Question about Epson Stylus Photo R260 InkJet Printer
Status Monitor says ALL ink cartridges empty
This printer sence I bought it new 7 months ago has been a great printer with great results and no problems with this printer even though I have used after market ink for it as I have for all my printers for many years without much trouble.
Today I turned it on and it said all of my ink cartridges were empty.
This could not be as I have replaced all of the cartridges within the last week.
I took all of them out and placed them back in and all showed fine but one which I took back out and placed back in and all again showed as empty.
I took the emptiest one and replaced it with a new one and it also showed empty along with the rest.
I took all of them back out and cleaned all the contacts with an eraser and wiped with a clean cloth and replaced all the cartridges and Still all showed empty.
I uninstall ed the driver and rebooted and with the new driver installed all still had the same results.
I replaced all the cartridges with a different brand of compatible ink and still the same results.
I then called Epson and they ran me through diagnostic. (everything I have already done),
and one last thing.
"What brand of ink are you using in your printer? Is it genuine Epson ink"?
No, I can't afford "Genuine Epson ink".
"Well, replace with genuine Epson ink and call us back and if it still does not work we will tell you what to do with it next."
I can buy a new R260 Epson printer for less then I can buy the "genuine Epson ink".
Anyone got any ideas other then the obvious?
HELP!!!
Thanks.
  • 5 more comments
  • JohnnyRudick Dec 21, 2007
    Did you see the cleaning pump described by another writer? (Excellent
    idea!!!) Look for it under "Epson Stylus Pro 4800" and if that won't
    work get another printer. Get another printer anyway and keep the pump
    handy;-)
  • haynaguy Jan 06, 2008
    I have an R280. The fist OEM cartridge to go low was Yellow. I replaced that one only. All others showeed between 50% and 33% full. Immediately after replacing the Yellow cartridge with a new genuine Epson cartridge the printer stopped printing and following diagnostics I found it now was telling me two other colors were in need of replacement. This is crazy. Epson ink already costs $500,000 a gallon and now they tell me a half full cartrdige has to be replaced??? I have a friend with an R260 who has similar experience. I think in their zeal to make people use OEM cartridges Epson has really screwed up an otherwise great printer to the point where it doesn't even recognize Epson cartridges properly.
  • Anonymous Nov 30, 2008
    Same problem with error. This is designed obsolescence. There is no such thing as "aftermarket ink" causing problems.
    All the chips inks timers etc.. have one purpose. Greed. Do the math ink from the manufacturer is $5000 a gallon. THAT clearly states why they take such steps.
    Why make a printer fail even if nothing is wrong with it (and there IS nothing wrong with it) thats easy. to force you to buy a NEW printer that uses a NEW style ink cartridge. No other reason.
    On older model printers I "reset" the components inside your printer require service error DOZENS of times. not ones not twice DOZENS of times.
    Waste ink? same thing reset DOZENS of times. I even took apart one once and yes the waste ink was all black but no where "near" spilling over or risking spilling over.
    Quality difference? Bull. No difference. I do a blind test you will NEVER be able to definitively determine which was printed with original or aftermarket ink. I know I do photographs for a living. I have a good eye for this stuff and I can NOT tell any difference.
    Magenta is magenta. this is not complicated stuff.
    Replace the printer every few cartridges? I burn through 50-60 CARTRIDGES A WEEK. The life span of our printers (epson's and canon's) is measured in YEARS.
    Hundreds and Hundreds of cartridges. My only impediment is DESIGNED obsolescence (these designed to fail errors) that I bypass. Otherwise the ONLY reason I replace a printer is #1 the print heads finally go and its too expensive or hard to find a replacement or I literally "physically" wear then out (drive motors pulleys rollers etc.. The most common is the paper intake mechanism just dies it can no longer "draw" in paper because I wore it out. thats after THOUSANDS of prints.
    NO aftermarket ink will NOT hurt your printer. Refilling is a royal pita I hate doing it.
  • mrogal0522 Jan 07, 2009
    Hi
    I also have an R260 printer and the same problem, the printers error message is that the cartridge is not compatible. I called epson and they sent me a cartrige genuine. Still the same problem. I really don't know what to do. My printer is one month after waranty and now I got to buy a new one. Sucks.
  • krystian123 Jan 16, 2009
    My epson stylus CX4600 just got its cartidges changed. The cartidge brand is LD any ideas why? And the printer is only about a year and its been great
  • Anonymous Feb 06, 2009
    Printer has been working fine and now it will not print at all.  It is telling me that all inks are out.  I know that is not true as they are all newly replaced.
