Siemens Gigaset 4000 Phone
Problem for Siemens Gigaset 4000 Phone (Gigaset 4000 Comfort)
I have a siemens 4000 handset and I like to
By angelos436 on Sep 29, 2009
I have a siemens 4000 handset and I like to register it to a ssiemens 4215 base. Is that posible? Please help.
Best Solution
posted on Sep 29, 2009
Very Helpful)
Samyfam
Rank: Guru
Rating: 92%, 90 votes
Yes. All DECT compatible handsets will register to a DECT compatible base unit.
If you have the manual for either phone, just follow the instructions.
If you dont, some manufacturers do have some odd quirks to the registration process, but most follow the following.
Look on the bottom of the base unit - there should be a 4 digit number somewhere. There will probably be lots of other longer numbers and bar codes also, but these are unrelated.
The base unit needs to be put in to registartion mode - usually done by either switching it off, waiting about 30 seconds, and then switching it on. Or, press and hold the base unit's page / find handset key. NB. the base unit stays in registartioon mode for about a minute, so if you dont complete the handset steps before this time, you have to start again.
Somewhere in the handsets menu will be a register handset option. On selecting this it will then ask for the 4 digit number above. Enter this, and after a short wait, the handset will be registered. Remember, this has to be done before the base unit times out.
Also note; base units can only register 4 or 5 handsets (depends on manufacturer), so if you've already got this number, you'll have to de-register one of the others first.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you very much. My phones are working again. " - angelos436
Popular Solutions for Siemens Gigaset 4000 Phone
Questions and Unsolved Problems for Siemens Gigaset 4000 Phone
Do you recommend Siemens Gigaset 4000 Phone (Gigaset 4000 Comfort)?
Answer
Answer
Two of my Siemens Gigaset 4200 is in a "searching" mode on the handset. I cannot make any... (More)
Answer
Siemens Gigaset 4000: I put in new batteries, this doesn't solve the problem. The ringer icon on the... (More)
Answer
Main base phone is not working at all. I can go through the menus fine - but no dial tone - can't... (More)
Answer
Please all I need is printed instructions for siemens gigaset AL170Duo cordless telephone to be sent... (More)
Answer
sorry, my handset lost connection with the base and now there is "base search" blinking on... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Siemens Gigaset 4000 Phone:
Top Phone Experts
Rank: Guru Guru
Solutions: 567
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Phone Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
