The light went out. I replaced the bulb but it did not do any good. The fan runs, but no light. I don't know what to try next. Yes I made sure the lid was attached completely.
  • 1 more comment
  • ans7b Sep 29, 2009
    I have an overhead projector, but could not find a catagory for it so I chose office equipment.
  • ans7b Sep 30, 2009
    Your last comment, were you speaking about the overhead projector (which I have) or the copier with a scanner which you first mentioned?
  • ans7b Oct 01, 2009
    Thanks. I won't be able to tell you if it works until tomorrow. I have to go home to read fixya comments. Our firewall blocks it. I don't know if the switch was facing the column or not. I did replace the bulb with the cord plugged in. Then I tried unplugging it and removing the bulb, then replacing it with the cord not plugged in.
  • 11,896 Answers
Either ballast is bad or power to ballast is not getting there due to faulty capacitor. You can get a voltmeter and test power from power supply and also the power from ballast to light bulb. check to see if fuse is good.
Posted on Oct 02, 2009
  • 360 Answers
What brand of copier is this? You may need a service adjustment or repair. If I knew what kind of copier it is I could look it up and decide possibilities.
Posted on Sep 30, 2009
  • 3 more comments
  • Richard Klein
    Richard Klein Sep 30, 2009
    Yes, your posting didn't say anything about an over head projector. That is fine though, I also work on projectors too.
  • Richard Klein
    And the changer knob is in the correct position. The instructions said,
    1. Disconnect power cord
    2. Open the stage frame, and the main switch knob in the direction of the column.
    3. Replace defective lamp.
    4 Close stage frame until it clicks.
    Note: Make sure to insert lamp is firmly into to socket. Make sure not to touch any part of the mirror.
    I'm sure you know these parts have to go back exactly. There is two electric safety component inside the projector. It is very possible that one of these electric devices failed when the bulb failed, or what caused the bulb to fail.
    The troubleshooting section say's, that either the new bulb was bad , wasn't put back together right, or needs servicing. Let me know if this helps, and what I can do to help you more.
  • Richard Klein
    Richard Klein Oct 01, 2009
    Is there any way we can go back over the steps, and see if we can get it back on?
  • Richard Klein
    Did you notice any differences with the bulb?
  • Richard Klein
    Did you unplug it before the procedure of replacing the bulb? I'm might have to shut the machine off and On to get power back too.
  • 19,396 Answers
The question had been posted in copiers, therefore I guess you are talking about the Scanner Lamp in your copier.
If you replaced the scanner lamp, and copier is operating, lamp moves, but does not scan, then you have a fault that can concern the high voltage circuit powering the lamp or main control board.
If instead copier is not operative at all, and stays in standby with error mode. Then either the copy counter must be reset, the lamp is not well assembled, or there is a different fault.
Posted on Sep 29, 2009
  • Ginko
    Ginko Sep 29, 2009
    There is a board, or a circuit integrated on main board, depending on the model. This board supplies high voltage to the lamp. When the board is faulty, the problem may be confused with faulty lamp.
    The board must be tested by a technician. Mainly the test is done reading high voltage to the lamp, and DC voltage to the board input.
Brake lights ceased working.
-Make sure the correct fuse.
And did you check the bulb? If yes the bulb are good.
-next check power at the bulb. Ask a helper to help you brake and
check any power there or not. If yes there is power. Then the problem is NOT Ground.
Good Luck
Mai
Nov 11, 2013 | 1998 Ford Laser
I have Hunter ceiling fan / light. I installed it. It worked fine for a little while, than one bulb blew out, then a second bulb blew out, now none work. Yes I repaced all the bulbs, still don't w
I would check with a voltmeter if you can safely to verify power at the light socket using an adapter to a plug in it. If you can not do that, with power off you may want to make sure that the socket contacts are good and clean. Sometimes they can become tarnished badly.
Oct 10, 2012 | Hunter 23852 Classic Original Ceiling Fan
Fan works fine, lights don't. Could it be the remote?
Had this happen to me and it was a hunter fan. Similar problem. Fan worked,lights went out. Took light bulbs out, lowered the light fixture. Tested power coming from the ceiling to the quick connect pins for lights. The power was good. So the Problem's in the light kit. Turns out the government requires all new fans to have certain wattage to lights, set at 190. So 3 60w bulbs or 4 40w. Inside the light kit is a limitor hooked to the black power wire coming from the quick connect,It is smaller wire and mine was pink into limitor and white coming out. Not very big. This went bad so i called Hunter, sending new light kit, but I just wired straight black to black wire bypassed that limitor and lights work fine
Aug 29, 2012 | Hampton Bay 24750 Huntington III Ceiling...
Aveo radiator fan FUSE
You never replace a fuse that blows with a higher amp one . That's a good way to set your car on fire ,melting wiring etc.... The fan isn't blowing harder ,drawing to much current . lower resistance in the circuit .
Why is all this happening.????? Because you have electrical problems . Do voltage drop testing on the problem circuits , testing with a DVOM - digital volt ohm meter .
Where did you fine this fuse for The radiator fan is blowing to hard and is killing the fuse.So went from a 10 to a 15. My service info states it take's a 30 amp fuse . An it has two cooling fan relay , an a droping resistor . Unless your mixed up on your fan's , Heater blower motor fan ? From reading your post , i'd say you don't know anything about automotive repair . Suggest you take your vehicle to the dealer . We know your vehicle better then anyone else .
Mar 20, 2017 | 2006 Chevrolet Aveo
Is there a dash light for the gages because replace ignition switch and key and still no display.
Yes, normally there is small bulbs at the back that light up the gauges
Jun 22, 2011 | 1989 Mercury Cougar
The red light was on solid, and the manual said to replace the lamp. I bought a new lamp and put it in, but still no picture. The fan comes on, it tries to power up and then in about 20 seconds the red...
these TV's have lots of problems. Don't waste your money on repair. But towards new one or you will be constantly replacing parts.
But anyway sounds like a power supply or light eng problem. If all measurements are good then the chassis needs to be sent to Mitsu for repair (approximately 140 updates to it).
Feb 26, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Hello. My desktop seemed to have completely froze (power was running and sounded normal, but did not respond to mouse or keyboard commands), so I shut it down by holding the face button. Now when I power...
Please Clean Processor Fan By removing dust from the cooling went ( make sure the air should be transfer through the cooling went from the fan) Then Apply the Good heat sink Paste on the processor then try
In this process please don't touch the processor fan while the sys is powered on or running
Dec 26, 2010 | Compaq Presario SR1000T (568657) PC...
H ave a sony kdfe60a20, just replased bulb and fan for bulb, watched for about 2 hours then tv went dark. Now I have a blinking red light. blinks 4 times pause 4 times continuously until I unplug the tv....
4 times red standby light indicates problem with exhaust fan that is not running for some reason.
Recheck fan that you replaced and make sure its connector is plugged properly and it running freely.
4 times red light blinking is fan error in this tv.
Thanks.
Nov 03, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
02 Pathfinder back lights just died
Some times when you get a short circuit. It will burn out a tail light bulb. With the bulb burnt out you don’ have a complete circuit. First, replace you tail light bulbs. If that doesn’t work. Check to see if you have a ground wire come off.
Jul 11, 2008 | 2002 Nissan Pathfinder
41 people viewed this question
jasbo
jasbo
