Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Cable conectors ?
Can I connect my Cable connection through a different way as i broke the cable connection part
  • 205 Answers
If you're using a cable box from your cable provider it may have output in both the RG cable and composite connectors already. Are you using a cable box? If you are, look on the back and see if you can find a group of red/white/yellow sockets labeled something like "video out" or "output". Whatever you do, you'll need to change the video input source on your TV.
Good luck.
Posted on Dec 19, 2007
  • ohiotom Dec 19, 2007
    I see now that I was repeating what willtab had suggested...I should have read that post more carefully. I'm glad you were able to solve your problem.
    Genius:
  • 1,030 Answers
Yes just run your cable through a vcr. then to input such as a composite or component vid. or most cable boxes have composite out.. THE yellow cable. Then on your set switch to that input. ...
I have a samsung tv model le23r88bd i want set up cable but the tv have a diferent cable conector that i need it a adaptor?
Need more info can u post a picture of the back of the tv and the type of cable your trying to connect?
Mar 25, 2014 | Televison & Video
Dvd/vcr recorder magnavox model mwr20v6, i got probelm hooking up my dvd/vcr recorder to my cable converterbox an tv , because i broke the antenne/ out socket on the back of the unit, how can i get it to...
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well..
Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
** in order to listen and watch your
magnavox DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected ) (audio will come thru Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on
magnavox
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has different type of Audio out jacks )
** to "iRCA nput or "Optic Cable input"
of your
magnavox (whichever you want ,based on the necessary cables on your hand )
There you go..Tv/Cable box video and sound are both on the
magnavox for recording..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | Televison & Video
I keep getting "Cable not connected". I have
That unit is Defective, you need to call it in for an RMA. the cable broke because of moving the tray in and our of the rack and some or all connecting cables broke. The unit has to be send in and the cable has to be replaced.
Feb 25, 2011 | Avocent 1U Rm 17IN LCD Single Rail with...
Cable connection in rear of TV broke off.
This problem will have to be taken or shipped in to a service center for repair or replacement of the cable connector on the main board. The telephone number for Insignia customer support is 1-877-467-4289. and the website is www.insignia-products.com. You can also call the Best Buy customer support telephone number. 1-888-237-8289. Give them you make and model number of television and the problem you had with the broken cable connection.They will be able to tell you how you can get service for your television. I hope this information helps you with your problem.
May 02, 2009 | Insignia IS-LCDTV32 32 in. Television
Cable connecter broke off?
It would probably cost more to have someone fix it than just replace it.If you or someone you know can use a solder iron you might get lucky and resolder conections, but most times its too hard to get at the circuit board to affect repairs and the connector usually gets mangled so bad it won't fit right anymore. Or you can try to avoid using this connection and use a different input. But you would need either a cable/satellite box or vcr (with the same kind of connection that broke on TV) and change the input used on the tv to the new connection such as 3 wire AV connection (with the yellow,red and white wires)
Apr 26, 2009 | Sharp 25H-M60 TV
Can't receive faxes
well... check the telephone cable or conector...Rj11 conectors...
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Battery Cable Replacement help?
whell now you have two problems but try to jump start the car and let me know what happens, also did you replace the batterie cable with the conector at batterie? or just the cable, if it was just the cable remove the conector and clean it inside
Jun 21, 2008 | 1993 Chrysler Lebaron
Won't show cable channels
First thing I would try is taking the set to a different location where you have cable and see if it works,if it does not make sure the conector in the back is not loose,make sure the cable you have selected is the standar cable and not another kind like HRC or other and last the set might have a tuner problem and for that you will need assistance from a servicer.
Sep 26, 2006 | Toshiba MD13P1 13 in. TV/DVD Combo
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