    How do I get this thing to work.  I have disconnected both the usb and power chords and let it sit for a long while.
    Nothing.
    Please help.  Tim Morse 508-481-7200
  • Anonymous Apr 19, 2009
    epson Says cartridge empty when it is full
  • 3 Answers
I went through 4 EPSON Printers because I liked the quality of the print-outs. I wanted to be loyal to EPSON but I have changed my mind. Continuously reading, that parts in my printer are at the end of theit life expectancy made my think again. EPSON Printers are of inferior quality mechanically.
I am now owner of HP printers, where I always get a new printhead when I insert a new cartidge, aftermarket, refilled or not.
Get away from Epson!!!
Posted on Aug 05, 2010
  • Epson Master
  • 1,113 Answers
Using recycled ink cartridges in your inkjet printer is never a more economical way to do colour printing, unless you are willing to become a master technician on your particular product and have ready access to print heads and machine engine unit replacements, you will also need manufactures service software/website to reset waste counters/error codes.
It is expensive to print in colour full stop. Printing cost is at least 30cents inkjet and 10cents toner/laser per sheet
Laser b/w and colour is far cheaper per sheet, but setup costs are one time expensive but they are also a lot more reliable printing system.
Your machine will stuff up sooner rather than later when using non genuine consumable, and when it does it will cost more than the machines worth to even look for repair, so be prepared if choosing this road to purchasing a new printer every few cartridges if you are lucky.
If your using non genuine products and you want machine looked at by a professional the first thing you will need to do is install all genuine products in to your machine to allow correct fault diagnostics to be done, this is before any repair cost that maybe incurred.
Recycled/refills/aftermarket ink cartridge faults include – not recognizing ink, poor print quality, error codes, wont come to ready, erratic carriage movement, lines, waste counter issues and also paper feed problems, circuit board/connection faults caused by leaked ink .Not all faults are immediately apparent it takes time for the poison ink to replace that in the supply system then issues begin.
Cheap printing can be achieved using b/w lasers they cost less than 2 cent per sheet and have a brilliant reputation for print quality and dependability. Then if you need the occasional colour go to the shop, let them have the hassle, stress, time and expense of running the machines and the cost is still relatively cheap to you.
There are many consumers still printing with 10 year old laser machines, you would be extremely lucky to find a 3-5 year old inkjet.
If you must recycle well buy one that has already been proven to be adaptable to the concept, so that means go back to older units that went so clever.
Older Lexmarks, Epsons and HP were once easy targets, there was and is a lot of development gone into managing bulk ink deleivery systems, software has been cracked and parts can be sourced.
Inkmizer canon/epson bulk ink modified printers
Chipresetter be prepared for some frustrations and mess.
P.s. Most new machines come with starter inks that do not contain as much as new ones ussally 3ml instead of 5ml to enable cheaper selling cost, but also note that about 2ml of ink is in the tubes that run from ink carts to print head.
Posted on Dec 22, 2007
  • Soulvisitor
    Soulvisitor Dec 22, 2007
    People that need to do colour printing like more than 8 pages a day, should be using full colour toner based print systems.
    ie Oki, HP, Brother, and kyocera all have reliable systems
  • Soulvisitor
    The pump wont solve the issue on this machine, this machine has smart cartridges that are identified by the printer and they keep record of how many dots have been printed with each cartridge, once the upper limit of prints has been reached the cartridge shuts down from the printer thus disabling printing,
    Machine wants to see a new fresh chip on a unused cartridge to once again begin cartridge ink supply count.
    Check this maybe be what you need...Epson Stylus Photo RX260, R280, R380, RX580, RX680, RX595, RX680 Refillable Cartridge with "Always Full Chips"
    LINK
2 Suggested Answers
tom19511
  • 1601 Answers
SOURCE: Epson R260 ink cartridge problem (yes, with the genuine Epson ink)
Try this:
http://er.epson.com:8001/start
Posted on Feb 20, 2008
Black is full, colors are "low", refuses to print anything
If you have a look on this site you will see there are far more reported problems related to Canon than Epson however the choice is yours.
As to your cardridge problem. The Epson status monitor measures the amount of inkshots used by each cart individually. You know they have chips which indicate when the cart is empty and yet you have not bothered looking for a reset programme. Who's fault is that? The manufacture?
