Question about Lexmark X6170 All-In-One InkJet Printer
Our lexmark X6170 was getting error code 502, now it won't power off. I unplug and plug in , unit powers on and does nothin
map9966
  • 2351 Answers
SOURCE: Error C50 on Lexmark X6170 printer
You correct about that dmattia! Most manufactures put small chips in the ink cartridges. The driver software knows when you have inserted a re-filled "same cartridge". Hence you get an error.
Theres one way around this wall.
Keep at least two emptied cartridges. (Prefered three).
Go ahead & refill them & store them standing up so the nozzle does not dry out. Rotate your replacements. This works with HP's printers. With the HP's printers it's suggested to rotate three cartridges. This should work for Lexmark as well.
Enjoy!
& please vote.
Posted on Mar 08, 2008
SOURCE: lexmark error message hardware error 0502
the printer cartridges go all the Way to the right and hit the side
with a bang sound. Then i get the [0502] error and i have tried everything posted on this site and others.
Posted on May 21, 2008
don_farr
  • 1011 Answers
SOURCE: Error Code???
The 0502 error can be caused by four different issues:
    1. A contaminated encoder strip
    2. An unseated encoder strip
    3. A faulty black/photo cartridge
    4. A faulty color cartridge
Your best look see at the problem would be www.lexmark.com >technical support> Model name >FAQs
Posted on May 04, 2009
don_farr
  • 1011 Answers
SOURCE: Error code 2200 and loud siren on my Lexmark 7170
Please follow the link below to Lexmark's Technical Support web page.
http://support.lexmark.com/index?page=content&id=SO3533&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_X7170&searchid=1264183239432
Don
Posted on Jan 22, 2010
pineworks
  • 4041 Answers
SOURCE: lexmark X6170 hardware error 0502
Hi there
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Somehow it presents a drag on the cartridges and causes an error.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Lexmark X6170 shows cartrige error error 50C how do I correct the problem
Please follow the steps below to fix the issue:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 15, 2011 | Lexmark X6170 All-In-One InkJet Printer
I have upgraded to Windows 7 and my Lexmark X6170 will print but not scan. I need the scanner badly. Please advise on solution.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 29, 2011 | Lexmark X6170 All-In-One InkJet Printer
X6170 will not scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Disconnect your printer from your computer. Reboot your computer. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to scan again. Also, make sure the Lexmark OCR scan software is installed on your computer. The scan software is available on the installation disc that came with your printer.
Jun 26, 2011 | Lexmark X6170 All-In-One InkJet Printer
6170 I HAVE A ERROR MESSAGE STATEING 50C CONSULT USER GUIDE AND I DO NOT HAVE A USER GUIDE
Hi. The error tells you that your print cartridge has shorted. Here's a link to the Lexmark website to give some instructions on how to remedy the problem. Just click on this link: http://bit.ly/aSWvpk . Good luck!
Mar 23, 2010 | Lexmark X6170 All-In-One InkJet Printer
It keeps saying hardware error 502. Help
Hi
It is the rod that the cartridges travel on. Just wipe this rod with a Kleenex and the
Other thing you could try is to lubricate the bar that the carriage
Jan 31, 2010 | Lexmark X6170 All-In-One InkJet Printer
What is an error message 502?
  • A contaminated encoder strip
  • An unseated encoder strip
  • A faulty black/photo cartridge
  • A faulty color cartridge
If the printer is still under warranty, it is best to replace it, as error 502 is usually recurrent. Otherwise, please follow the link below to the Lexmark website for a detailed troubleshooting guide for error 502:
I hope this helps.
Nov 19, 2009 | Lexmark X6150 All-In-One InkJet Printer
I have a Lexmark X 6170 all in one printer and I get error 50c
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Oct 20, 2009 | Lexmark X6170 All-In-One InkJet Printer
Reattach encoder strip? Lexmark 6170
Hardware Error 502:
Cause: The All-in-One is stalled.
  1. Press Power to turn your All-in-One off.
  2. Unplug the All-in-One.
  3. Check for paper jams.
  4. Plug in the All-in-One.
  5. Press Power to turn the All-in-One back on.
Thank you for using Fix Ya!
Have a great one!
Dec 27, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 All in One Printer
So many things this could be. I would try the basics first. Turn it off, unplug it, see if it resets itself. Is the power supply it is plugged itno ok? You can test this by trying thr printer from another socket. Power boards are notorious for shorting out with lots of equipment attached. If it is plugged into a powere board try resetting the boards switch too (make sure all is unplugged first!!! Next if no good i would try uninstalling it and reinstalling it. If you do not know how to do this let me know and i will talk you throught this. This corrects alot of issues. WE can explore other issues if these things do not work. I am hoping it is not the power supply that has died on thr printer.
Sep 13, 2008 | Lexmark X6170 All-In-One InkJet Printer
LexMark 6170 Encoder strip came off
unplug the unit. Move carrier to middle. Gently press down on either end of the carrier, you are moving it down and a bit forward then let it go back up, this will get it back going again. It should now be back in slot. cheers lilacgerry xxx If you get error 502 or similar, clean the roller and coating with a lint free cloth or unscented wipe.
Jan 15, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
104 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
