Question about Brother MFC 210C All-In-One InkJet Printer
Brother 210 C Unable to Clean message appears in
Brother 210 C Unable to Clean message appears in the LCD box,
    President:
  • 787 Answers
Probably it's waste ink tank is full.
Try this:
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value which is I assume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set". Do the same for numbers 7, 8 and 3. After you have entered this combination, the purge numeric value will be reseted to 00000.
Posted on Sep 29, 2009
SAYS UNABLE TO CLEAN
"How do I clear the message Unable to..." ( "Unable to Change" "Unable to Clean" "Unable to Init" "Unable to Print" "Unable to Scan" )?
Step1: To clear the message follow the steps listed below:
1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.Unplug the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2.If the error continues to appear, the machine may have a mechanical problem.If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. Please make sure you have followed the instructions in the Step1.
3.If the error still continues to appear, move the print head and examine under the print head.
3-1.Disconnect the Brother machine from the poweroutlet.
3-2.Open the scanner cover by pulling up on the lower right corner of the cover.
3-3.Check the print head's position.
3-4.Gently move the print head to the center.
3-5.Examine under the print head. If anything is found, remove it.Use a flashlight if necessary to check thoroughly.
3-6.Close the cover and reconnect the machine to the power outlet.
If the message continues to appear on the LCD, the machine will require repair.
Step2: Check if the machine has faxes in its memory
1.Transfer the Fax Journal Report
1.Press Menu/Set or Menu on the Control Panel of the machine.
2.Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set or Menu.
3.Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set or Menu.
4.Press the up or down navigation key until Report Trans appears on the LCD. Then press Menu/Set or Menu.
5.The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Black(Mono) Start.
2.Verify and Transfer faxes in memory
4.Press the up or down navigation key until Fax Transfer appears on the LCD. Then press Menu/Set or Menu.
5.If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3. If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Black(Mono) Start .
3.Reset the machine
After the Fax Journal Report and faxes in memory have been transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
Feb 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
I am facing the problem of clean unable 46 and clean unable Af please give me solution
The error message "Clean Unable 46" is an indication that the machines ink absorbers are full or almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
There is a possibility that this message may have occurred in error. Upgrading the firmware of the Brother machine may resolve the issue. Follow the procedure below to determine if a firmware update is required:
-if the display screen is displaying an error message, press the STOP/EXIT key to change the LCD to the main screen.
-press the # and * key at the same time. The first 2 characters on the top row will determine the ROM version.
If the ROM version is OE or greater (example: OF, OG, OH, etc), the firmware does NOT need to be upgraded. If the ROM version is OA, OB, OC or OD, follow the procedure on this link to upgrade the firmware.
If the message "Clean Unable 46" continues to appear on the display the Brother machine after completing the firmware upgrade and your machine is within warranty (even if it's not under warranty you have to do the same thing), you have to take it to a Brother Authorized Service Center. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000059/faq002659_000.html?reg=us&c=us&lang=en&prod=mfc290c_all&Cat=11
Dec 17, 2010 | Brother MFC-290C Printer
Unable to clean can you help
The message "Unable to Clean" will appear on the display if there is a mechanical malfunction of the Brother machine OR if a foreign object, such as a paper clip or ripped piece of paper, is stuck in the machine. Check the machine for any foreign objects by following the steps listed below:
1. Open the scanner cover by pulling up on the lower right corner of the cover until it locks into place.
2. Look inside the Brother machine and remove any foreign objects.
3. Close the scanner cover by lifting it slightly to release the lock, gently push the scanner cover support located in the back of the unit and then close the scanner cover.
If the message Please Wait - Unable to Clean continues to appear on the display the machine will need to be reset. To reset the machine, unplug it from the power outlet for several seconds and then plug it back in. If the date and time appear on the LCD, then the problem is resolved.
If the message continues to appear on the display your machine is within warranty, you can locate a Brother Authorized Service Center (ASC) in your area by clicking on the link below:
http://www.brother-usa.com/service/default.aspx or contact Brother Customer Service by calling 1-877-Brother (1-877-276-8437) Monday through Friday, excluding holidays.
If your machine is out of warranty, you can locate a Brother Authorized Service Center using the information listed above.
If you need more help come back.Post /thumbs / testimonial are welcome!
Nov 28, 2010 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Brother Model DCP-340CW - Unable to clean
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
    Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.
    If the error message continues to appear, the machine will need to be reset. Disconnect the machine from the power source for several minutes then reconnect it.
If the message continues to appear on the LCD, please contact Brother Customer Service.
hope this helps please leave rating (vote)
Jan 26, 2009 | Brother DCP-350C InkJet Printer
Unable to clean message on mfc5440cn?
Ink absorber box needs to be replaced. Take machine to nearest authorized dealer for them to replace. Machine has to be dismantled for box to be installed!
Dec 28, 2008 | Brother MFC-5440CN All-In-One InkJet...
[HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Sep 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
BROTHER MFC210-C "UNABLE TO INIT"
good day! Unable to print 50 means'' the machine does not work due to paper jam or some sensor...mostly unable to print 50 is sensor problem. to clear the problem clean the sensor, and then the mechanical...t
Dec 07, 2017 | Brother MFC 210C All-In-One InkJet Printer
Brother DCP-115C unable to clean
you need a new waist ink absorber box from a service partner which can be found at brother homepage of you country.
After replacing the box you have to do a reset.
search error 46 or unable to clean here in the forum. it has been written many times.
May 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
287 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
