Question about Edimax BR-6104K Router (br6104k)
How do I set security network on my Edimax (i.e. to allow new connection of a client only if a password is provided)
I've been trying to figure out this problem and solved the darn thing just in time.
This is what I did --> http://zeebigtourist.blogspot.com/2009/11/just-addendum-to-my-previous-post.html
Thanks for all the helpful info, FixYa.
ZeeBigTourist
Posted on Nov 10, 2009
What is a wps button?
Wi-Fi Protected Setup (WPS)
It is a network security standard that allow users to easily secure a wireless home network, and connect wireless client devices (iPads, smart phones, etc.) to it, without accessing the router configuration screens, and without the wireless network security key/passphrase/password.
Mar 18, 2016 | Canon Pixma Mx922 - Multifunction Fax /...
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
Edimax BR-6424n router wireless works fine with
This could be because the encryption settings in the wireless router has not been entered into the wireless card configuration. To secure your wireless network from unauthorized access, please click on this link and follow my instructions to configure the wireless router and the wireless card in the laptop/computer :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jun 25, 2010 | Computers & Internet
How do make my router secure when its states it unsecure
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to set up password for my edimax wireless router?
you want to secure wireless network.
is there any other computer connected to the router with the ethernet cable?
If not then you will need to connect the computer to the router with the cable.check the ip address on the computer.open the router set up page.
you will find the option to make it secured.
Click here for more info
Oct 22, 2009 | Edimax EW-7206APg (EW7206APG) 802.11b/g...
I dunno ow to secure my connection with my edimax router
You can read more about WEP and WPA in the following links:
This article explains how to configure WEP/WPA-PSK/Access list on NETGEAR Wireless router (also applicable to access points).
Note:
  • You can configure WEP or WPA. But you cannot enable both at the same time.
  • You can configure Access list and also enable WEP or WPA for additional security.
  • After you enable wireless security features on the router (or access point), you must configure your wireless clients (wireless computers) with matching settings. Your wireless clients will not be able to connect unless you configure matching settings.
  • Its recommended you enable these wireless security settings from a computer wired to the router (or access point).
Configuring WEP:
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  4. Under Security Options, Select WEP (Wired Equivalent Privacy)
  5. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
Apr 27, 2009 | NetGear WGT624 Wireless Router
How do i set a password?
Follow these rules for a secured WLAN
connect to your router as admin using Lan cable.
Set A router password. (if not already set)
Change your SSID from standard name
Consider do not broadcast SSID
In wireless setting select WPA-PSK security protocol
Create a Passphrase to be used as key (write it down)
save and use new setting in every connected device of this network.
I recommend first broadcast your network with WPA-PSK password.
Find your network with your clients (PC, Console, print server) use pw to connect in secured way.
Be sure to set client network properties to "connect to this network even if not broadcasting"
For increased security modify your network in Router to "No broadcast"
Jan 10, 2009 | Belkin Wireless-N Wireless Router with...
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
Edimax connection options
Make sure that when you connect, you?re signed in as ADMIN and not a USER. If that isn?t the problem, check in system preferences if the connection has to be secure or limited in any way.
Feb 22, 2006 | Edimax BR-6104Wg 802.11g/b
Edimax BR-6104K Router (br6104k) Logo
96 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
