Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Hi, I have a side by side S20D RBB32-A/G Fridge Freezer with ice and water dispenser. The frezeer and fridge stopped working. I called a local repairer who took away a part for repair. However, the fridge and freezer are now working but the ice and water dispensers are not. I have turned off the power supply and emptied out the filter, this seemed to start the water going but only for 2 pints of water and then it stopped working. Could this be due to a blocked filter? Or is it something else? Anyone have an answer please.
  • 4,070 Answers
Try checking the mesh screen which is in the water line where the water supply connects to the water inlet valve on the back. It can get stopped up with sediment.
Posted on Sep 29, 2009
Do i have to hook up my refrigerater to the sink to get water an ice
Yes you have to connect the water pipe from sink to refrigerator back.hen turn ON the water valve o run the water from fridge to freezer section.Form freezer section to water inlet valve at the back of ice maker.Then only ice maker and water dispenser will function.Other wise only freezer and fridge will work.-------------- If you dont have water tube and water valve then You can get required parts from www.repairclinic.com or from online sears part site. If you are not aware of how exactly to set and connect water valve and water tube then local plumber or fridge repair technician can do it for you.Its not at all hard job and can be easily done.It will take near to 15 minutes to connect all parts.------------- Thank you.
Jan 31, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Temp in fridge side is too warm
Make sure that the air canal that runs from the freezer to the cabinet is not obstructed by ice or debris...
Jan 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
Fridge stop working
You need a volt/ omh meter or call a repairman.. need to start at the control board and check power going out of the board. sounds like a board problem with out more info
Sep 03, 2007 | GE PSS26NGPBB Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
283 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