Give this a try, make sure to read the instructins before using.
http://www.ssclg.com/epsone.shtml
Sep 14, 2009 | Epson Stylus Photo R200 InkJet Printer
After 5 new cartridges computer recognises as empty Have been trying to get sence for days I need this to work have spent 70dollars on ink !!!!!!!
Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 21, 2009 | Epson Aculaser C1100 Printer
MP140, new cartridges - reading runout whilst still "new".
Its ok if the status monitor displayed empty ink that just a counter. when it say that ink run outjust press the resume button about 5 second and it will print with empty ink display on status monitor.
Mar 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
IP1880
YOU NEED TO DISABLE THE INK LEVEL MONITORS AFTER RE-FILLING THE CARTRIDGES. GO TO PROPERTIES, MAINTENANCE, VIEW PRINTER STATUS, OPTION AND CLICK ENABLE STATUS MONITOR ONCE. Also check to make sure that if you have only one cartridge that you go printer settings/maintenance/ink settings change to cartridge you will be using black or color.
Both of the cartridges have to be in there whether one is empty or not. Then turn off wait a few seconds then turn it back on. This worked for me. I hope is works for you.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
My Epsn Stylus PHOTO R300 says I need to replace an ink catridge however it does not tell me which one is out of ink. How do I find out which one to buy?
If an ink cartridge is empty, the red error light will remain solid. You can check the status of the of the ink cartridges by looking at the icons on the control panel. Press the down arrow button to scroll down to MORE OPTIONS. The level of ink will be shown on the screen and the ink that will be out will have cross on it.
Please follow the steps below to replace one or more cartridges.
***NOTE***
-You cannot print if any ink cartridge is expended.
-Leave the empty cartridge installed in the printer until you have obtained a replacement.
-To ensure good results on your printouts, we recommend using Genuine Epson Ink cartridges. Epson does not recommend the use of refilled inks or 3rd party ink cartridges.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
1. Make sure the printer is powered on, and not printing.
2. Open the printer cover.
3. Do one of the following:
3a. If the red error light is on (cartridge is empty) press the MAINTENANCE BUTTON.
3b. If the red error light is flashing (cartridge is low) press the MAINTENANCE BUTTON. You will now see the Cartridge Replacement highlighted in Advanced Settings. Select OK.
3c. If the error light is off (outdated cartridge), press the DOWN ARROW MENU button to choose MORE OPTIONS. Press OK, then select INK CARTRIDGE REPLACEMENT.
4. You will now see a message on the display telling you that the ink cartridge replacement will begin. Press OK to continue. The print head will move to the replacement position.
5. Open the cartridge cover. Press in the tab on the back of the cartridge, and lift the cartridge out of the printer. Dispose of it carefully.
6. Unwrap the new ink cartridge. DO NOT touch the green circuit boards, or remove ANY labels.
7. Lower the cartridge into the holder, with the green circuit board facing the front. Gently push the cartridge down until it is firmly seated.
8. If you need to replace another ink cartridge, repeat steps 5-7 above.
9. Close the cartridge cover. Press the front corner of the cartridge cover forward to lock the cover into place.
10. Press OK, and close the printer cover. The printer will begin charging the ink delivery system. Once charging is complete, press OK to finish.
May 23, 2008 | Epson Stylus Photo R200 InkJet Printer
LCD show "NO CARTRIDGE" after installing new ink cartridges...
next move: give to back due to guarantee. there is nothing what you can do!
Apr 08, 2008 | Brother MFC-5860CN InkJet Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Can't use compatible ink
You need a chip-resetting tool.
Or use the printers software utilitie changing ink cartridge, some printers insist that you go into your printer software/program. to inform or communicate with the printer, that you are changing a Cartridge. then the printer, will move the printhead to the desired position, to remove the cartridge.
When the new cartridge is installed, the printer is set to look for new changes. make sure you,ve inserted the cartridge fully into it,s slot ( holder ) push until you get a slight click.
If you,ve disabled Status monitor, then your printer cannot output the Cartridge Status. ( empty-Full )
mike @ Compurepair.
Feb 25, 2008 | Office Equipment & Supplies
All Cartridges show as empty though I know they are full.
You had it for 7, they have a 12month warranty, take it in for free repair.
Dec 17, 2007 | Epson Stylus Photo R260 InkJet Printer
Epson Stylus Photo R260 InkJet Printer Logo
1,931 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
