:
http://www.quickverse.com/Shopfiles/Faq.asp?ID=QV2007WIN
Apr 23, 2009 | Computers & Internet
Installing QV 7 produces warning MS DAO preventing installation.
I,too, have the problem of installing my Quickverse 7 on my computer with Vista. What do i do to stop the running of Microsoft DAO?
Apr 08, 2009 | Parsons QuickVerse 7 Essentials (fe11044)...
Want to install Quick verse 7 on Vista
the Quick verse 7 was made only for 95 98 2000 and XP but you can try this method on how to install the QV 7 on winXP sp3
"Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the QuickVerse version 7 Essentials CD into optical drive & close tray. This begins the auto run / install process. (Please do not remove CD until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message box appears at the end of the installation: “QuickVerse installation has encountered a problem and needs to close” Choose “Don’t Send” The installation program exits.
Navigate to: Start Button / All Programs / Parsons / QuickVerse 7 / (from drop down list) find “QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog Box appears, “The librarian datafile library.mdb not found etc…” Select “New” / "Open Book" dialog box appears click on “Close”
Now with QuickVerse 7.0 running go to File / Add Books. “Registration Guide – Introduction” box appears. Choose “Next” The path to the new collection to register should identify the optical drive (with the QuickVerse CD already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight QV Essentials in the LH pane. The RH pane shows all the books present on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…"
hope this helps./
Nov 04, 2008 | Computers & Internet
Quick verse 7
Default Drive
Jul 11, 2008 | Parsons QuickVerse 7 Essentials (fe11044)...
Hp photosmart c4380
well..you'll need a different set of drivers for vista
get them here(make sure to choose vista for operating system)
Mar 23, 2008 | Office Equipment & Supplies
I tried the following and it works. I had several bad installs and this works. My guess is that the first steps are not necessary, but they won't hurt.
1. Insert the first CD and explore to find the autorun file. Right click and choose properties, and run it in compatability mode with Windows 98.
2. Right click again on the autorun file and choose to run it as administrator.
3. Follow all the regular steps for installation.
4. On the new shortcut, right click and choose properties, run in compatability mode with Windows 98.
5. Finally, right click on the shortcut icon and choose to run the file as administrator.
Good luck. It is a wonderful software I have had for ten years and used on a half dozen computers.
Nov 17, 2007 | Parsons QuickVerse 2005 Expanded Edition...
Quickverse 5.0
I had the same problem [Quickverse 7 on a Vista OS] but my fix was a little longer. On my right click on the icon I didn't get a Compaibility tab. I went down to "properties" then in properties the tab for compatibility shows up. Click on "Run this program as an administrator." This worked fine for me. And this site rocks with so much great information - thanks everyone for your input and for sharing!
Nov 12, 2007 | Parsons QuickVerse 2005 Expanded Edition...
Cannot install Quickverse 7 version from year 2000 because of Microsoft DAO.
Hi, I had the same problem and fixed it, (loaded my quick verse bible software by loading the software in SAFE-MODE. This mode stops the dao that is running. (probably micorsoft office at start up). This solution worked perfect....God bless
Sep 06, 2006 | Parsons QuickVerse 7 Essentials (fe11044)...
Computers & Internet Logo
184 people viewed this question
Top Parsons Computers & Internet Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Parsons Computer and Internet Expert? Answer questions, earn points and help others
