The machine was working properly until 1 day ago. Now, the tub is not balanced. It leans forward so the water entering the machine cannot get the rim of the tub. This is especially pronounced during the rinse, spin cycle. One of the springs was broken so I fixed but bi matter what I do, I cannot get the tub to position itself so the water won't engage the rim Should I replace the other springs? Is there a way to square the tub so it doesn't tilt towards the front right of the machine? Thank you.
  • bbreichner Sep 29, 2009
    Sorry, it's a Roper (whirpool)
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Is this a hotpoint?..Change both springs
Posted on Sep 29, 2009
Load won't balance on an LG model# wm2655hva and machine is level
Washing machines are made to have there main tubs hang from spring hangers. If one of your rear springs have come undone it would allow the main tub to lean to the back of your machine. This in turn will make your inner tub lean towards the rear of machine i.e. balance being off. Yes your machine is level ,but the tubs are not. Check. Good Luck Friend.
Oct 22, 2017 | LG Washing Machines
Whirlpool refridgerator ice machine mod.ED2PHE water will not come into ice machine. it was working fine until 2 days ago.
check water line is open, check filter seated properly,make sure of on/off lever or switch or turn off water supply to fridge and check line for possible clog, and also on filter
Jan 24, 2013 | Whirlpool Refrigerators
Washing machine off balance in one cycle
Make sure washer is on a level surface and all four feet adjusted properly. A slight forward lean may help with this problem as the out of balance switch is at the rear.
Feb 28, 2010 | Washing Machines
While my kenmore top load washer is pumping water into the tub, water is splashing from the rim of the tub and leaking behind the tub onto the floor. If before I turn the washer on I push the tub towards...
if it keeps failing into that position
then either your machine nneds to be releveled or there may be someting wrong with the suspension but with this model i would have to believe your machine is out of balance tword the front
relevel and try that.
Oct 27, 2009 | Washing Machines
Tub gets off balance during spin cycle
also,shorten front legs,lean washer forward,and reset back legs.level.
Feb 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer leaks from rear. The hoses are perfect.
Hi .If you look, the tub is leaning towards the front . Theres a counter balance spring that has fallen off. remove the cabinet, to gain access, and replace the spring
Dec 23, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Washer LSQ9645KQ0
The washer has the sound both times but not all the time. I THINK we found all the pieces but now that you mentioned it, perhaps not. Are you thinking there may be a piece lodged somewhere and making that noise?
di_marie60
Aug 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer
There are a few things that can cause this issue.
1. The counter balance spring broke or the mounting hole for the spring rusted through.
2. One or more snubber pads may have come off.
3. The balance ring may have come loose from the basket or the ring has been damaged and the fluid has leaked out..
Start by removing the shell as follows:
A.) The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw.
B.) With console lifted you will find a lid switch connector (white in color). Unplug the switch from the connector.
C.) There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
D.) Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
1.) The counter balance spring is located in the bottom rear. It should be attached between the cabinet and a bracket on the tub.
2.) Inspect snubber and corner pads. May be brown or white in color.
3. Remove tub ring by pushing down then lifting each locking tab.
Inspect balance ring for proper fit and any cracks. By moving/shaking ring you should hear liquid sloshing around.
If you need further assistance, let me know
Regards,
reg501
The FixYa Team.....
Jun 26, 2008 | Kenmore 15864/15862 Top Load Washer
Leaks water frim front of the machine
make sure the tub is pushed back , not leaning foward. this fills from back of tub possible splashing on and over the tub rim, anorhersource of leak could be from pump assy removing front cover and lookng at pump will tell (if its been leakin its quite obvious)
Feb 24, 2008 | Whirlpool LTE6234D Top Load Stacked...
Odor when starting cycle
Check your water softener(If so equipped). This can cause foul odors in the water supply if not properly balanced or maintained. Good luck!
Sep 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
