Question about Kenmore Washing Machines
Kenmore top load model 20922 will not spin or empty but it does agitate
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
http://www.fixya.com/support/r699497-replacing_gearcase
WITH APPOLOGIES TO AMERICAL APPLIANCE.COM, ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2
inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Sep 29, 2009
Kenmore elite washer model 110 won't empty water and spin
Does it agitate? If it does not then it maybe the coupler that connects the motor to the transmission. If you hear a clicking sound. This may be your problem.
May 21, 2014 | Kenmore Oasis Agitator 4.5 cu. ft....
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Washing Machine does not agitate
Following is the Whirlpool installation and maintenance PDF on how top load, direct drive washers work with a troubleshooting section.
Following is the Whirlpool parts list for commercial top load, direct drive washers although the consumer washers are basically the same.
The problem seems to point to the Agitate Cams in the transmission that raise and lower the Agitate gear on the main transmission shaft. These are relatively inexpensive to replace.
I'd also check the splines on the main agitator shaft and the two pronged "washer" on top of it.
Oct 03, 2009 | Kenmore Washing Machines
Kenmore Model 110.26712693 stuck on agitator cycle
Your air pressure hose going to the water level switch is pinched.
Open the top control panel to access the clear plastic tube and relieve the pinched area.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 washing machine does not spin or agitate
make sure your pump is not clogged or jammed..that will stop the motor,,quick test,,pull pump off and start unit in wash,,or spin if unit is empty..onthejob
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
My washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Jan 19, 2009 | Kenmore 24932 Top Load Washer
Kenmore washer 110 20912 990 will not spin or empty
sounds like perhaps you dissconnected the door latch assy,and never reconnected??? hte unit will not spin/drain with the door latch not making contact
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
503 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
