Question about Toshiba 55H70 55" Rear Projection Television
Toshiba projection TV. Bulbs wont come on
I have sound and I hear the bulbs click as if they are starting up, but no picture. Usually after a period of 2 minutes or so, with the power disconnected, it will start up. I have noticed, when it is working, that the picture takes longer than normal to get fully bright, howerver, everything else is as normal. I assumed it was getting hot, so I cleaned out the dust, but this morning it wouldn't light up at all, so temperature doesn't seem to be the reason. Also, when the power is on with no picture, I can turn the power button off and I get a bright flash from all three bulbs as it urns off. If I try to turn the power on again from the button I get a flashing light from the power button indicator on the front of the tv. Disconnecting the power seems to be the only way to reset this. Any help on this would be greatly appreciated.
    Genius:
  • 1,112 Answers
The deflection board in failing, eventually it will not come on at all, disconnecting power is only reseting the HV shutdown protection circuit which is the reason your set if failing. Have a technician replace the Horizonal Output Transistor and the flyback transformer.
Please comment if you need futher assitance.
Delhielectronics@live.com
Posted on Sep 29, 2009
Testimonial: "Thank you! I'll try that and let you know! "
Get sound but no picture The picture wont come on but get sound
If it is a projection TV like a Sony Bravia, it only has one bulb. I suspect that the bulb filament is burned out (no light on screen) but the audio circuit is still functioning. The bulbs are easily service by the owner/user through an opening in the front or side of the set (refer to owner's manual). Bulbs are available on line from a number of manufacturers at very resonable prices. Good luck!
Dec 17, 2014 | Televison & Video
My tv toshiba 51'' rear projection wont come on, no sound or image but i hear a click when turn on and off.
most common reason is convergence problem--unsolder both chips and see if set will power up with them out of the circuit.
May 02, 2012 | Toshiba 51H94 51" Rear Projection HDTV
Periodically my 52HM95 would have some little electrical glitch where it would not come on when I turned the tv on. I would have to wait a little while before I tried again, or I could shut the power off...
I have a similar DLP TV. If you losing your new bulbs that quickly there is likely a problem with cooling. There is a fan that keeps bulb cool. Make sure the fan is working and there is nothing blocking the air passages. I have not had a problem with my fan but you should be able to find a replacement at Radio Shack or a computer/electronics store like MicroCenter. They come in standard sizes just make sure the voltage is correct typically 120 VAC or 12 VDC.
I have had the computer inside crash such that the sound would work, the bulb would come on, put no picture. Fixed by unplugging the TV for one minute then plug in and turn on.
The bulb repeatedly goes through its startup cycle but never comes on. It tries about ten times then stops. Fixed by removing the bulb housing and firmly tapping it on a counter top ten times. This was at Toshiba instructions over the phone and it actually worked.
Dec 31, 2010 | Toshiba 52HM95 52" HDTV Projection...
I have a Toshiba model 65HM167. The bulb exploded about 6 months ago so I replaced it and everything worked fine until now. Now the TV will power on and I will get sound but no picture. The yellow light...
Unfortunately lamps go bad without the visible state of being bad. I don't know who or where you bought the lamp from but I order all my lamps through dlplamps.com
The clicking sound you hear is the lamp inverter igniteing the lamp but the lamp is bad.
Nov 29, 2010 | Toshiba 65HM167 65" Projection Television
I have a Toshiba TN50X81 Cinema Series HD the sounds works great but there's no picture. It just went blank all of the sudden. Opened it up and there's 3 bulbs and none of them are working. Can anyone...
the bulbs go out it is normal on projection tv's, you can order the new one online, just out in the model number of your tv and you will find it, be very carful not to touch the bulbs when they come or when you are putting them in the tv
Aug 11, 2010 | Toshiba TN50X81 50" Rear Projection...
Hi. I have a 2004 52' Flat screen projection TV. For the past couple months, we have turned on our TV and all we hear is sound, but no picture comes up. We thought the bulb was having problems. We ordered...
The buzzing is the ballast arc gap,normal sound. When the tv starts does the lamp start to come on. Can you see any light from the back? Sounds like bad ballast. Unfortunatly this part is no longer available. the light engine will have to be removed and sent to Toshiba to be rebuilt.
Nov 26, 2009 | Toshiba 52HM95 52" HDTV Projection...
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
DARK PICTURE ON MY SAMSUNG DLP/HD REAR PROJECTION TV
It sounds like you need to buy a new bulb, this is what usually happens when the bulb is burning out this bulbs are made to last 6000-8000 life hours
http://www.discount-merchant.com/
Nov 21, 2008 | Samsung HLP4674W 46" Rear Projection HDTV
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Jun 08, 2008 | Toshiba 50HM66 52" Television
2005 RCA HDTV
Ok. no U can hear the audio for the channels?... this set has no bulbs to replace. does it shut down. does the front green light flash. if u push menu on remote does anthing come up?
Dec 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 55H70 55" Rear Projection Television Logo
244 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
