It says "input not supported" whenever i change the resolution higher than 1280 1080..i changed my vga card to my onboard one...cause at least here i can see everything clear with the resolution of 1280 1080.But when i switch back to my nvidia 8400 series vga card...after my windows loading screen it blacks out and says "input not supported".I really need help right now...By the way im using an hp desktop with a w17e monitor...
Once the drivers are installed, your issues should be resolved - the driver will allow only the modes that can be displayed on the monitor - probably giving you options for resolutions you hadn't seen before.
Probably your video card driver is out of date or not installed. Install the driver provided by the manufacturer or get it at your manufacturer's website. Also When changing to other screen resolution the frequency should be compatible. Try changing the frequency of your screen when it is in 1280x1080 to 60Htz then increase it slowly to see what frequency is compatible with that resolution.
Was this helpful?
Yes
No
Popular Solutions for Acer AL1916W 19" LCD Monitor
I've changed all the setting to Extra Large and nothing happens the fonts are still small in all my...
(More)
I've changed all the setting to Extra Large and nothing happens the fonts are still small in all my program, Simply Accouting and such
