Question about HP w17e Monitor
It says "input not supported" whenever i change the resolution higher than 1280 1080..i changed my vga card to my onboard one...cause at least here i can see everything clear with the resolution of 1280 1080.But when i switch back to my nvidia 8400 series vga card...after my windows loading screen it blacks out and says "input not supported".I really need help right now..
    Sergeant:
  • 338 Answers
looks like windows does not know how to handle the monitor.
You may try to disable the onboard graphic card in the BIOS before
hooking up the monitor to the nvidia card. then try to run windows in safe mode(by pressing F8 when booting up), it'll run windows with the lowest available resolution, which will be supported by the monitor.
Now download appropriate driver for monitor, install and reboot.
That should do the trick
good luck
Posted on Sep 29, 2009
3 Suggested Answers
  • 3287 Answers
SOURCE: W17e says "input not supported"
Hi - here's what I found about your wide screen monitor:
The HP Pavilion w17e LCD wide-screen monitor has the following features:
  • 1440 x 900 factory-set resolution
  • Supports VGA analog signal video input
  • Plug and play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Energy Star compliant
Download & install the drivers for the monitor based on the version of Windows you are running from the HP site below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=pe&dlc=es&product=3377546&
Once the drivers are installed, your issues should be resolved - the driver will allow only the modes that can be displayed on the monitor - probably giving you options for resolutions you hadn't seen before.
  • 104 Answers
SOURCE: My w17e monitor says "input not supported"
Not quite sure what the question is that you have not already answered for yourself.
That monitor's maximum resolution is given as 1440 X 900 at 60Hz and installing a more powerful video card won't change that.
http://reviews.cnet.com/lcd-monitors/hp-w17e-lcd-monitor/4507-3174_7-32735619.html?tag=mncol;psum
JOAT
Posted on Oct 16, 2009
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Sep 20, 2017 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Tip
LAPTOP to TV Connection
Many people today want to connect their computer to a TV. Most HDTVs today have a VGA input for computer hookup. Most laptops also have a VGA output for external display. Using a male to male VGA cable, the computer can use a HDTV for a display. Sound is connected using a 3.5mm audio cable. See this web page for complete details.
http://columbiaisa.50webs.com/laptop_to_tv.htm or this webpage
http://sites.google.com/site/columbiaisa/laptop_to_tv
The screen resolution setting determines how much information is displayed on the display screen. It is measured horizontally and vertically in pixels. At lower screen resolutions, such as 640 x 480, fewer items will fit on the screen, but they will be larger. At higher resolutions, such as 1600 x 1200, more items will fit on the screen but they will be smaller. The resolution options will vary with each computer based on the video card device, monitor size, and video & monitor drivers. If the screen looks distorted or fuzzy, then you may have an incorrect screen resolution size set for your monitor. In Windows you can change the screen resolution to match the TVs capabilities. Go here to view a video on how to change screen resolution:
http://windows.microsoft.com/en-US/windows7/Change-your-screen-resolution
on Aug 23, 2010 | Televison & Video
My compaq computersceen says input not supported
i think your cpu settings you changed to high resolution. That resolution is not supporting by your monitor. If you have another monitor connect to that monitor to your cpu and change lo some low resolution. If monitor is not there try to boot in vga mode for that mode you need to press "F8" button on booting. It show you some modes select vga mode and boot and change the resolution and restart your system
Jul 05, 2010 | Computers & Internet
19LVWK (Black) LCD Monitor: input not supported -- I have tried F8,changing th...
No bent pins on the VGA cable? Bootup in safe mode, select VGA support and set the PC video resolution to he native resolution of this monitor, reboot.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | AOC 19LVWK LCD Monitor
JOAT
Sep 29, 2009 | HP w17e Monitor
Sep 29, 2009 | Acer AL1916W 19" LCD Monitor
My viewsonic Va712b monitor does not allow higher resolution than 800x600 resolution
ok, you need to know and to do
1) your monitor can be up to 1280X1050 resolution and automatch to destop one,
2) you need clean Rams first(reinstall Rams to make connection well)
3) the windows xp sp3 it can not support onboard VGA higher resolution without original motherboard video driver,
3) in this case your destop maybe lost the original driver so you need check the onboard video driver at hardware managment, there is a yellow mark at video device.then find a matched driver to update. still unfixed means your onboard video chips has some problem.and then
4) you may insert a AGPvideo card to AGP slot and install its driver should be fixed well.
hope to help you fixed it ,any question feedback to me please
May 10, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
Cannot get correct resolution
1. It could be limitation of your video card. Older cards would not support high resolution for LCD monitors.
2. Be sure to use DVI(digital) output from your video card. You will not get a good resolution with VGA(analog)
3. When installing driver for a monitor sometimes you will get a chose to install analog(VGA) or digital(DVI) driver. Choose the correct driver.
Jun 04, 2008 | ViewSonic VX2235WM Monitor
HP w17e Monitor Logo
265 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
