Question about Linksys Instant Wireless WMP11 802.11b
Wireless will not connect to internet after installing XP Service Pack 3. Router is a Linksys WRT54G2, adapter is a Linksys WMP11. Router is set to "mixed".
    Genius:
  • 1,112 Answers
Try upgrading the firmware for your routher and the linksys WMP11. Also try setting router to 802.11g instead of mixed to see if it connects.
Posted on Sep 29, 2009
I have a Linksy WMP11 network card along with a DLink WBR 1310 router. Everything is installed fine along with drivers. My connection is showing excellent/strong/100% but i can't connect to Intern
Enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
Jan 25, 2013 | Linksys Instant Wireless WMP11 802.11b
Fitted a Linksys-g 2.4 ghz pci adapter to my kids pc, take make their PC wireless, installed the correct drivers after researching what these were on the internet and all ok. Changed ISP and no longer...
If your modem(the device given by your ISP) connected the linksys router on WAN port just power down all devices and power on modem and make sure all lights are on and then power on linksys router. This should fix most problems. If no luck connect your computer to modem directly and check if you are able to log on to internet! If your modem is not working then your ISP is the best option to call!
Sep 11, 2011 | Linksys 2.4 GHz 802.11b Wireless - B PCI...
Show me how to connect linksys wireless
Hi
The Router configuration is not that much difficult, only few thing you have sure,
1) Correct ADSL Connection User name & password,
2) Chose unique ip address in All host.
Follow the mention bellow instruction to configure and connect to Wifi Router,
  • Plug the network cable ( Mine was Blue ) which comes with the Router Box pack to your computer. The other end goes into any of the Router Ethernet Port ( 1 or 2 or 3 or 4 )
  • Now type in 192.168.1.1 in IE or Firefox or any browser. You will prompted for password which is admin. You must be logged into Linksys Router.
  • Now since your ADSL modem is also having the same IP , we will change the IP address for WRT54G2 Router to 192.168.5.1
  • Under Setup >Basic Setup look for Network Setup and Change Router IP. Change to 192.168.5.1 and Save changes.
  • Since the IP has changed you will need to close the Browser.
  • Sometimes the IP doesnt change automatically. Do a IPCONFIG / RELEASE and then IPCONFIG / Renew
Making WRT54G2 Router talk to ADSL broadband modem
  • Plugin the Ethernet cable which comes from the Modem into the port on Wrt54g2 router which says Internet.
  • Open Internet Explorer and Type in 192.168.5.1.
  • Type in same password ( admin )
  • You will be in Setup > Basic Setup
  • Take a look at Section , Internet Setup. The current selection should be Automatic Configuration DHCP. Select Static IP instead.
  • Add following details to it. In the first step we backed up All the IP configuration. Use them here
Internet IP Address: . . .
Subnet Mask: . . .
Gateway: . . .
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3:
ADSL Modem Settings to Wrt54g2 Router
  • Once Done just save changes and you should be back at same page.
  • Now try to connect any application which talks to internet. You should be able to connect
Configuring for Wireless Connection :Now once your Router is talking with Modem, it is pretty easy to connect on Wireless. The only thing we need to setup here is Security. Lets get WIFI
  • Get to the Lynksys page again. Do all login and regualr stuff.
  • Now look for menu Wireless, click on it. You should land on Basic Wireless Settings.
  • Select wireless configuration to Manual .
  • Wireless network mode to Mixed.
  • Give a Wireless Network Name (SSID), make sure its unique.
  • Make Wireless channel selection 11 ( 11 - 2.463 GHZ)
  • Select Wireless SSID Broadcast to Enable
  • Save Settings and you will be back at the same page with changes you made.
Now Lets secure the Router :
  • Go to Wireless Security on the same page.
  • You will need to configure here Security Mode : WPA Personal, WPA Algorithms: TKIP
  • WPA Shared Key is what you will need when you connect to your router without wire. This key does the authentication and keep unwanted people away. Add 8 digit alphanumeric key.
  • As suggested in comments, there is a new mode which you can use : WPA2 with AES
  • Save changes.Just make sure you save that key to a notepad or remember it.
Wrt54g2 wireless security
  • Now last step, Move to next menu Security > Firewall .
  • Uncheck Block Anonymous Internet Requests .
  • Save Settings.
Wrt54g2 firewall settings
  • Remove the blue cable which you had connected with Router.
That's it. Now just turn on your WIFI and Search for the router. The name should be visible. Click to connect. At this stage it will ask you for the Password or Shared Key which we configures just above. It will connect and you will be able to connect to Internet.
That's all Folks. This is how you connect WRT54G2 Linksys router with Adsl Broadband Modem. If you have any questions feel free to comment.
Aug 03, 2011 | Linksys WRT54G2 Wireless Router
Steps to configure linksys wireless router
GO TO LYNKSIS AND SEARCH FOR YOUR MODEL INSTALLATION.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 08, 2011 | Linksys WRT54G2 Wireless Router
I have an old laptop that has a linksys wireless-b notebook adapter and my new computer with a linksys router attached is a linksys dual-band wireless-n. I can not get the notebook to link to the router...
Most of the newer routers use a newer type of encryption (WPA or WPA2) which is not supported by older 802.11b hardware.
Either set the Linksys router to use WEP encryption, or get a newer 802.11g card for the old laptop which can use WPA or WPA2 encryption.
Older versions of Windows XP also need to be upgraded to Service Pack 3 or apply this patch:
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=662bb74d-e7c1-48d6-95ee-1459234f4483&displaylang=en
Mar 22, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
Connect a router
Are you trying to set up the router ?
Or you are trying to connect to the wireless network.
It is very easy to set up the router.
I hope the following link will help you
Click Here for step by step solutions
Nov 06, 2009 | Linksys Wireless-G Broadband Router
Does router wrt160n have both 2.5GHz and 5GHz
Hello Bill,
The problem sounds like you have the router set to WPA security. The WMP11 cards do not support this security standard, they only use WEP 64 bit and 128bit. If you attach to the router with your vista machine and go into the configuration settings and change the security level to WEP you should be able to get online.
Buddy
Jun 18, 2009 | Linksys Computers & Internet
Cannot connect to the internet with my laptop
To connect to the router wirelessly using a Windows XP, right click on the wireless network connection icon on the lower right corner of the screen and choose view available wireless networks. Select your existing network and click on the connect button. If you are using Vista, go to network and sharing center of your control panel then select connect to a network. If you still having problems, please provide details of the problem like your Internet service provider and if there are already other computers online with your WRT54G2.
Jul 11, 2008 | Linksys Ultra RangePlus Wireless Routr...
Linksys Instant Wireless WMP11 802.11b Logo
128 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
