Question about Diablotek CX0656A Barebone
Powering up issue
I have 2 of these cases and when properly connected to 2 different motherboards I get zero, nothing, notta. I jumped pin 4 and 7 and the power supply fires up. Anyone have a wiring diagram for the power supply so I can see if it matches my motherboard? It should be industry standard but I am at wits end trying to figure this out
  • 61 Answers
Only guess I have is unplug the 4 pin connector from the MB if you used it, I had that problem with an Abit nf7-s, no joy until I found out the extra 4 from a 24 pin is NOT what hooks to the 12V boost connector on the MB when you only have a 20 pin main hook-up.
Sorry if this doesn't help.
Posted on Dec 29, 2007
Need the motherboard layout for the front panel connections for a Dell optiplex 790 desktop, to connect the +/- power switch, power LED, HDD LED to my new case
ok i lied, i went to RUSSIA for you (no USFF mentioned nor answered) ultra SFF.with 13/14 front panel jack.
all MOBO not USFF have 5/6 jack for powerjack
Power_SW labled.
http://pinoutguide.com/Motherboard/Dell_Optiplex_360_790_701_pinout.shtml
i see he does not know how to find ground.?
so pin 1 to 2 jump I guess.
pin 5 is missing keyed pin.
im guessing pin 4 is power 5vdc, for led a meter used, yes measure them.
one more way short pin 1 to case see if this turns on PSU.
if that fails short pin 2 to PC case, one of the 2 will work. I think.
there it is, reverse engineered by a great russian hacker,
thanks to MR, COsta.
Ps do not wreck the connector, use 2 arduino pinned jumper wires,
2 wires 2 pins, no damage to mobo , OK>?
Jan 07, 2017 | Dell Computers & Internet
My motherboard G31M3-F V2 doesn't power on nothing powers on enven the fans but the power supply seems fine what could be the problem
Best thing I can recommend is check your connections. Are all the power supply connectors plugged in? Your P1 connector, your 4-pin (or 6/8-pin) connector for your CPU?
Can you bypass the switch on your case and jump the power button pins on your motherboard to get it to power up?
Grounding could also be an issue.
What about your graphics card? Has it got the power it needs? Try the onboard or booting without it.
Hope this helps!
Mar 11, 2016 | Computers & Internet
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
Asus M4A785-M will not post. I have completely removed motherboard from case, removed all components except CPU (AMD Phenom II X4) and CPU cooling fan. When power supply (which I tested in seperate...
All I read properly .Please remove power supply from HDD and CD /DVD RW. If you face the same problem Open the mother board on a open place and try it again ,because there are some particles witch has made the short sercit in your M. Board.Cgeack all voldage socket plkaced properly,MAY BE CAN SILLY MISTAKE FOR 4 pin socket .
If you face same problem please install in another mother board .Post me please imediate next result.
Dec 12, 2010 | ASUS M4A785M (890552666775) Motherboard
CPU fan turns for a few seconds and stops, pc will not turn on. Have tried a good PSU, same issue. Removed all connection to motherboard apart from 20 pin, 4 pin power + cpu fan and PW switch: same issue.
1. First of all Remove dust from your CPU fan and try again if issue has been not resolve
2. Second test your SMPS by the help of Green & Red wire. In case fan is turning properly it mines your SMPS is ok
3. Third & last kindly replace your SMPS For the same.
Nov 19, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Help!
Page 26 of the below PDF should have your answers.
http://www.globalamericaninc.com/manuals/2801550.pdf
It might also be in your manual just on a different page?
Jun 21, 2009 | Intel 865G Motherboard
Two sets of power leads to motherboard from pwr pk, 1 x 20 pin and a 4 pin, when the 4 pin isn't attached to the 8s651mp-rz motherboard the fans spin, the mother board light comes on, but then does...
The 4 pin connector is required as it provides the power for the CPU to run. if nothing is happening with the 4 pin connector plugged in then there is a problem. You need to make sure that you Power Supply can supply enough power for what you are connecting to it (400W would be the bare minimum with no high end video card, 500W would be recommended). You also need to make sure that the Power Supply is connected properly because some Power Supplies from pre-built systems from companies like Dell are wired differently than the standard power supplies. The only other likely problem is that there is a short on the motherboard either from the mounting of the motherboard in the case or from something on the motherboard being bad. Make sure there is no metal touching the motherboard except at the holes used for mounting.
Jan 02, 2009 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
Changing my case
If you want to download the Manual for your Motherboard, I've included the link below. Otherwise I will provide a rough diagram of the Panel header for connecting your case to the Motherboard.
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=422&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
[2][4][6][8][10]
[1][3][5][7][ 9 ]
HDD Led
+ = 1
- = 3
Power/ PWR LED
+ = 2
- = 4
Power switch
Pins 6 & 8
Reset
Pins 5 & 7
RSVD (Reserved)
pin 9
NC (No Connection)
Pin 10
Hope this helps you
Dave
Nov 14, 2008 | EliteGroup K7VMA Motherboard
Hello I have a motherboard Asrock nothing works
check all possible connections from your power supply to the motherboard.
May 28, 2008 | Asrock M266A Motherboard
Ms9317e does not boot
you better go to last resource directly:
1. disassemble the system completely and take the mother out the case... Give it a perfect cleaning.
2. place the mother over a wood table or something like that (mother without anything but the cpu).
NOTE: if you are running onboardvideo do not connect external video board... if you are using external videoboard and do not have onboard video, you might have problems on the board... so you could need another one).
3. just connect RAM and power supply (the power supply must be out of case, placed over the table too and well connected to mother and to power line.
4. power on the system by jumping the pins on the motherboard... you can find them under the identification front pannel or something like that deppending on the model... just the pins that normally you attach to the cables that leads to the buttons on the front of the case. (use a screwdriver and do not touch anything on the motherboard with your hand if its connected to powerline).
then, and after trying vga adapter if you have one and trying rams one by one in different socks... you will know that if the system never boots up, you have hardware problems, either on mother, ram and less probably, power supply or very rarely cpu...
g luck, in this cases... better go live chat...
Mar 21, 2008 | Matsonic MS9317E Motherboard
Diablotek CX0656A Barebone Logo
82 people viewed this question
Top Diablotek Computers & Internet Experts
Donna Sander
Seanzilla
Are you a Diablotek Computer and Internet Expert? Answer questions, earn points and help others
