I have an older Maytag model #WU482. For some reason it will not drain and will only run using the economy mode. I can hear the timer ticking at all other cycles and it does click between cycles. I recently replaced the drain float and the machine had been working fine after. The motor is working and the belt is good. I think the kids were playing with the timer knob. Could this cause a problem with the timer motor? Or does this sound more like a pump out issue, impeller? I'm thinking its the timer motor since only one mode is working, dry cycle also works.
First,inspect the drain float. Make sure it rides on the micro switch correctly or it will not take on water.Check the float micro switch for continuity. Check for power at the water valve when it calls for water. Remove the wire harness from the timer and re-install it. Make sure you get a good tight fit,they can become loose over years of use. If that does not correct the problem I would suspect a bad timer.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Maytag 24 in. PDB1420 Built-in
I have a Danby portable dishwasher model #DDW396W. There is standing water in the well of the...
(More)
I have a Danby portable dishwasher model #DDW396W. There is standing water in the well of the dishwasher and its leaking out on the bottom when dishwasher is on.
food still on the dishes, what detergent do you recommend, I have been using Cascade (which is...
(More)
food still on the dishes, what detergent do you recommend, I have been using Cascade (which is recommended for our water) but now all their product has "Dawn" added, and consequently my dishes are not coming out clean. Ours is an Ultra Wash Kenmore dishwasher model #665.1372. Thank you
Asko model 1885 dishwasher will not turn on, no lights shown, I checked the power to the machine,...
(More)
Asko model 1885 dishwasher will not turn on, no lights shown, I checked the power to the machine, and it is ok....can you help?
I have a gallery FDB679GFC2 that is acting like it is stuck in heat delay and not cleaning the...
(More)
I have a gallery FDB679GFC2 that is acting like it is stuck in heat delay and not cleaning the dishes and the heating element is not heating
AFter my load of dishes has gone through its cycle and dried I still have water in the bottom of the...
(More)
AFter my load of dishes has gone through its cycle and dried I still have water in the bottom of the dishwasher, about 12-15 cups..What is causing this and how do I go about repairing it. Thanks.
