Question about Grundfos MQ3-35 3/4 HP Pressure Booster Pump
I have a grundfos pump for my bore. It stopped working a few of months ago and we pulled it up, gave the propella (?) a spin. Tested it and it was working. Lowered it into the ground and it worked fine until yesterday. It has been maybe 3 weeks since I had turned it on and it is not working. So I have pulled it out again. Before I get a new one I would like to know whether they cn be fixed. The pump man I had out this morning said no, get rid of it!
  • 990 Answers
I'm not fimular with this pump but if you can spin the impeller (propellers are on airoplanes) and the motor will start and run it could be a start capicator. This stores elect. and gives the motor a bump in power to start.This will usually be found in or around the wireing box on the motor and should cost about 20.00- 30.00 dollers. You will need to find a service manuel for your pump and the motor that drives it. Good Luck with it, sorry that's all the help I have on that one..
Posted on Oct 05, 2009
Had a ideal i35 boiler fitted 7 months ago. The grundfos ump3 pump has failed 4 times and has been replaced by ideal tech. The pump has failed again,ideal refusing to attend. Any advise appreciated.
ideal are required to fix under warranty any part that continually fails
(check with a lawyer)
as it is a possible design error or improper installation, the company is obliged to rectify the problem
while grundfos is the preferred installation pump and the problem is related to the pump the company in an effort to ensure customer satisfaction should be making an arrangement to fit a different brand of pump or rectify the cause of the pump failure
as I stated --discuss the matter with the company and a lawyer to resolve the issue
Oct 26, 2016 | Grundfos Plumbing
Grundfos booster pump has been revving higher than normal and just stopped working completely. Now it hums on and off a few times and eventually alarms
Over revving is normally caused by air in the pump, or that the impeller has broken off. In you case I think it is the latter and the broken impeller is jamming the motor and that is what is causing the hum. The only thing to do is remove it and strip it down.
I used to live in Leighton Buzzard where the head office is, and have a friend who works for them.
https://www.grundfos.com/
Apr 01, 2016 | Grundfos Garden
Grundfos pump problems
I've just had a ideal i35 boiler fitted, the grundfos ump3 economic pump has failed / seized and has been replaced 4 times since the boiler was installed 7 months ago.
It has just stopped working again and ideal are refusing to attend.
any advise would be appreciated.
Aug 14, 2014 | Grundfos Pumps Grundfos UP15-29SF 1 12 Hp...
Can this pump be repair it just stop working
I don't think it's economically feasible to repair these pumps. But the problem may not be with the pump, it may be with the control box. A new control box is about $90.00. How to Test Well Pump Control Box eHow
May 18, 2014 | Grundfos Pumps Grundfos 22SQE15-220...
Grundfos runs intermittently and needs power cycle to get going again
What type of pressure switch or pump controller on pump? Could be capacitor check. with power on try spinning fan at rear if starts probably cap. Have it checked. Could be controller faulty.
Jan 27, 2013 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Grundfos stopped circulating.
At approximately $238.95 new, it pays to do a bit of troubleshooting.
Below are some sites that may help:
http://www.plumbersurplus.com/Brands/Grundfos/74
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
There are no repair parts for these pumps, and nobody at Fixya has reported taking Grundfos apart and repairing it.
Jan 21, 2013 | Grundfos Comfort System Recirculator ...
Need to find a link to the owner's manual/ repair manual for the Grundfos up10-16 b5/atlc......
Following link shows links to grundfos and grundfos manuals.
1) My grundfos stopped working because sediment clogged the pump, and the motor slowed.
When motors slow, they get hot and burn up.
I ask my friend who rewinds motors how to fix it, he said in the old days, they rewound every motor, but today they throw valuable scrap into landfill, and then buy new motors from China.
I told him not to retire, but go to school and teach kids how to rewind motors, and then took apart the grundfos line and cleaned it out with CLR, but it never worked again.
2) If timer stops working, but pump still works, you can buy cheap plug-in timer and connect grundfos to the cheap timer
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Grundfos UP10-16B5/ATLC Comfort Series...
Timer gets off by hours
I have circulation system on my water heater.
First system gave out.
When taken apart, it was clogged with sediment and couldn't be cleaned.
Put sediment filter on line, and second circulation system works fine, and timer works fine too.
I haven't had timer problem, but have investigated timer motors running fast and slow.
My friend who re-winds big pump motors says homeowner timer motors are engineered for 60Hz.
As long as electric power is 60Hz (60 cycle AC), then motor will keep exact time.
Since your household current is 60Hz and other electro-mechanical timers run correctly, then it's likely timer motor has a flaw or has gone bad.
Grundfos water heater re-circulation pump and timer are sealed unit.
Grundfos manuals do not show parts list or repair steps:
It's aggravating when expensive household timers like Malibu power packs and Grundfos pumps are not made to be repaired.
Nov 24, 2010 | Grundfos The UP1510B5ATLC 125th HP 1...
My 39 month old pump stopped working today. Can
Any dealer can repair it. These pumps have a long life.
Dec 03, 2009 | Grundfos MQ3-45 1 HP Pressure Booster...
Grundfos MQ3-35  3/4 HP Pressure Booster Pump  Logo
240 people viewed this question
Top Grundfos Garden Experts
john h
jasbo
jasbo
Audrey Messer
Audrey Messer
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
