Question about Trendware TEW-632BRP Wireless Router
I installed the router and it shows up on my
I installed the router Trendnet tew-632brp and it shows up on my computer that I am connedted but I cannot get on the internet. My ipconfig says media diconnected. I rebboted but still no go
  • ed_browne Sep 29, 2009
    The network shows me connected to the wireless router but no connection to the internet. Media disconnected. I am set up for Dynamic IP
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Sep 29, 2009
In order to use WiFi in my home, I need to know/change my router password. Id there any way to reset and renew my password?
Normally on the back of a router there is a reset button that will set the router back to the way it was when you first removed it from the box. Hold this button with a pin or tip of a pencil for 10 seconds and then go through the original setup process you went through. This is where you can setup your wireless password and your router password as well.
Check out the Trendnet web site for more detailed instructions if you do not remember.
Good Luck.
May 09, 2011 | Trendware TEW-632BRP Wireless Router
Trendnet router will not give a wireless signal, Wi-fi on laptop is enabled, direct connection from modem to laptop will give internet connection. Tryed unplugging everything, resetting it. Nothing I know...
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop/desktop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Apr 13, 2011 | Trendware TRENDnet TEW 632BRP wireless...
Im having problems with my trendnet 632brprouter connecting to xbox live
Step 1 : Connect - Router - Computer ( Wired )
Step 2 : Open Router setup by typing http://192.168.0.1 on the address bar of internet explorer
Step 3 : Click Login
Step 4 : On the Left Click Access
Step 5 : Chose DMZ
Step 6 : Click Enable ... And Assign the IP Address of the Xbox /PS3/Wii in it
Step 7 : Click Apply
Step 8 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 9 : Plug the power cord back to the router and wait till the lights are Solid
Step 10 : turn On the Xbox/PS3/Wii
Step 11 : Test the Connection
let me know if this works
Regards
TOM
Dec 17, 2010 | Trendware TEW-632BRP Wireless Router
Can't assess password to set up a new computer
Here is the PDF file that shows how to reset the router if the password is forgotten.
http://downloads.trendnet.com/TEW-432BRP/FAQ/FAQ_TEW-432BRP.pdf
Oct 14, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
My Trendnet router 423 BRP system lights is blinking. I sthere a problem?
The model number of the Product you are mentioning would be TEW-432BRP. The system light should be blinking all the time showing that the router is active. If the system light is Solid or off then there is some problem
Apr 06, 2010 | Trendware TRENDnet TEW-435BRM 802.11g...
Have a WRK-54G Linksys wireless router. Have a
I had a TEW-421 card for a time, and it can not do WPA encryption, only WEP. It's not a driver shortcoming, it's the hardware in the TEW-421 card.
Sorry to tell you it's a dead-end, but at least now you know.
Oct 18, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Can't connect to internet
just try to power down your router for a minute or two then fire it back up again...9times out of 10 this resolves the issue...failing that try re-installing the wireless adapter.... hope this helps
Dec 11, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
Trendware TEW-632BRP Wireless Router Logo
249 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
